ggzilla Posted April 18, 2009 Report Share Posted April 18, 2009 What is the really small alternator I see advertised from hotrod shops? They are like half the size of most alternators (e.g. regular Datsun alternator). Is it the Saturn alternator or something else that can be found at a wrecking yard? I'd like to swap one in that weighs less than the Datsun Hitachi LT series alternators. My LT-135 (early 510 type) weighs 8.4 pounds with pulley. The LT-150 (50A) 1974-1978 unit weighs 9.6 pounds. Quote Link to comment
datzenmike Posted April 18, 2009 Report Share Posted April 18, 2009 (edited) LT 135 (35amp) and optional LT 138 (38amp) alternators were used only through '77. LR 135 (35amp) and optional LR 138 (38amp) alternators were used from '78-through '80 on the 620s and first year 720s. LT signifies external regulator, LR is for internal regulator. All alternators after '78 were LR. The LR 150 and LR 160 (50 and 60amp) weren't available until the '81 model year 720 and though they will physically fit the older 620s, they are larger in diameter and will/can rub the lower rad hose and idler arm. Check this out: I have heard that the '88-'93 Maxima alternator LR 190 23100 85E00 will work if you swap the 620 pulley onto it and drill the threads out of the housing so you can use through bolts to mount it. The output is a nice 90 amp and they are small. Edited April 18, 2009 by datzenmike Quote Link to comment
Bleach Posted April 18, 2009 Report Share Posted April 18, 2009 There were lots of 89-93 Maximas (2nd gen) at the Tacoma yard a couple months ago. Seems those and the 1st gen Altima are very popular wrecking yard cars. Quote Link to comment
ggzilla Posted April 19, 2009 Author Report Share Posted April 19, 2009 Yes, all those are typical size. What are the really small ones (about 4-5 inches in diameter?) Quote Link to comment
Duke Posted April 19, 2009 Report Share Posted April 19, 2009 I have heard that Subaru alternators are really small. I think I have seen them mounted on SR's, so I bet you could make them work on an L-motor fairly easily. I'm not sure of the output though. Quote Link to comment
Rubberman Posted April 25, 2009 Report Share Posted April 25, 2009 LT 135 (35amp) and optional LT 138 (38amp) alternators were used only through '77. LR 135 (35amp) and optional LR 138 (38amp) alternators were used from '78-through '80 on the 620s and first year 720s. LT signifies external regulator, LR is for internal regulator. All alternators after '78 were LR. The LR 150 and LR 160 (50 and 60amp) weren't available until the '81 model year 720 and though they will physically fit the older 620s, they are larger in diameter and will/can rub the lower rad hose and idler arm. Check this out: I have heard that the '88-'93 Maxima alternator LR 190 23100 85E00 will work if you swap the 620 pulley onto it and drill the threads out of the housing so you can use through bolts to mount it. The output is a nice 90 amp and they are small. Datzenmike, on the 88-93 Maxima alternator, what about the wiring? Plug in? I guess you would need the original plug-in off a maxima to to rewire it? Right? Quote Link to comment
datsunhead Posted April 25, 2009 Report Share Posted April 25, 2009 you are looking for a fork lift alternator. we use them on race cars all the time. but dont buy one from hotrod guys.they mark them WAY up.call your local fork lift dealer.better be nissan. Quote Link to comment
3nickels Posted April 25, 2009 Report Share Posted April 25, 2009 GM ALTERNATOR CS121 Style (GM's Smallest Delco Alternator) Quote Link to comment
ggzilla Posted April 25, 2009 Author Report Share Posted April 25, 2009 Thanks guys. I have now located a small Toyota forklift alternator. Quote Link to comment
mklotz70 Posted April 25, 2009 Report Share Posted April 25, 2009 I know which one you're talking about.....they're at all the shows and swap meets. I used a Toy Corolla one for the NL. 65A and it's a good bit smaller than the stock one you're talking about. Not quite as small as the one you asked about. Quote Link to comment
