?-Question regarding rims for 510
jefe de jefes
From the info I have gathered , The wheels in the following link will only fit a 510(stock fendered) that has 280z struts up front correct?
I'd like to run some 16's on my 4 door. Looks like I have stock struts with cut stock coils.
http://losangeles.craigslist.org/lac/pts/971196784.html
**Info from listing**
Brand New Set of 4!!!
Diameter:15" or 16" (add $20)
Width: 8"
Offset: +0
Bolt Pattern: 4x100 and 4x114.3
Style: Wantanabe Panasport Banana
Color: Black, Gunmetal, Silver, Red
Price: $350/Set of 4 or $550 with Tires!!! (Mounted and Balanced)
(16" will be $370 or $630 with tires)
Edited by jefe de jefes
  • Replies 53
Look for something with an offset of +15 to +20 give or take. Because of the shape of the rear arms it's not easy to say exactly what fits given the changes in diameter and offset of wheels. I can tell you 16x8 +38 will require shaving some off the rear arm, but will otherwise fit. 16x7 +33 will fit on S12 200sx front struts dependent on where the spring perch ends up. Here's a pic of that:
Dude,,, those wheels will never fit a stock fendered 510
This is a pic of 16x8 zero offset wheels, and the tires are about 1mm from the stock 510 struts
This pic is 16x7 Rota rb's with +22mm offset
So yeah do some more research,,, because 16x8 wheels will NEVER fit in the front of a non-flared 510, no matter what offset
That's exactly the look i'm shooting for.
Is that your ride?
"16x7 Rota rb's with +22mm offset" <<-- Is that the same for front and rears?
I'm also guessing that has the 280z front strut swap with coilovers correct?
Thanks for the pics.I somewhat have an idea of the direction I have to take..
Time for some heavy reading. I think I saw a thread by mklotz regarding strut modding.
Well I'm now confused. I have 280 ZX struts with coilovers and 15x7 wheels with +15 offset and they hit the struts. Now someone says that 16x7 with +22 offset fit great. I wonder if there is any difference between 2 doors and wagon strut locations? Thanks.
The bigger the diameter the more clearance you'll have since the strut gets farther away from the wheel the higher up you go.
no way to fit 16x8 huh? Never say never... There's a 510 on here somewhere (too lazy to look for it), it's running 16x8 0et under stock fenders, tucking...
Yup. Look up " layedoutb2k ".
I think it belongs to his Pop's.
That car is what made me decide to pick up a dime.
Yeah,, here's the link.... requires crazy fab skills
http://forum.ratsun.net/showthread.php?t=5525
Hah! You beat me to it.
thanks for the compliment :) those are 205/50 or 45's i dont remember.
lol my friend fit the xxr 002's on.. but he stretched the hell out of them and rolled fenders, and theyre not completely tuckin
Thanks again. Your ride looks like mine, without the wheels of course.
16x7 on all four corners right? Did you roll your fenders?
