Bleach Posted December 10, 2007 Report Share Posted December 10, 2007 Run dual heater cores... :D you won't need a radiator fan then Quote Link to comment
datsun dreamer Posted December 15, 2007 Author Report Share Posted December 15, 2007 O.K, What if your defrost was working and throwing hot air, But your panel vents weren't? Quote Link to comment
datzenmike Posted December 15, 2007 Report Share Posted December 15, 2007 The two dash mounted side vents are individually, operated cold air vents to the outside. The cab heat is linkage operated by the heater controls. At the bottom of the heater assy. there is a movable flap door. in the up, or clossed position, hot air can only go up and out the defrost vents, down and the air is let out into the cab onto the tranny hump. The linkage may have fallen off or is out of adjustment. Quote Link to comment
NWOleman Posted December 16, 2007 Report Share Posted December 16, 2007 Or you could just yank it out and put in a aftermarket heater. That's whay i'm doing to the ol 73'. Just got it, 28,000 btu's! Sweet! Haven't installed it yet but will post info soon as i do. Quote Link to comment
hang_510 Posted February 15, 2008 Report Share Posted February 15, 2008 Or maybe screen over the slots in the cowl. bump :eek: here is what i found stuck in the drain part of the cowl...along with 10lbs of: pine needles/dirt/bamboo leaves/rocks/1 wiper boot anyone under 25 has probaly never seen one before :glare: good thing its aluminum Quote Link to comment
DISLEXICDIME Posted February 15, 2008 Report Share Posted February 15, 2008 wow i have not seen one of those since i was a kid Quote Link to comment
DanielC Posted February 15, 2008 Report Share Posted February 15, 2008 I was on a church youth camp on Lake Shasta, in 2005, with my boat, and found five or six pull tabs on the beach when the water was low. One evening we had a contest to see if any of the youth could identify the "mystery object" About five or six, out of around 200 kids guessed correctly. Quote Link to comment
datzenmike Posted February 16, 2008 Report Share Posted February 16, 2008 Haven't choked on one of those in decades. Quote Link to comment
