lynchfourtwenty Posted August 13, 2007 Report Share Posted August 13, 2007 hmmm.. so whats best to do... go with the carb setup.. or fuel injection.. if i couldnt get a FI manifold whats the best way to make one.. also would i need a computer for the fuel injection? or? how difficult would it be to plumb everything?? would it clear the steering column in my 620? been thinkin alot about it an i think thats the route im going to go.. im not lookin for alot of horse power.. maybe 150 or so maybe a little more.. Quote Link to comment
datzenmike Posted August 13, 2007 Report Share Posted August 13, 2007 If you go to 'The 510 Realm' there's a guy called hairfaus (Chris) who has an L20B EFI project. Got a 280 z intake and cut and welded the two halves to make an L20B intake (very well done, and cool, very trick). He is now looking to turbo it. It's a good read and you might get some ideas (or change your mind lol) Quote Link to comment
Bleach Posted August 13, 2007 Report Share Posted August 13, 2007 go fuel injection. A carbbed L20b turbo will have less power than a KA24e you're doing this for the nostolic reason of running an L-series, right? Because you know an engine swap to pretty much anything else will not only be easier but probably more powerful. And I'm talking about an NA engine. L20bet 8psi probably 140-160hp at most Quote Link to comment
///FiveOneOh Posted August 13, 2007 Report Share Posted August 13, 2007 Tell keith law that with his 300HP L20B turbo monster....:confused: Quote Link to comment
Icehouse Posted August 13, 2007 Report Share Posted August 13, 2007 Tell keith law that with his 300HP L20B turbo monster....:confused: That's 30 years of development. I thought he said between 220 and 240 to the wheels was his estiment. Did he dyno it? Quote Link to comment
datzenmike Posted August 13, 2007 Report Share Posted August 13, 2007 Yah the A.S.S. dyno. Yes they have dyno days up here. There's one in the works and we'll soon know! I think he ran a larger cam and recently went back to the old one. It should be safely over 200 hp, safely! Maybe the unknown amount arrises from RWHP and trying to guess the crank hp. Quote Link to comment
lynchfourtwenty Posted August 13, 2007 Author Report Share Posted August 13, 2007 bleach, yea i know most engine swaps would get me more power and such, but i like my lil l20b and i think im gonna stay l-series in the truck i was jus lookin for some more power, an maybe a blow off valve lol, theres not alot of l20b turbos around an the ones that are around are spoken highly of.. it'd just be nice to say, Yeah i did that!.. when i get a Z or 510 or something i will do a swap of some sort i like the l28's those are cool but an RB is cool also.. lol thanks mike Quote Link to comment
///FiveOneOh Posted August 13, 2007 Report Share Posted August 13, 2007 I thought it was dynod at 260 wheel a # of years ago. Its faster since then. We will find out on the 25th. 510 club dyno day. Come up and run!!! Quote Link to comment
Bleach Posted August 13, 2007 Report Share Posted August 13, 2007 the hardest part is the manifolds. If you can source the FI 4-cyl intake manifold and get a custom exhaust manifold made then you're well on your way. Well, Keith probably spent twice (or three times) what a 250hp SR20DET would have cost. That's my point. It is great that he got the old L-series up to those hp levels though. One idea might be to keep your compression low and use a closed chamber head. A way to do this is use a shorter stroke engine. L18, with the large dished pistons from an L20b. Then put on the closed chamber A87 head. It'll be a new engine on the side that you need to build but it should work better. Then you don't have to worry about blowing out the stock rings at 9psi. :D Quote Link to comment
lynchfourtwenty Posted August 13, 2007 Author Report Share Posted August 13, 2007 well i got to drooling over a certain 280zx turbo intake manifold an started wondering how easy or hard it would be to make it fit the 4 cyl head... as for the exhaust manifold i maybe able to have something like that fabb'd up for me, im thinkin 7psi would be enough boost to keep me happy, an if i ever blew the engine i could either get another block an build it back up or sell the manifolds to someone else wanting to go that route an use the turbo an other stuff for another engine... i just was tryin to get some opinions and some ideas, im broke right now but i want to do SOMETHING to my truck.. so im jus tryin to figure out what that something is Quote Link to comment
///FiveOneOh Posted August 13, 2007 Report Share Posted August 13, 2007 I have an old crown 510 turbo kit in my garage ;) Quote Link to comment
nismopu Posted August 13, 2007 Report Share Posted August 13, 2007 you source me an intake lynch and I will cut it up for ya and weld it back together. the kiz and I are already doing it to another manifold of mine. Also, I wonder if we could section an l28et exhaust manifold? wouldnt that be crazy looking? Too bad we didnt get the euro versions that were in three seperate pieces. we could just clamp the front and rear sections together without a hitch. It would look so cool and factory as well!!! peace. Quote Link to comment
DISLEXICDIME Posted August 13, 2007 Report Share Posted August 13, 2007 i know where there is manifold remember kyle we found it on a friday. And dont forget we can always copy my manifold for the exaust side. JUST REMEMBER LYNCH TURBOING AN L IS OFTEN MORE EXPENSIVE THAN SWAPING AN ENGIN ! p.s. don't forget to o ring the block or els you will be replacing your head gasket ! Quote Link to comment
sjeff64 Posted August 14, 2007 Report Share Posted August 14, 2007 I think I said this before but I will say again. I have several rochester tbi's I aleady drew up an adapter plate to fit weber dg manifold just need someone to cut it. Jeff Quote Link to comment
datzenmike Posted August 14, 2007 Report Share Posted August 14, 2007 Keith runs over 10:1 compression with water and al cool injection to tame the cylinder temps. Less than that and there's little throttle response in the lower ranges. His has an I/C and a blow through a Weber carb induction. Quote Link to comment
Fineline Posted August 14, 2007 Report Share Posted August 14, 2007 Definately go FI. The cut 280 mani can be done although the two sides are about 1/4" off. Quote Link to comment
Icehouse Posted August 14, 2007 Report Share Posted August 14, 2007 I thought it was dynod at 260 wheel a # of years ago. Its faster since then. We will find out on the 25th. 510 club dyno day. Come up and run!!! I am excited to find out what kind of power it puts down. It looks fast thats for sure :D the hardest part is the manifolds. If you can source the FI 4-cyl intake manifold and get a custom exhaust manifold made then you're well on your way. Well, Keith probably spent twice (or three times) what a 250hp SR20DET would have cost. That's my point. It is great that he got the old L-series up to those hp levels though. Yeah Keiths car has tons of power but tons of gauges to go with all that power. When I had my sr with 200rwhp I had no gauges haha not even a gas gauge :D I'm not trying to talk you out of your idea just adding a little side note :D well i got to drooling over a certain 280zx turbo intake manifold an started wondering how easy or hard it would be to make it fit the 4 cyl head... as for the exhaust manifold i maybe able to have something like that fabb'd up for me, im thinkin 7psi would be enough boost to keep me happy, an if i ever blew the engine i could either get another block an build it back up or sell the manifolds to someone else wanting to go that route an use the turbo an other stuff for another engine... i just was tryin to get some opinions and some ideas, im broke right now but i want to do SOMETHING to my truck.. so im jus tryin to figure out what that something is It will keep you happy for a bit anyways :D I think it will be a fun project for sure! Definately go FI. The cut 280 mani can be done although the two sides are about 1/4" off. When is it going to be on the road? Quote Link to comment
Fineline Posted August 14, 2007 Report Share Posted August 14, 2007 I would tell you soon but I've said that before. Kids go bact to school soon and I have about a month time off comming from work. Im definately getting the itch though. I finally got the intercooler mount worked out so the only thing holding me back is the time. Quote Link to comment
lynchfourtwenty Posted August 14, 2007 Author Report Share Posted August 14, 2007 can someone come up with a list of things i'd have to do so i can maybe think this over.. Nismopu .. i got one ;) Quote Link to comment
Fineline Posted August 14, 2007 Report Share Posted August 14, 2007 FI setup (Manifold, Injectors, ECU, wiring, etc.) Turbo Exhaust mani Charge piping BOV Oil supply pickup point Oil return point (bung welded into oil pan) Boost referencing ignition with timing retard Intercooler High volume oil pump High volume/pressure fuel pump FPR Quote Link to comment
nismopu Posted August 14, 2007 Report Share Posted August 14, 2007 if your only after a few pounds of boost I dont see why you couldnt run another vehicles EFI system from say like a ca20 or even the uber rare pontiac sunfire turbo. If you could find the turbo sunfire stuff then you could run individual coils! My buddy has an oil feed and drain kit from jgs that he could sell ya pretty cheap. nice stuff too like braided ss feedline with fittings and a silicone 7/8 drain tube with fittings for a garrett. were gonna have to go j-yard hunting for that turbo and manifold. peace. Quote Link to comment
datzenmike Posted August 14, 2007 Report Share Posted August 14, 2007 An oil cooler More extreme: O ringed head Exhaust temp gauge Water injection An '80 through '83 200sx EFI will work and only six wires to hook up. The CAs will work but require a crank angle sensor distributor I think. That's the beauty of the 200sx it's primitive but simple and will work with ANY 4 cylinder gas motor. Quote Link to comment
Fineline Posted August 14, 2007 Report Share Posted August 14, 2007 I have a complete 200sx FI (wiring, ECU, AFM) if interested. Pretty much everything but the mani and injectors. Like Mike said its really easy to set up. Quote Link to comment
kiznook Posted August 14, 2007 Report Share Posted August 14, 2007 I have a complete 200sx FI (wiring, ECU, AFM) if interested. Pretty much everything but the mani and injectors. Like Mike said its really easy to set up. how much? is it a pre o2 setup? Quote Link to comment
Fineline Posted August 14, 2007 Report Share Posted August 14, 2007 it is a 1983 with the o2 sensor. Its just sitting around my shop taking up space. Make me an offer. Quote Link to comment
