Drfixit Posted February 22, 2009 Report Share Posted February 22, 2009 I busted the thermostat housing on the L18 thats in my 69 521 where the temp sensor screws in so I need a new one. I see a few for sale but mostly for Z cars. Where can I find out what Thermostat housings will fit my engine from other cars. Are all L series thermostat housings the same or do I need one from an L 18? Thanks again Doc Quote Link to comment
banzai510(hainz) Posted February 23, 2009 Report Share Posted February 23, 2009 were you tryinh to remove the sender??????? They are all stuck in there!!!!!!!!!!!! I did this once also and broke mine. best to get a new one with new hex and sender. send phot of the one you have. Some have a bypass on the lower housing and some dont. which you have? Quote Link to comment
Drfixit Posted February 24, 2009 Author Report Share Posted February 24, 2009 Yah I got lazy and tried to remove the sender without taking the housing off. I went to pry on it and broke the casing where the threads are LOL. No big deal just gotta get another. I see a bunch on ebay but they dont know whether it will fit an L18 or not. I'll put up a pic in just a bit. Quote Link to comment
datzenmike Posted February 24, 2009 Report Share Posted February 24, 2009 They all fit, it's just that it might have too many sensor ports or no water by pass connection. I have one that takes a three bolt (triangle) thermostat cover... go figure. Quote Link to comment
izzo Posted February 24, 2009 Report Share Posted February 24, 2009 hahaha, mine is busted too!! previous owner did it tho not me. I will take a pic in the light thursday of mine and show you. I need to get a new sensor in there too so i can see what kinda temp its running at Quote Link to comment
Drfixit Posted February 24, 2009 Author Report Share Posted February 24, 2009 Ok here is mine. What idiot would pry on a housing at the threads???? Oh, that was me!!! Quote Link to comment
Drfixit Posted February 24, 2009 Author Report Share Posted February 24, 2009 They all fit, it's just that it might have too many sensor ports or no water by pass connection. I have one that takes a three bolt (triangle) thermostat cover... go figure. Thanks Mike, makes it a lot easier to find one. Quote Link to comment
datzenmike Posted February 24, 2009 Report Share Posted February 24, 2009 '79 on L28 had the three bolt top cover. Quote Link to comment
Jester Posted March 6, 2009 Report Share Posted March 6, 2009 '79 on L28 had the three bolt top cover. That's what both of mine look like. Some have a bypass on the lower housing and some dont. So, does this mean we don't NEED to use the "bypass" hose? Quote Link to comment
fisch Posted March 6, 2009 Report Share Posted March 6, 2009 Heh mine was so coroded the bolt heads snapped off, so the only way I could get the bottom off the head was to cut the entire side wall along the long bolt! The bolt was cemented the entire way down with that weird white corossion. Quote Link to comment
datzenmike Posted March 6, 2009 Report Share Posted March 6, 2009 No. The by pass is so that water will circulate past the thermostat and back to the lower rad inlet, back into the pump, into and through the motor and back past the thermostat. The thermostat is mounted on the side of the head and without circulation, the engine can get very hot while the water trapped around the thermostat stays cold. Quote Link to comment
Drfixit Posted March 6, 2009 Author Report Share Posted March 6, 2009 Heh mine was so coroded the bolt heads snapped off, so the only way I could get the bottom off the head was to cut the entire side wall along the long bolt! The bolt was cemented the entire way down with that weird white corossion. AWESOME,yours was worse than mine LOL! I bought a new one on E-Bologna and it had the by pass port. Now that everything is here I just gotta put it all together. Quote Link to comment
Jester Posted March 7, 2009 Report Share Posted March 7, 2009 No. The by pass is so that water will circulate past the thermostat and back to the lower rad inlet, back into the pump, into and through the motor and back past the thermostat. The thermostat is mounted on the side of the head and without circulation, the engine can get very hot while the water trapped around the thermostat stays cold. That just seems wrong. Lets trap the water so it will get hot, but allow some to pass so it doesn't get too hot. I'm confused. :blink: When did they decide to put in a bypass? Quote Link to comment
jesusno2 Posted March 7, 2009 Report Share Posted March 7, 2009 Man! Here's a tip go buy a little mapp gas or propane torch (handheld type) next time you have to remove steel fasterners from aluminum heat it up first and your bolts will almost always screw right out. Just a tip 8 outta 10 times it works like a charm. Quote Link to comment
