datsun77 Posted July 7, 2009 Report Share Posted July 7, 2009 someone posted about a chemical you can buy at home depot that kills rust does anybody know what it is called Quote Link to comment
jefe de jefes Posted July 7, 2009 Report Share Posted July 7, 2009 ospho? Should contain phosphoric acid. Quote Link to comment
whitechef Posted July 7, 2009 Report Share Posted July 7, 2009 (edited) It's called sandpaper. No no, just kidding, When I used to do bodywork we used a product called Rustmort, we got at the paint shop we used. I've also used sodium hydroxide and it works really well but be very watchful if you dip aluminum, it eats it up quick and have lots of water nearby. You can make it by mixing 1 can of Red devil lye with 2 gallons water in a plastic bucket. Edited July 7, 2009 by whitechef Quote Link to comment
yellowdatsun Posted July 7, 2009 Report Share Posted July 7, 2009 Hydrochloric pool acid. Works *REALLY* well, but is also highly toxic, and will eat your skin. It's really sweet for small parts though, just buy the 5 gallon tub, let the parts sit in there for an hour, and all the rust is gone. Hose the parts off with brake cleaner instead of water so they don't immediately rust again. I keep a 5 gallon jug on the side of the house for small parts. You can brush it on larger panels, but it usually eats the brush. Quote Link to comment
mklotz70 Posted July 7, 2009 Report Share Posted July 7, 2009 ..hhmm...I like the brake clean idea to stop the flash rust. Word of warning about having the bucket close to the house. If the lid doesn't seal well, the vapors will eat metal items in the vacinity. You'll end up with a bright orange rust on any bare metal near it :) Quote Link to comment
yellowdatsun Posted July 8, 2009 Report Share Posted July 8, 2009 It's stored next to my block fence, it could spill and not hurt anything where it's at. Parts look brand new when you use this. Be careful though, because the acid will eat aluminum, quick too. Quote Link to comment
MikeRL411 Posted July 8, 2009 Report Share Posted July 8, 2009 Try Naval Jelly. Quote Link to comment
yellowdatsun Posted July 8, 2009 Report Share Posted July 8, 2009 If you want to actually fully remove rust, POR-15 is not the right product. BUT, POR-15 is an awesome product that actually encapsulates rust. So you basically wire wheel the rust and get the chunks off, and then brush it on. So if you have a floorboard that has rust, but it's not through yet, then POR-15 is ideal for that. Encapsulates everything and prevents it from getting worse. I used it on a 521, and parts of a 510. There's also a 2 part epoxy POR product which also works wonders. Even available in clear, which I used on the steel front door of my house. They are expensive, but worth the money. Quote Link to comment
mklotz70 Posted July 8, 2009 Report Share Posted July 8, 2009 Also with the acid....you don't want to forget the part in there....it will eat the good metal once it's done with the rust. There's a rust removal thread on this forum with several other options. There's a rust remover available at HF too...it actually seems to work pretty nicely. Not as fast as acid, but a lot safer!! Molasses is the cheapest/safest.....but extremely slow and not suited for stuff like body panels and floor boards. Quote Link to comment
Guest DatsuNoob Posted July 8, 2009 Report Share Posted July 8, 2009 I bought some Phosphoric acid etch and prep (Home Depot), made by Kleen-strip. Only 15 bones! I'll let you know how it works out. Quote Link to comment
71ka510 Posted July 8, 2009 Report Share Posted July 8, 2009 check these guys out... some sweet sh*t http://www.safestrustremover.com/ Quote Link to comment
djmoreron Posted July 8, 2009 Report Share Posted July 8, 2009 ive used naval jelly. you can get that at any home depot or lowes. i worked it into the rust with a wire brush. its smelly though, and i probably wouldnt do it again. it will strip everything that it contacts, so prep well. lots of options out there. Quote Link to comment
az_rat210 Posted July 16, 2009 Report Share Posted July 16, 2009 check these guys out... some sweet sh*thttp://www.safestrustremover.com/ I used the safest rust remover on my floor boards and other parts. For the floor boards, I built a funnel underneath to a bucket. Got a fish tank pump, with hose and just plugged it in and let it flow over the flooor boards. 24 hours later no more rust...washed it and applied POR15. The Safest Rust Remover is costly but its biodegrable, non-toxic, which is why I went with it. If you use it, make sure its in a cool place out of the heat and sun due to its evaporation rate. Another advantage to it is that its reusable, just pour it through a filter to clean out the crud and your set to use it for the next set of parts. It fully removes paint and anodizing too. Forgot to mention, it will NOT remove POR15 that has been properly applied. Quote Link to comment
mklotz70 Posted July 16, 2009 Report Share Posted July 16, 2009 didn't happen if you didn't take pics :) Any chance you did? Would love to see before/after...even the setup during. The paint/anodizing removal is intriguing :) Quote Link to comment
sanitys Posted July 16, 2009 Report Share Posted July 16, 2009 my build thread has pictures of the phosphoric acid stuff from home depot. And when you get the whole por-15 kit it comes with cleaners and acids. Great way to redo motorcycle tanks... Quote Link to comment
paradoxx Posted July 16, 2009 Report Share Posted July 16, 2009 I used Dual Etch. I think is a product of Sherwin Williams, not sure. Quote Link to comment
az_rat210 Posted July 16, 2009 Report Share Posted July 16, 2009 didn't happen if you didn't take pics :) Any chance you did? Would love to see before/after...even the setup during. The paint/anodizing removal is intriguing :) I can show a pic of the pre-rust removal, but now it has POR15 and Bed Liner over it, so no after pics. Quote Link to comment
bonvo Posted July 16, 2009 Report Share Posted July 16, 2009 if you have an electric drill the 3m paint and rust stripping wheels work well they just wear out fast i just used them to finishe removing the rust from the back seat area of my car Quote Link to comment
