inline4 Posted August 19, 2009 Report Share Posted August 19, 2009 I'm thinking of replacing that valve that splits the brake lines (dunno what its called) with a line lock, so I can kind of have a parking brake.... Quote Link to comment
Rudejester510 Posted August 19, 2009 Report Share Posted August 19, 2009 resourceful..but sadly, it wont work. Line locks are designed to hold the brake pressure for short amounts of time. 60 secs or less at a time or they burn up easily. Also you def don't want to replace the proportioning valve with anything....cept maybe an adjustable one which won't do want your looking to do. Quote Link to comment
72240z Posted August 19, 2009 Report Share Posted August 19, 2009 I'm thinking of replacing that valve that splits the brake lines (dunno what its called) with a line lock, so I can kind of have a parking brake.... I think you mean a brake bias/proportioning valve unless you just mean a simple T. None of the things mentioned though will equate to a parking brake though. Quote Link to comment
510six Posted August 20, 2009 Report Share Posted August 20, 2009 I'm thinking of replacing that valve that splits the brake lines (dunno what its called) with a line lock, so I can kind of have a parking brake.... A line lock is used for doing this. http://www.youtube.com/user/sss510#play/uploads/3/LYVhJWjFbCs Quote Link to comment
Guest DatsuNoob Posted August 20, 2009 Report Share Posted August 20, 2009 Why not just hook up a parking brake??:blink: Quote Link to comment
inline4 Posted August 20, 2009 Author Report Share Posted August 20, 2009 Why not just hook up a parking brake??:blink: wilwood rears = Quote Link to comment
72240z Posted August 20, 2009 Report Share Posted August 20, 2009 wilwood makes parking brake kits........ Quote Link to comment
inline4 Posted August 20, 2009 Author Report Share Posted August 20, 2009 wilwood makes parking brake kits........ that work with the dynalite singles? Quote Link to comment
inline4 Posted August 20, 2009 Author Report Share Posted August 20, 2009 http://www.jegs.com/p/Wilwood/Wilwood-Mechanical-Parking-Brake-Spot-Calipers/757779/10002/-1 how would you install that? Quote Link to comment
72240z Posted August 20, 2009 Report Share Posted August 20, 2009 Depends on the application, you would mount it just like the caliper and run a cable to it. It doesn't have to be some crazy billet adapter or w/e to mount it like calipers. If your just using it to park a piece of 1/4 steel and some bolts would be fine. Quote Link to comment
inline4 Posted August 20, 2009 Author Report Share Posted August 20, 2009 Depends on the application, you would mount it just like the caliper and run a cable to it. It doesn't have to be some crazy billet adapter or w/e to mount it like calipers. If your just using it to park a piece of 1/4 steel and some bolts would be fine. google search indicates people have problems with the kit and hot rotors? Quote Link to comment
72240z Posted August 20, 2009 Report Share Posted August 20, 2009 I really don't know, there are a bunch of different kits and applications. Just pointing you in the right direction. You could always sell your rears and get a pair with a parking brake option too. Quote Link to comment
Cuts metal like mad Posted August 20, 2009 Report Share Posted August 20, 2009 or carry a brick! :D Quote Link to comment
72240z Posted August 20, 2009 Report Share Posted August 20, 2009 Ya I don't have the cash for no stinking ebrakes lol. I got 4x4 sections in my bed at all times. Whether it be for the parking brake or so the stock jack can actually reach the frame :lol::lol:. Quote Link to comment
bonvo Posted August 20, 2009 Report Share Posted August 20, 2009 couple of these in the trunk http://www.edarley.com/cat_img/AG083_800.jpg Quote Link to comment
stilltwisted Posted August 20, 2009 Report Share Posted August 20, 2009 if you want an cheep alternative to an ebrake that is hydr you can try a (buggy park lock)just google ,,i have used the chirco one on pretty steep hills and dunes it seem to work well ,,but i have not left it set over nite ,,another down side is that you would have to run hydr line inside passenger compartment with you,,if it fails brake fluid is nasty to cleanup Quote Link to comment
BoostinBen Posted August 21, 2009 Report Share Posted August 21, 2009 I have a line lock in my 510 and no ebrake. Let me tell you they are definetly not good enough for parking brakes. they fade out after being parked for a few min. Id never trust one Quote Link to comment
arkitekz Posted August 21, 2009 Report Share Posted August 21, 2009 Inline4, Were you out there tonite at the sd meet in mission valley? I was the one with the blue ka 510. Quote Link to comment
inline4 Posted August 21, 2009 Author Report Share Posted August 21, 2009 Inline4,Were you out there tonite at the sd meet in mission valley? I was the one with the blue ka 510. hhaha that makes sense now. yeah I'm Joe. the other guy with the KA, your name is josh right? I have a horrible memory. Quote Link to comment
Cuts metal like mad Posted August 21, 2009 Report Share Posted August 21, 2009 I still vote brick, its also an effective weapon! :lol: Quote Link to comment
arkitekz Posted August 22, 2009 Report Share Posted August 22, 2009 hhaha that makes sense now. yeah I'm Joe. the other guy with the KA, your name is josh right? I have a horrible memory. close, I'm a Joe as well. Joseph to be exact. Quote Link to comment
SaSeda Posted August 25, 2009 Report Share Posted August 25, 2009 Maybe check out eBay and see if anyone is selling one that they brought. Id love a cross trainer and have been considering hiring one as I know that it will just be a passing fade. Quote Link to comment
hang_510 Posted August 25, 2009 Report Share Posted August 25, 2009 Maybe check out eBay and see if anyone is selling one that they brought. Id love a cross trainer and have been considering hiring one as I know that it will just be a passing fade. STFU :fu: Quote Link to comment
yellowdatsun Posted August 25, 2009 Report Share Posted August 25, 2009 Just to make sure everyone is on the same page......the dealy bob in the engine compartment is NOT a proportioning valve. It's merely a distribution block, and you can delete it if you want. I have, as well as many others. It's ugly, and unnecessary. Quote Link to comment
