HRH Posted February 13, 2009 Report Share Posted February 13, 2009 So I yanked a set of 280z struts the other day which I'm going to lengthen for 510 inserts while retaining the good hub/brakes. I know most everyone uses the 280zx struts, vented rotor and all that. The regular 280z struts will still work on a 510 right? I know there are a few with different spacing where they bolt to the balljoint. Quote Link to comment
Ultramagnus Posted February 13, 2009 Report Share Posted February 13, 2009 the 280 struts have smaller spring perches than the 510 and will sink in the front tires. they are shorter than stock 510 struts, why lenghten them to stock height? those that use the 280zx struts go coilver setup. Quote Link to comment
HRH Posted February 13, 2009 Author Report Share Posted February 13, 2009 What do you mean sink in the tire? Lengthening to make the same height as 510 strut cartridges and going coilover so the spring perch won't matter. Just wasn't sure if the bottom attachment is the same. Need all the travel I can get for rally. I would use the stock 510 struts, but want the better brake/hub option. Quote Link to comment
Clearalbino Posted February 13, 2009 Report Share Posted February 13, 2009 I think what he trying to stay is that the 280zx struts is a narrower track width in the front. Quote Link to comment
CorAce Posted February 13, 2009 Report Share Posted February 13, 2009 Please correct me if I'm wrong, but by the time you spend the money for the struts, coil over Quote Link to comment
Duke Posted February 13, 2009 Report Share Posted February 13, 2009 From what I have read, the 280z struts will not work on a 510. I'm pretty sure that the bolt spacing for the steering knuckle to the strut bottom is different, so you might be SOL dude. This is the reason that people don't use 240/260/280z struts, cause they don't bolt on like those from a 280zx or 200sx. Again, this is only what I have heard, so I could be totally wrong and they could work, but my money is on that they won't. Quote Link to comment
Lozer Posted February 13, 2009 Report Share Posted February 13, 2009 are there any visual cues to tell the difference between 280zx and 280z struts? Quote Link to comment
Duke Posted February 13, 2009 Report Share Posted February 13, 2009 The zx struts have vented rotors and a sliding single piston caliper. The z rotors are solid and the calipers are dual piston. The zx also has a larger diameter spring. Best way to tell is to look at the car you are pulling them from in the JY though ;). Quote Link to comment
damon Posted February 13, 2009 Report Share Posted February 13, 2009 i know the z struts won't work with the 510 steering arms. I was given a set of bump steer spacers from my brother in law that he had gotten for his 280z and the bolt spacing is wider and the centering hole is smaller. Definitly want the ZX stuff or 200sx. Quote Link to comment
HRH Posted February 13, 2009 Author Report Share Posted February 13, 2009 Damn, that's what I was thinking. The last time I got 280zx struts, but this time it was easier to find the regular z. Oh well. Anyone need an extra set of 280z struts, complete? $40 and they're yours! CorAce: Yes, you end up spending more money, but you gain a larger hub and bearings, as well as additional strenght. Stock 510 tubes are a bit weaker than the 280zx struts, being they were a much lighter car not original intended for high performance. Seeing as I'm going to rally, bigger is better. Quote Link to comment
HRH Posted February 14, 2009 Author Report Share Posted February 14, 2009 Yes, as far as tweaking, the stock 510 housing is much weaker than the 280z/zx housing. The housing is filled by the strut cartridge so is actually stronger when assembled than just an open tube. Many in rally have bent the stock 510 strut assemblies. Strut tubes designed for heavier cars (280zx probably is 2900 pounds?) fare much better. And having a bit bigger bearing is a welcome addition when you're pounding the crap out of something. Of course, eventually there is a weight tradeoff. And the 280zx strut assemblies are a lot heavier than the 510, but well worth the extra weight. Quote Link to comment
thisismatt Posted February 17, 2009 Report Share Posted February 17, 2009 Lengthening struts for 510 inserts? What sense does that make?? Quote Link to comment
HRH Posted February 17, 2009 Author Report Share Posted February 17, 2009 You didn't read it all. Need more suspension travel for rally and already bought Tokico inserts for 510 stock tubes. Hence....:D Quote Link to comment
HRH Posted February 19, 2009 Author Report Share Posted February 19, 2009 (edited) Well, fortunately another ratsun member needed some cashola, so I now have another set of struts, but these are ZX, not just Z. Took some pictures of the differences, just in case anyone should look this up in the future. Didn't realize just how different the two struts were. Check out how much more positive camber the 280z is. Z spacing on ZX strut. ZX is on the left, Z on the right. Edited February 19, 2009 by HRH Quote Link to comment
