quik question
Thebandito
  • Replies 14
The pipe is part the PCV (Positive Crank Case Ventillation) system. Ask your dad about a PCV Valve. There should be a rubber hose that is smaller on one end that connects to the PCV Valve which should be screwed into the intake manifold under neth the carberator.
In the diagram the:
Pipe is #4
The hose is #5
The PCV Valve is #6
I cannot tell what # 3 is.
This in my opinion should be hooked up and functional.
now i guess i gotta find th epart for it
Do you have a intake manifold for this engine? The part is probably already in it. You connect a hose from this pipe to something sticking out of your manifold. Is there something sticking out of your manifold that looks like you could stick a hose on it?
