jefe de jefes Posted December 29, 2008 Author Report Share Posted December 29, 2008 yea 16x7 205's all corners unfortunately they dont make any other different sizes for a 16" Sounds good. Now once I do the zx coilover mod will I be able to use the stock 510 components such as rotor,caliper,and pads? Or will I have to go with the 280zx gear? Quote Link to comment
Cuts metal like mad Posted December 29, 2008 Report Share Posted December 29, 2008 There are 2 pros to doing the 280ZX struts, they give you 1/2" narrower track as well and the spindle angle gives more positive camber... Why is positive camber a good thing. In this case since it's built into the spindle angle, when mounting wider wheels it allows more back spacing than stock struts. Quote Link to comment
jefe de jefes Posted December 29, 2008 Author Report Share Posted December 29, 2008 Sounds good. Now once I do the zx coilover mod will I be able to use the stock 510 components such as rotor,caliper,and pads?Or will I have to go with the 280zx gear? Reason why I ask this is that my local JY has a half off sale this weekend and I want to make sure I pick up everything I may need. Quote Link to comment
thisismatt Posted December 29, 2008 Report Share Posted December 29, 2008 Reason why I ask this is that my local JY has a half off sale this weekend and I want to make sure I pick up everything I may need.Might as well grab as many sets as you can, then ;) s11 200sx rear disc calipers, or mid 80's maxima rear disc calipers are "popular" rear brake swap options (need custom brackets). B210 brake booster works too. Quote Link to comment
thisismatt Posted December 29, 2008 Report Share Posted December 29, 2008 There are 2 pros to doing the 280ZX struts, they give you 1/2" narrower track as well and the spindle angle gives more positive camber... Why is positive camber a good thing. In this case since it's built into the spindle angle, when mounting wider wheels it allows more back spacing than stock struts.The strut angle is the same as 510 except for possibly some way back early 280zx's. There's one guy that claims to have seen a set, but there's no proof elsewhere that I've ever seen. Quote Link to comment
jefe de jefes Posted December 29, 2008 Author Report Share Posted December 29, 2008 Might as well grab as many sets as you can, then ;) s11 200sx rear disc calipers, or mid 80's maxima rear disc calipers are "popular" rear brake swap options (need custom brackets). B210 brake booster works too. When you say "sets". Is that the strut with rotor,caliper,and brake hardware? Quote Link to comment
Cuts metal like mad Posted December 29, 2008 Report Share Posted December 29, 2008 280zx was only made 79-83... There is no "way back early" cars... I can personally confirm there is most certainly a difference, I've done it twice... And both times my cars were lowered prior to installing, and lowered more after, end result was less camber even with more lowering. Quote Link to comment
thisismatt Posted December 29, 2008 Report Share Posted December 29, 2008 280zx was only made 79-83... There is no "way back early" cars... I can personally confirm there is most certainly a difference, I've done it twice... And both times my cars were lowered prior to installing, and lowered more after, end result was less camber even with more lowering.Yeah, I know, but there are notable differences between the years, and Nissan has also been known to change minute things without telling anyone. http://the510realm.com/phpBB3/viewtopic.php?f=1&t=3525&st=0&sk=t&sd=a&start=60#p70830 Quote Link to comment
bonvo Posted December 29, 2008 Report Share Posted December 29, 2008 Sounds good. Now once I do the zx coilover mod will I be able to use the stock 510 components such as rotor,caliper,and pads?Or will I have to go with the 280zx gear? i dont know why anyone hasent said anything on this yet use the zx brake parts bigger calpers bigger, vented rotors its not just an upgrade for the struts its also a brake upgrade Quote Link to comment
Cuts metal like mad Posted December 29, 2008 Report Share Posted December 29, 2008 I think the main thing is that by finding the positive camber struts it will allow you to run more back space... Too much positive camber can be easily dialed out with plates and/or lower arms Quote Link to comment
oregondime Posted December 29, 2008 Report Share Posted December 29, 2008 i dont know why anyone hasent said anything on this yet use the zx brake parts bigger calpers bigger, vented rotors its not just an upgrade for the struts its also a brake upgrade if i remember right i dont even think the 510 stuff would even fit on a 280zx strut.. nor would u want to keep 10" rotors when u could have 11"! Quote Link to comment
INDY510 Posted December 29, 2008 Report Share Posted December 29, 2008 Yeah,,, you need to get the struts, rotors, calipers, brake master cylinder, and probably more. When you have all that stuff, you will still need coilovers, bump steer spacers, shocks, maybe camber plates, it aint cheap... I was looking at your 4dr on craigslist for months, it only has a L16 with a auto transmission, what is wrong with the stock suspension??? I don't know exactly, but it sounds like the cheapest 280zx strut swap will be close to what you paid for the car, you should save some money for a 280zx 5 speed. Quote Link to comment
jefe de jefes Posted December 29, 2008 Author Report Share Posted December 29, 2008 i dont know why anyone hasent said anything on this yet use the zx brake parts bigger calpers bigger, vented rotors its not just an upgrade for the struts its also a brake upgrade Thanks bro. Quote Link to comment
jefe de jefes Posted December 29, 2008 Author Report Share Posted December 29, 2008 (edited) Yeah,,, you need to get the struts, rotors, calipers, brake master cylinder, and probably more.When you have all that stuff, you will still need coilovers, bump steer spacers, shocks, maybe camber plates, it aint cheap... I was looking at your 4dr on craigslist for months, it only has a L16 with a auto transmission, what is wrong with the stock suspension??? I don't know exactly, but it sounds like the cheapest 280zx strut swap will be close to what you paid for the car, you should save some money for a 280zx 5 speed. There's really nothing wrong with the stock suspension. I just want to be able to run the 16x7's. Yeah, it has the l16 w/auto tranny. I have an extra 5speed(dog leg) and l16 if needed. That automatic tranny has got to go though. Edited December 29, 2008 by jefe de jefes Quote Link to comment
INDY510 Posted December 29, 2008 Report Share Posted December 29, 2008 Dude.... You can fit 16x7 rims with stock struts Quote Link to comment
jefe de jefes Posted December 29, 2008 Author Report Share Posted December 29, 2008 Dude.... You can fit 16x7 rims with stock struts Well damn, screw the strut swap then! 16x7 , but what offset should I look for? +15 or +22? Thanks for the good news. Quote Link to comment
Cuts metal like mad Posted December 29, 2008 Report Share Posted December 29, 2008 +22, if you end up wanting more offset later, you can add a spacer, +15 will be too Much for stock struts (fender clearence). Quote Link to comment
jefe de jefes Posted December 29, 2008 Author Report Share Posted December 29, 2008 +22, if you end up wanting more offset later, you can add a spacer, +15 will be too Much for stock struts (fender clearence). Perfect. I just want my dime to have a low look with the tires tucking. I'm not after performance or handling. I'll be driving it to work not on a track. Thanks for the input guys. I really apreciate it. Quote Link to comment
Cuts metal like mad Posted December 29, 2008 Report Share Posted December 29, 2008 for a daily driver... 15" tires are cheaper! :D Quote Link to comment
jefe de jefes Posted December 29, 2008 Author Report Share Posted December 29, 2008 for a daily driver... 15" tires are cheaper! :D Im not really worried about tire prices but I just received a reply from them and they don't carry a +22 offset wheel in 16x7". They do have them in +15 but then I'll have fender clearance issues right? What can I get away with if I go with 15's? Quote Link to comment
Cuts metal like mad Posted December 29, 2008 Report Share Posted December 29, 2008 (edited) stock struts and rolled fenders, probably as much as +6 to +10, but +12 to +20 would be nominal. 15x7 +0 will stick out about 1/2" to 3/4" in front. Which is not that bad but limits lowering... It will actually look ok... It will rub in the rear without rolling Edited December 29, 2008 by zuum510 Quote Link to comment
jefe de jefes Posted December 29, 2008 Author Report Share Posted December 29, 2008 I don't want the fronts to stick out. I need them to tuck. I'll check and see what they have available in 15". Quote Link to comment
69FJWagon Posted December 29, 2008 Report Share Posted December 29, 2008 (edited) Dude,,, those wheels will never fit a stock fendered 510 This pic is 16x7 Rota rb's with +22mm offset So yeah do some more research,,, because 16x8 wheels will NEVER fit in the front of a non-flared 510, no matter what offset Indy NEVER SAY NEVER :lol: I have 18x8s all the way around on my 2 door FJ car and I am working on 16x8s for race tires at the moment just need to mount up a tire and check for clearance :D here is a pic of the rears Edited December 29, 2008 by 69FJWagon added pics Quote Link to comment
thisismatt Posted December 29, 2008 Report Share Posted December 29, 2008 18's aren't 16's ;) Quote Link to comment
LAYEDOUTB2K Posted December 29, 2008 Report Share Posted December 29, 2008 the whole time reading the begining of this thread i was thinking of my dads 510 and its funny that it got brought up. ill definitely have to ask him what front suspension setup he is running because this is making me very curious now. Quote Link to comment
