banzai510(hainz) Posted March 26, 2009 Report Share Posted March 26, 2009 I went to the gas staione then went to start the truck. Bam just dead, I said OK lets see how good I am. Ck the battery cables ck bat positive at starter all seemed good. so I put the lights ON and nothing. So I cked the fusable link wire to starter. Then went to fuse box and wiggled the ignition fuse(well all of them and ck the wire near fuse box). then lights cam back On. Truck started right up. Most times its just just CORROSSION Quote Link to comment
datsunaholic Posted March 26, 2009 Report Share Posted March 26, 2009 My 520 would do that. I'd start it up for it's monthly warm-up and it would just shut off randomly (all out, no power to anything). Power to the fuse box, but not to the fuses. Real pain in the rear when it did that on the road. The terminal lugs got corroded. Quote Link to comment
yello620 Posted March 27, 2009 Report Share Posted March 27, 2009 I said OK lets see how good I am. Ohh, your good.:D Damn, L-motor god.:) Quote Link to comment
lynchfourtwenty Posted March 27, 2009 Report Share Posted March 27, 2009 ya the ground wire to my dizzy went bad on me.. i would wiggle it.. fucker would star.. hit the gas.. boom it dies.. over an over im like wtf.. so i just changed out the whole wire an now its all good Quote Link to comment
ggzilla Posted March 27, 2009 Report Share Posted March 27, 2009 Is there some spray that removes the corrosion? Quote Link to comment
72240z Posted March 27, 2009 Report Share Posted March 27, 2009 Is there some spray that removes the corrosion? I know they have a jell I never seen a spray, but for the trouble of that just sand/pipe cleaner in my opinion. Quote Link to comment
athoose Posted March 27, 2009 Report Share Posted March 27, 2009 Is there some spray that removes the corrosion? CRC has a few options. http://www.crcindustries.com/files/2008AutoCatalog.pdf Quote Link to comment
Buzzbomb Posted March 27, 2009 Report Share Posted March 27, 2009 I sprayed some RC car motor contact cleaner on a few of my connections, and it seemed to work pretty good on lighter corrosion. You can pick it up pretty cheap at a local hobby shop. Quote Link to comment
banzai510(hainz) Posted March 29, 2009 Author Report Share Posted March 29, 2009 (edited) Happened again. it was the + side Battery cable, corrossion Edited March 29, 2009 by banzai510(hainz) Quote Link to comment
fisch Posted March 29, 2009 Report Share Posted March 29, 2009 The timing was great on this. After sitting since last Oct I tried to start the 521. I could tell it wanted to start, but just wouldn't catch. Remembered this post. Tightened the battery terminals, cleaneded the connection at the fuse box, BAM, started right up! It is the little things! Quote Link to comment
