moparvwfreak Posted September 14, 2009 Report Share Posted September 14, 2009 87 cherokee, 4.0 MPI automatic. yesterday i got a call from my wife saying she lost power. not electrical power, but motor power. it seemed to run REALLY rough and just not want to hit on all 6. then it cleared up and ran fine for a few. get it brought home on a hook and today i went to turn it around and move it. ran the same way again. after i got it moved it started running like ass again. full throttle it just bogged and died. restarted ok but still ran rough. a freind of ours said it could be an injector that died. hes been working on cherokees and is a heavy diesel tech so i trust his word, BUT i want a 2nd opinion. ideas anyone???? my thoughts were head gasket, but no water in the oil and no oil in the water unless it popped between cyls. Quote Link to comment
]2eDeYe Posted September 14, 2009 Report Share Posted September 14, 2009 A buddy of mines XJ would run awesome in reverse, as soon as he put it in drive it would run all shitty and try to die. He finally traced to a pinched wire, turns out the linkage was hitting it or something like that. I can find out exactly what was wrong with his (which wire) if that sounds like your problem. Quote Link to comment
moparvwfreak Posted September 14, 2009 Author Report Share Posted September 14, 2009 please do. i am not sure why it would do this out of the blue like this. i had a w TPS and CTS installed 3? months ago. and its been a champ ever since until yesterday. on the way home from work it just bogged and no power. so who knows. i am going to spend the day going over everything i can to figure this out. Quote Link to comment
moparvwfreak Posted September 14, 2009 Author Report Share Posted September 14, 2009 i jsut had a though. could something as simple as a clogged fuel filter do this??? i have never seen it but is it possible??? i dont think its b een changed in the last few years. i cant remember if i did it when i dropped the tank in '05. Quote Link to comment
motavated Posted September 14, 2009 Report Share Posted September 14, 2009 Maybe all the emissions are clogged up? Sea foam it if everything else fails... Quote Link to comment
datzenmike Posted September 14, 2009 Report Share Posted September 14, 2009 One injector couldn't hold it back like described. Lack of proper fuel pressure caused by a clogged filter or bad pump could. Can you test the fuel pressure at the fuel rail? Assume it should be in the mid 30s? Quote Link to comment
moparvwfreak Posted September 14, 2009 Author Report Share Posted September 14, 2009 Maybe all the emissions are clogged up? Sea foam it if everything else fails... its been seafoamed int eh last 6 months. did that right after i fixed the steering column. it had been siting for 2 YEARS before that. One injector couldn't hold it back like described. Lack of proper fuel pressure caused by a clogged filter or bad pump could. Can you test the fuel pressure at the fuel rail? Assume it should be in the mid 30s? i dont have a good enough tester. only one for a carb setup. pump was changed when i dropped the tank in '05. i figured do it while i ahd the tank out. Quote Link to comment
moparvwfreak Posted September 14, 2009 Author Report Share Posted September 14, 2009 heres an odd one. i have been working on it for about 12 hour now, tried starting it 3 times, once to check for spark which i have but a weak orangeish spark, and now the battery is dead. i am thinking the alt was on its way out, again, and finally gave up the ghost and it was running off battery. maybe???? Quote Link to comment
sly-yota Posted September 14, 2009 Report Share Posted September 14, 2009 lol, damn marky... but you know EXACTLY what im going to say the problem is....:lol: :D:p good luck buddie (btw, if you keep frying alts you need to look into your volt. regulator;)) Quote Link to comment
datzenmike Posted September 14, 2009 Report Share Posted September 14, 2009 Low battery + low electric fuel pump pressure = it looks like clogged fuel filter. :D Quote Link to comment
moparvwfreak Posted September 15, 2009 Author Report Share Posted September 15, 2009 good luck buddie (btw, if you keep frying alts you need to look into your volt. regulator;)) this is the 3rd alt in 9 YEARS. cheap ass schucks shit remans. plus they are INTERNALLY regulated like most GMs are. since its a chevy alt. Quote Link to comment
]2eDeYe Posted September 15, 2009 Report Share Posted September 15, 2009 He said "it was a wire, now it don't run at all" :lol: Sry...:( Quote Link to comment
moparvwfreak Posted September 15, 2009 Author Report Share Posted September 15, 2009 its all good. ya tried. tahts what counts. thanks man :) once i get this thing goin again we'll have to go play. Quote Link to comment
banzai510(hainz) Posted September 15, 2009 Report Share Posted September 15, 2009 get a Mean Green Alternator $$$$$$$$$$$$ Quote Link to comment
moparvwfreak Posted September 15, 2009 Author Report Share Posted September 15, 2009 i would but to the tune of $350 i could get an alt for my passat and then some. Quote Link to comment
moparvwfreak Posted September 17, 2009 Author Report Share Posted September 17, 2009 yay!!! i get the fun and joyous job of....... dropping the fuel tank AGAIN!!!!!! when my light comes on, and this is from a chrysler tech, the tank still has about 5-7 gallons left. 13 gallon calibrated float in a 20 gallon tank. the way i figure it is the pickup tube has come off. or has a leak in it somehow. either way its not getting enough fuel to stay running. i syphoned a few gallons out of my datsuns for both my yota and the jeep and now the jeep runs like a champ. even got the one tire fire going. so i know the problem. and am NOT looking forward to yanking hte tank again. Quote Link to comment
yello620 Posted September 17, 2009 Report Share Posted September 17, 2009 Droping that tank beats the hell out of dropping the tank from my suburban.:D Fuel pump died in the suburban a few years ago about 50 miles after filling the tank, only about a 44 gallon tank. Quote Link to comment
moparvwfreak Posted September 17, 2009 Author Report Share Posted September 17, 2009 last time i dropped this tank, i got a bath in 91 octaine. i had just filled it and the pump died. 18 gallons of premium all on my shop floor and me. it slipped off the jack. not fun. Quote Link to comment
moparvwfreak Posted September 23, 2009 Author Report Share Posted September 23, 2009 well i got that taken care of, and now if i dont drive it in 24 hours or less, the battery dies. what fun. if its not one thing, its half dozen others. Quote Link to comment
]2eDeYe Posted September 23, 2009 Report Share Posted September 23, 2009 Just Empty Every Pocket :D Quote Link to comment
moparvwfreak Posted September 24, 2009 Author Report Share Posted September 24, 2009 2eDeYe;208659']JustEmpty Every Pocket :D smartass! suprisingly i havent put a whole lot into it. it may seem like a lot but if you streach it out over the last 9 years its not so much Quote Link to comment
]2eDeYe Posted September 24, 2009 Report Share Posted September 24, 2009 I'd rather not add up how much I've put into mine :D Quote Link to comment
moparvwfreak Posted September 24, 2009 Author Report Share Posted September 24, 2009 well found out that both my alts are good but the battery was shot. so.... i went and got a battery yesterday. seems to work like a champ now. Quote Link to comment
