Moisabamf Posted March 26, 2009 Report Share Posted March 26, 2009 since it seems i am going to do a rebuild of the car, i want some advice now i have rought 1500 dollars to do this. 800 is going toward engine rebuild, so i have about 700 dollar budget right now i want the car to run better on the freeway, what is the best differential for freeway driving? the only one i can think of is the datsun 210 diff, but that only brings the ratio from 3.9 to 3.88, which is basically negligent. so either get a 210 one, or rebuild mine.(can you get a lower gear ratio made for a housing?) and im also going to put in a bigger radiator with an electric fan. aside from that im good to go all of this for Canby. i hope you norcal folks are happy:D and my pops wont be done in time. loser. it seems that i will be basking in the "farthest driven" glory alone. unless datrod goes. but if he does ill kill him on the way:lol: Quote Link to comment
ggzilla Posted March 26, 2009 Report Share Posted March 26, 2009 Some Datsun 210s came with 3.54 ratio -- mine had that. Keep it lightweight. Better yet, keep your ratio and fit an overdrive 5-speed. For $800 I hope you are getting more than 1200cc :-) Quote Link to comment
Moisabamf Posted March 26, 2009 Author Report Share Posted March 26, 2009 tis the A15. and can you shed more info on the 3.54 diff? and what car to get it from? Quote Link to comment
hang_510 Posted March 26, 2009 Report Share Posted March 26, 2009 Better yet, keep your ratio and fit an overdrive 5-speed. ^that and spend some on the suspension. Quote Link to comment
ggzilla Posted March 26, 2009 Report Share Posted March 26, 2009 Datsun 210, 1980. A12A engine with 4-speed. The gear ratio was 3.54 as I recall. I can double-check tomorrow when Datsun1200.com is back online. Quote Link to comment
Guest jaimesix Posted March 26, 2009 Report Share Posted March 26, 2009 since it seems i am going to do a rebuild of the car, i want some advicenow i have rought 1500 dollars to do this. 800 is going toward engine rebuild, so i have about 700 dollar budget right now i want the car to run better on the freeway, what is the best differential for freeway driving? the only one i can think of is the datsun 210 diff, but that only brings the ratio from 3.9 to 3.88, which is basically negligent. so either get a 210 one, or rebuild mine.(can you get a lower gear ratio made for a housing?) and im also going to put in a bigger radiator with an electric fan. aside from that im good to go all of this for Canby. i hope you norcal folks are happy:D and my pops wont be done in time. loser. it seems that i will be basking in the "farthest driven" glory alone. unless datrod goes. but if he does ill kill him on the way:lol: I will go to Camby in my 610. That is the plan. There are Datsun fans looking to go to Canby, so I do not think going alone will be a problem. About your differential, like Gzilla said, I would place my bet on a 5 speed. Good to know about your project. Glad to hear you are not selling your 1200!:D I would lower your car a bit for the long highway trip. No need for big expense, with the stock parts, just by griding and separating the coil spring perch off the strut ( allowing it to slide through the strut ) and using a clamp, you can have an effective coil over set up. The rear is not difficult either, you can use a one in block, 1.5 block, or have your springs decambered. Keep us posted! OH!, I forgot to mention, the 120Y sway bar fits the 1200. I learnt that at the formerly cool Datsun 1200 site. I do not know if the 610 or 710 stock bars would fit. I have both ( I swapped bigger sway bars in both my 710 and 610 ), so if you need one, I will give it to you, my contribution to your build! We have to make sure it fits, I will try to find out. Jaime.________________________________________________________ Jaime._________________________________________________________ Quote Link to comment
Moisabamf Posted March 26, 2009 Author Report Share Posted March 26, 2009 About your differential, like Gzilla said, I would place my bet on a 5 speed. Good to know about your project. Glad to hear you are not selling your 1200! im glad for your concern, but there was and never will be a plan to sell it the only way that car goes is wrecked with me in crunched inside Quote Link to comment
Skib Posted March 26, 2009 Report Share Posted March 26, 2009 and can you shed more info on the 3.54 diff? and what car to get it from? what rear diff is in there now? I have an R200 and a few R180's. Quote Link to comment
Duncan Posted March 27, 2009 Report Share Posted March 27, 2009 Mo, The 210 is a coil spring rear axle. I put one into my Morris, but it was a real pain in the ass. You have to cut off the 4 link mounting tabs and fabricate spring perches and have custom u-bolts made. I would suspect a custom driveshaft may be necessary as well. (Or mods to an existing shaft) I'm pretty sure the 210 has a wider track width than the B210 axle, and that might stick your wheels out a bit far. The B210 came in a 3:70 ratio and I have a NOS ring and pinion for one. If you're interested, I have a rear axle from a B210 sedan (yes, they are different for Coupe and Sedan just like the 110's) that you can have for free if you want to come pick it up. I have $150 in the NOS ring and pinion, and looking to get that back out of it. (You don't have to buy it if you just want the axle) I don't know the existing ratio in the rear axle, but it was a junk yard pull. If you recall, I was going to rebuild this unit and put it into my sedan. I ran into a 1200 sedan in the junkyard and decided to grab the rear axle out of that and put it back to stock. (It will be fully rebuilt first) If interested, get a hold of me, or we can chat about it Sunday. If you don't want it, let me know and I will see if anyone here wants it, or I will junk the thing. Quote Link to comment
datzenmike Posted March 28, 2009 Report Share Posted March 28, 2009 (edited) Mo, the 3:889 IS a 3.90 I think. It's just rounded up is all. Going to lower rear will kill performance. Try to find an over drive 5spd. like this FS5W60A from an '81 210. I think there was an FS5W63 dogleg for A series too. Not sure. It would be the same as the 200sx but with a bell for A series. http://i138.photobucket.com/albums/q251/datzenmike/Tranny/transFS5W60A81210.jpg[/img]"] You say you're off to Mexico? Have a look around down there for one. Drive it back. Edited March 28, 2009 by datzenmike Quote Link to comment
Moisabamf Posted March 28, 2009 Author Report Share Posted March 28, 2009 mark, i will get taht NOS ring and pinion and axle from ya datszenmike i have to dogleg 5 speed in the car now. and looks like ill be off to mexico every year for a month, and this year were taking a truck, so i plan to come back with some 160j fenders and bumpers for those unfortunate enough to have park bench bumpers Quote Link to comment
Guest jaimesix Posted March 28, 2009 Report Share Posted March 28, 2009 mark, i will get taht NOS ring and pinion and axle from yadatszenmike i have to dogleg 5 speed in the car now. and looks like ill be off to mexico every year for a month, and this year were taking a truck, so i plan to come back with some 160j fenders and bumpers for those unfortunate enough to have park bench bumpers ;) Quote Link to comment
ggzilla Posted March 28, 2009 Report Share Posted March 28, 2009 by griding and separating the coil spring perch off the strut ( allowing it to slide through the strut ) and using a clamp, you can have an effective coil over set up.Do tell. It makes sense, except what is this part about a clamp? 3.545 ratio from Datsun 210 (B310) 1980 with A15 -- the center pumpkin bolts right into the Datsun 1200, no need to replace the axle housing. You will need a 1975-up driveshaft. Some say put a 2mm spacer on the gasket, others say skip that it works anyway. Quote Link to comment
athoose Posted March 28, 2009 Report Share Posted March 28, 2009 Do tell. It makes sense, except what is this part about a clamp? Instead of a welded perch (like stock) or an adjustable plate/screw (like adj. coilovers) you have a clamp positioned/tightened where you want the strut perch to be. By moving the clamp higher or lower on the strut you reposition the perch and coil. Quote Link to comment
athoose Posted March 28, 2009 Report Share Posted March 28, 2009 (edited) i want the car to run better on the freeway, what is the best differential for freeway driving? the only one i can think of is the datsun 210 diff, but that only brings the ratio from 3.9 to 3.88, which is basically negligent. so either get a 210 one, or rebuild mine.(can you get a lower gear ratio made for a housing?) By playing with these variables you can get an idea of what you want. http://www.bgsoflex.com/rpmmph.html Don't forget tire inflation, even a few lbs. can make a difference. Edited March 28, 2009 by athoose more info Quote Link to comment
ggzilla Posted March 28, 2009 Report Share Posted March 28, 2009 What kind of clamp? Datsun 210 came with these ratios: * 3.70 * 3.889 * 3.545 They are H150 pumpkins, fit into Datsun 1200 H145 housing and can handle more torque. Quote Link to comment
athoose Posted March 28, 2009 Report Share Posted March 28, 2009 What kind of clamp? In here. http://forum.ratsun.net/showthread.php?t=8796&highlight=strut+clamp Quote Link to comment
S@nt0s Posted May 3, 2009 Report Share Posted May 3, 2009 save yourself the headache and just run a taller tire..... Quote Link to comment
datzenmike Posted May 3, 2009 Report Share Posted May 3, 2009 If you find a 3.545, found in 210s only, grab the speedo drive from the tranny and swap into yours to keep the speedometer accurate. H-150 were used after Aug. '74. Quote Link to comment
ggzilla Posted May 3, 2009 Report Share Posted May 3, 2009 Yes, Sep. 74 was the start of the 1975 model year which used A14 & H150. 3.545 is listed in the catalog as being for: * AUTO(CAL),A12 from Aug 80 [i.e. 1979 model and newer] * MANUAL(A14,MPG) from Aug 80 * MANUAL(A15,MPG) from Dec 1979 to July 1980 [1980 model only] If you find one, let us know with speedo gear it has. The catalog list 16T or 17T for all models, regardless of gearing. Nissan lists the part numbers for the speedo pinion cog: 16T, 17T, 18T Nissan Japan Parts Business also has 15T and 19T Quote Link to comment
