compression Posted June 29, 2009 Report Share Posted June 29, 2009 Who sells polyurethane bushings for the rear subrame crossmember? I am talking about the big ones (3.5" or so...) that go in the very ends of the crossmember. I have used "savage washers" ( thanks Gary!) in the past, but now I am looking for a little more tightness (is that a word?)without solid mounting it. thanks Quote Link to comment
philcas1987 Posted June 29, 2009 Report Share Posted June 29, 2009 A company in australia makes blue poly ones. Also a us based company makes a solid mounts as well. I just can't think the names or web site. Heirfaus has components from both companies. Pm him Quote Link to comment
Colbino Posted June 29, 2009 Report Share Posted June 29, 2009 http://www.racetep.com/datsunsusp.html Quote Link to comment
sssr20det510 Posted June 29, 2009 Report Share Posted June 29, 2009 I think datsport has them Quote Link to comment
DISLEXICDIME Posted June 29, 2009 Report Share Posted June 29, 2009 you could always do the savage washers Quote Link to comment
compression Posted June 29, 2009 Author Report Share Posted June 29, 2009 thanks for the replies! Quote Link to comment
dat510sss Posted July 4, 2009 Report Share Posted July 4, 2009 Check this out,not poly but urethane, http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=290237946597 You could mail them and ask if they just could sell the ones you need..?? Does anybody know the the difference in poly and urethane? Or is it any? -Richard Quote Link to comment
thisismatt Posted July 4, 2009 Report Share Posted July 4, 2009 Check this out,not poly but urethane, http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=290237946597 You could mail them and ask if they just could sell the ones you need..?? Does anybody know the the difference in poly and urethane? Or is it any? -Richard Polyurethane products are often called "urethanes". They should not be confused with the specific substance urethane, also known as ethyl carbamate. Polyurethanes are not produced from ethyl carbamate, nor do they contain it.They're polyurethane...people sometimes just call them urethane. Quote Link to comment
Icehouse Posted July 5, 2009 Report Share Posted July 5, 2009 Polyurethane may not be to bad for the rear sub frame bushings but I wouldn't use it anywhere else! Junk IMO. I like the guys idea on the realm. He turned out some aluminum bushings to replace the stock rubbers on the rear sub frame. Quote Link to comment
DISLEXICDIME Posted July 5, 2009 Report Share Posted July 5, 2009 http://datsun510.com/photopost/showphoto.php?photo=656&ppuser=9 Quote Link to comment
DISLEXICDIME Posted July 5, 2009 Report Share Posted July 5, 2009 (edited) i wonder how much noise it makes having the rear solid mounted i bet it is loud there is that one company thAT sells the whole kit to solid mount the whole rear Edited July 5, 2009 by DISLEXICDIME Quote Link to comment
Pedro Posted July 5, 2009 Report Share Posted July 5, 2009 http://www.noltecsuspension.com/products.php I used them in my car and I can report they made a huge difference, the ride is so smooth it almost doesn't feel like a datsun :blink: I did crossmember and trailing arm bushes, along with front LCA bushes and castor rods bushes, front bump stops. Quote Link to comment
