Gp620Rat Posted April 30 Author Report Share Posted April 30 Just wanted to show you guys that expressed some interest the L18 project, before I throw it in the classifieds. Quote Link to comment
datzenmike Posted April 30 Report Share Posted April 30 Any Idea what this block came out of??? L20B and L28s adopted that style oil filter boss in '79? The L18 was used elsewhere in the world into the '80s at least. Could this one be other than the '73 610, or the '74 710/620 that we got? Perhaps an import engine?? Could be why I can't identify the N56 block. On 4/12/2024 at 6:17 PM, datzenmike said: N56 I don't know this one. L18s used K25 and A87 blocks? Quote Link to comment
iceman510 Posted April 30 Report Share Posted April 30 1 hour ago, Gp620Rat said: Just wanted to show you guys that expressed some interest the L18 project, before I throw it in the classifieds. I just replied to your pm then saw you posted these here. 😁 PM me a starting price if you will. Quote Link to comment
Gp620Rat Posted April 30 Author Report Share Posted April 30 I’m not sure what car this came out of. It’s the only L18 that I have. (I do have a number of L 16 and L 18 chains and sprockets etc…, that I still need to investigate further. ) But the gentleman that had all of these parts and pieces was certainly an aficionado. It appears that it has never been bored, it has been honed, and all of the internals look pretty sweet. brand new pistons and rings. Quote Link to comment
Gp620Rat Posted April 30 Author Report Share Posted April 30 Question for the group: I have two L20B blocks, both completely disassembled and missing the main bearing caps. I rifled through ALL of the other parts that I have, and only found one complete set of L20B main bearing caps. My plan is to install them (separately, of course ) on both blocks, and measure them on both blocks, and see which one comes closest to a perfect measurement. I know that these main bearing caps came from one of these two blocks, of that I am sure. What do you think? Or do you think it even matters? Was the original manufacturer of these Datsun engines that good, that the caps (not the bearings) would be interchangeable with another L20B? Quote Link to comment
datzenmike Posted April 30 Report Share Posted April 30 I think they install them and line bore them to spec then put the crank and bearings in. I doubt they check the clearances if the crank and the caps were perfect. That set must be from one of the blocks, just keep going till you get the numbers you like 1 Quote Link to comment
banzai510(hainz) Posted April 30 Report Share Posted April 30 (edited) Make sure to get the Good Japanese timing chain kit Dont get a Cloyes or Melling with the 3 holes on the cam sprocket. it hole in wrong spot to see timing marks. Tsubaki kits are the best if found Edited April 30 by banzai510(hainz) 1 Quote Link to comment
Gp620Rat Posted April 30 Author Report Share Posted April 30 Thanks…great info. If I need to buy the kit, that’s exactly what I’ll get. I have an awful lot of this stuff on hand, that came with these engines; and I’m assuming that most of it is stock from Japan. I will be checking it out to make sure that it is still viable and usable and within spec. Quote Link to comment
Stoffregen Motorsports Posted April 30 Report Share Posted April 30 22 hours ago, iceman510 said: Really? Not even manifold port matching? That's what this one looks like it had done. I never ran it as an SCCA IT car, only group 2 in vintage. Really, zero porting. There is "blueprinting" that can be done, but this is limited to valve job (three angle) and surfacing to the low limit. Rocker geometry via thinner lash pads too. Oh, and since the L16 cam was superseded by the L20B cam, it was legal to install one of those as a "replacement part". Liberties have been known to take place in IT or spec class racing. I've seen heads that have been ported then shot peened to look as-cast. 1 Quote Link to comment
iceman510 Posted April 30 Report Share Posted April 30 1 hour ago, Stoffregen Motorsports said: Really, zero porting. There is "blueprinting" that can be done, but this is limited to valve job (three angle) and surfacing to the low limit. Rocker geometry via thinner lash pads too. Oh, and since the L16 cam was superseded by the L20B cam, it was legal to install one of those as a "replacement part". Liberties have been known to take place in IT or spec class racing. I've seen heads that have been ported then shot peened to look as-cast. Thanks for the details. Good to know. I never ran in SCCA as mentioned, so I didn't have to read the rules. 😄 1 Quote Link to comment
Gp620Rat Posted May 18 Author Report Share Posted May 18 Hi guys, I’m trying to use the search function of this website/forum to find the following conversation, that I found a year or two ago. I took a screenshot (a year or two ago). I have the date and very specific words to use in the search function, but I am not having any luck. I will post the photo here, and if you can guide me back to that conversation, I would like to read a little bit of what was written Before, and after the page (the photo) that I am posting. Quote Link to comment
Gp620Rat Posted May 18 Author Report Share Posted May 18 Anyway, while I wait for the response on that 2018 post; I can give you a quick update. I’m moving through the various engines, and the massive number of jumbled parts that I bought, cleaning , mic’ing, checking and making good progress, trying to involve my sons as much as possible, spreading the education. People ask me why I’m bothering with this project, and I told them that some people do crossword puzzles or sudoku, and I am enjoying sorting the parts that I bought, all jumble together, cleaning them, prepping them, and building the engines. I will be testing each one thoroughly in my 620 pick up, before , I sell them, or modify them further . it’s kind of fun, so far so good. more later… Quote Link to comment
datzenmike Posted May 18 Report Share Posted May 18 That's the 510 Realm not Ratsun. https://www.the510realm.com/viewtopic.php?t=30505 Quote Link to comment
Gp620Rat Posted May 18 Author Report Share Posted May 18 Thanks! Saw your name there… thanks for the link. Quote Link to comment
Gp620Rat Posted May 18 Author Report Share Posted May 18 Just read the link that you sent me…all good stuff. Quote Link to comment
datzenmike Posted May 18 Report Share Posted May 18 That's funny asking for a search for Realm material on Ratsun. Quote Link to comment
