sick620 Posted September 25, 2009 Report Share Posted September 25, 2009 i want to make a custom cover for my 620. its a long bed. what supplies would i need and what would have to be done? thanks Quote Link to comment
sick620 Posted September 26, 2009 Author Report Share Posted September 26, 2009 bump :) Quote Link to comment
skunk Posted October 4, 2009 Report Share Posted October 4, 2009 i hope some people reply on this one because i want to do the same thing. you thinking fiberglass? Quote Link to comment
sick620 Posted October 4, 2009 Author Report Share Posted October 4, 2009 ya fiberglass. if it too hard then leather . Quote Link to comment
VoidDragon Posted October 5, 2009 Report Share Posted October 5, 2009 My suggestion is take some measurements when start looking for a truck with similar ones that they make covers for, Quote Link to comment
Guest DatsuNoob Posted October 5, 2009 Report Share Posted October 5, 2009 Dammit. I thought you were gonna show us how to make one :mad: :D. I forgot to ask Stacey with the tricked out purple 620 (at Datsunfish's BBQ) where his came from. Quote Link to comment
skunk Posted October 5, 2009 Report Share Posted October 5, 2009 i wonder if i could just buy and fiberglass cover and cut it to size, cut in half both ways and take the extra out the middle, then fiber glass back together? i think it would be hard but if i took my time i think i can do it. Quote Link to comment
oneslick720 Posted October 10, 2009 Report Share Posted October 10, 2009 i just took the flush mount from my s10 and cut it down to fit my 720 what surprised me is it was nothing more than 1" thick Styrofoam with fiberglass on both sides of it and trim pieces so it sits flush on the bed rails so i will for sure make my own for my 521 now that i see how easy it is Quote Link to comment
skunk Posted October 10, 2009 Report Share Posted October 10, 2009 did ya take any pics? Quote Link to comment
oneslick720 Posted October 10, 2009 Report Share Posted October 10, 2009 No I sure didn't I didn't even think about it sorry..... But if you do find one off something else be sure that it is square cause after I cut it the first time is when I found out an s10 bed Is 1 1/2 out of square from front to back Quote Link to comment
skunk Posted October 10, 2009 Report Share Posted October 10, 2009 well now that i really think about it i think i make just try and make one with fiberglass myself Quote Link to comment
oneslick720 Posted October 11, 2009 Report Share Posted October 11, 2009 i couldnt tell you where to buy a 1" think piece of Styrofoam at but i was really surprised at how simply they were made and then charge 500+ dollars for the flush mounted ones and it is super light weight Quote Link to comment
skunk Posted October 11, 2009 Report Share Posted October 11, 2009 i think im going to make a mold out of wood, and fill it with that spray foam, break the mold and ill have a big peace of foam to work with. Quote Link to comment
butcherboyjc Posted October 12, 2009 Report Share Posted October 12, 2009 I got mine off a tundra, cut it and fiberglassed it back together Im still not done I have to fill in the top with more fiberglass. It is strong and still fully functions. Quote Link to comment
skunk Posted October 12, 2009 Report Share Posted October 12, 2009 thanks for the pic that helps alot can you get me a good pick of the hinges? Quote Link to comment
Guest DatsuNoob Posted November 3, 2009 Report Share Posted November 3, 2009 Here's Stacey's from Datsunfish's BBQ Quote Link to comment
1lo620 Posted November 3, 2009 Report Share Posted November 3, 2009 Most of the Mini trucks beds are the same size just different lips and rails. The one my blue truck is a Leer for an S10. And I also own a Leer for a Toyota, Both fit great, So look for a tonnue cover for a mini truck take measurements and go from there. Or PM Rick Rat from this site and have him ask Stacie where he got his or what it is,,,Rick works with him... Quote Link to comment
willz Posted September 24, 2012 Report Share Posted September 24, 2012 if you guys want to make a fiberglass tonneau cover: materials: 2x4, unsure of the length or amount... whatever the distance around the bed is plywood sheeting fiberglass and resin spray gelcoat automotive wax some bondo step 1: take that plywood sheeting and cut it into the the shape of the cover, giving enough room all the way around so that it coves the entire bed step 2: lay the 2x4 around the outline and nail/glue/fix the 2x4 to the plywood (its important to do this with a nice flat sheet of plywood, the thicker the better to eliminate the wood warping) step 3: fill in and smooth the inside where the plywood meets with the 2x4 with bondo, or other such material ( im a big fan of the fiberglass bondo.. its green) cut a piece of carboard to the curve you want the corners to have and drag this around the inside to make it all uniform allow all of this to dry, do any sanding or perfecting you want. This will be your mold for the tonneau step 4: spray gelcoat on the inside as evenly as possible, let that dry step 5: coat the gelcoat with a uniform amount of automotive wax, make sure everything is covered with the wax that will have fiberglass on it step 6: lay your glass down and let it dry cut and sand the edges to your ocd perfection, apply paint, hardware enjoy the nice thing about this method... you can make an infinite amount of tonneau covers 1 Quote Link to comment
Dat Lurka Posted September 24, 2012 Report Share Posted September 24, 2012 if you guys want to make a fiberglass tonneau cover: materials: 2x4, unsure of the length or amount... whatever the distance around the bed is plywood sheeting fiberglass and resin spray gelcoat automotive wax some bondo step 1: take that plywood sheeting and cut it into the the shape of the cover, giving enough room all the way around so that it coves the entire bed step 2: lay the 2x4 around the outline and nail/glue/fix the 2x4 to the plywood (its important to do this with a nice flat sheet of plywood, the thicker the better to eliminate the wood warping) step 3: fill in and smooth the inside where the plywood meets with the 2x4 with bondo, or other such material ( im a big fan of the fiberglass bondo.. its green) cut a piece of carboard to the curve you want the corners to have and drag this around the inside to make it all uniform allow all of this to dry, do any sanding or perfecting you want. This will be your mold for the tonneau step 4: spray gelcoat on the inside as evenly as possible, let that dry step 5: coat the gelcoat with a uniform amount of automotive wax, make sure everything is covered with the wax that will have fiberglass on it step 6: lay your glass down and let it dry cut and sand the edges to your ocd perfection, apply paint, hardware enjoy the nice thing about this method... you can make an infinite amount of tonneau covers Do this and make copies! They made a vinyl one as a dealer option I think. Like 3 pieces sewn together with some stretchy loops to go over the bed hooks. Quote Link to comment
willz Posted October 31, 2012 Report Share Posted October 31, 2012 well, i just got done moving to socal, havent found a place to live yet, but when i get a shop setup again i'll make one and if there is any interest in them i'll consider making more Quote Link to comment
Eagle_Adam Posted October 31, 2012 Report Share Posted October 31, 2012 depending on price and quality im interested Quote Link to comment
Dawa Posted December 15, 2012 Report Share Posted December 15, 2012 i like this guys idea http://www.mysporttrac.com/MySportTrac/projects/DIYTonneauCover/DIYTonneauCover.htm Quote Link to comment
BROWNE Posted June 27, 2013 Report Share Posted June 27, 2013 after looking around for covers for my 75, I thought of using waxed canvas and bungee cord material for an "old school" look Quote Link to comment
BROWNE Posted June 27, 2013 Report Share Posted June 27, 2013 I was planning on cutting out sections of canvas that line up with the bed hooks. Then stitching the bungee cord material in the seam of the wax canvas. Hopefully that makes sense. Quote Link to comment
d510addict Posted June 28, 2013 Report Share Posted June 28, 2013 I wouldn't use wood. Maybe closed cell foam that is glassed over with 2x4 made of the recycled plastic. Wood is heavey it will warp no matter what you do and it won't be as durable. Quote Link to comment
