bonvo Posted September 25, 2009 Report Share Posted September 25, 2009 looking for as many as i can get my hands on h2theizzo ill probibly be taking yours if its good any one else have ones that are good there willing to part with? i dont like the idea of paying almost $100 for a part the size of a matchbook Link to comment
izzo Posted September 25, 2009 Report Share Posted September 25, 2009 looking for as many as i can get my hands on h2theizzo ill probibly be taing yours if its good any one else have ones that are good there willing to part with? i dont like the idea of paying almost $100 for a part the size of a matchbook you will only need one man :D I need to track it down and find it Link to comment
bonvo Posted September 25, 2009 Author Report Share Posted September 25, 2009 you will only need one man :D I need to track it down and find it lol i know but i would rather have a spare or to in the glove box so if it goes out i can replace it quickly and not be out a car to long Link to comment
izzo Posted September 25, 2009 Report Share Posted September 25, 2009 lol i know but i would rather have a spare or to in the glove box so if it goes out i can replace it quickly and not be out a car to long they hardly ever go bad. i am surprised yours did The only reason i had to replace mine, was due to the spade braking off on the matchbox itself. It still works, and i still have it lol. Link to comment
zerow Posted September 25, 2009 Report Share Posted September 25, 2009 looking for as many as i can get my hands on h2theizzo ill probibly be taking yours if its good any one else have ones that are good there willing to part with? i dont like the idea of paying almost $100 for a part the size of a matchbook Thats why the Wrecking Yard Gods put the 280ZXs in the JY - Take/pilfer/pocket the ones from those cars, they are identical. Link to comment
Bleach Posted September 25, 2009 Report Share Posted September 25, 2009 Steal the 810/Maxima ones. Link to comment
datzenmike Posted September 25, 2009 Report Share Posted September 25, 2009 Thats why the Wrecking Yard Gods put the 280ZXs in the JY - Take/pilfer/pocket the ones from those cars, they are identical. Steal the 810/Maxima ones. BEWARE!!! If the matchbox has only the two prong plug on the top you're good to go, but many of the 280zx and Maximas had a second two prong plug on the lower right side like this one: http://i138.photobucket.com/albums/q251/datzenmike/Nissan%20Electrical/DatsunEI003Large-1-1.jpg[/img]"] If it does, pass on it. If this type is used it will start and idle but when revved up it will cause up to 20 degrees of ignition retard. This type is used with EFI cars and the ECU perhaps is programed to introduce ignition retard for emissions purposes. Link to comment
bonvo Posted September 25, 2009 Author Report Share Posted September 25, 2009 they hardly ever go bad. i am surprised yours did The only reason i had to replace mine, was due to the spade braking off on the matchbox itself. It still works, and i still have it lol. well when you find it i want it ill pm you with my shipping info and we will figure a price Thats why the Wrecking Yard Gods put the 280ZXs in the JY - Take/pilfer/pocket the ones from those cars, they are identical. i plan to but i have to have a good one to start so i can drive it Link to comment
Bleach Posted September 25, 2009 Report Share Posted September 25, 2009 BEWARE!!!If this type is used it will start and idle but when revved up it will cause up to 20 degrees of ignition retard. Link to comment
zerow Posted September 25, 2009 Report Share Posted September 25, 2009 BEWARE!!! If the matchbox has only the two prong plug on the top you're good to go, but many of the 280zx and Maximas had a second two prong plug on the lower right side like this one: http://i138.photobucket.com/albums/q251/datzenmike/Nissan%20Electrical/DatsunEI003Large-1-1.jpg[/img]"] If it does, pass on it. If this type is used it will start and idle but when revved up it will cause up to 20 degrees of ignition retard. This type is used with EFI cars and the ECU perhaps is programed to introduce ignition retard for emissions purposes. Thanks, Datzenmike - you are right. I amend my statement. Look for the E12-80 modules, I believe these are E12-93s for the EFI Link to comment
bonvo Posted September 26, 2009 Author Report Share Posted September 26, 2009 (edited) got one commin looking for a second so i have a back up i think im gonna order a stock 79 620 coil tomorrow or maybe an msd coil just so i know the coil is good and rated as a 12 volt not 8 volt coil Edited September 26, 2009 by bonvo Link to comment
mklotz70 Posted September 26, 2009 Report Share Posted September 26, 2009 It's really rare for them to actually fail. They ground through the distributor body. Make sure you run a dedicated ground wire from the dizzy body...usually the screw holding the vac adv in....to the chassis. Core support or similar. Don't forget to put the hink sink compound on the back too. You can get a small tube at Radio Shack. Just needs enough to act as a heat conductor...more isn't always better. Link to comment
fivetengarage Posted September 27, 2009 Report Share Posted September 27, 2009 I have 2 e12-80 modules.You can have them free. PM me your mailing info. Martin Link to comment
