jxb003 Posted March 8 Report Share Posted March 8 Anyone have a lead on the bushing that holds the front differential on a 83 4x4? It is also the same bushing as the mustache bar. Part 55476-U7600 I’ve found a couple that seem close in size but not exact matches. Quote Link to comment
datzenmike Posted March 8 Report Share Posted March 8 38930-18W00 is the insulator assembly. This is not just the rubber but the part that holds it as well. This part bolts to the front of the differential. The thing you call the mustache bar is sold as an assembly also with rubbers included. 40 minutes ago, jxb003 said: Part 55476-U7600 I’ve found a couple that seem close in size but not exact matches. I cannot find this Nissan part at all are you sure of the numbers?? See 610 below... The 610 mustache bar rubbers are 55476 U9600 The 510 mustache bar rubbers are 55476-U0100 Quote Link to comment
jxb003 Posted March 8 Author Report Share Posted March 8 I think my part number is correct? Assuming they are original.I’ll do some searching for the entire assembly but just a quick search it shows to be discontinued as well. Quote Link to comment
Stoffregen Motorsports Posted March 8 Report Share Posted March 8 If you can't find OEM or replacement bushings, try doing a google search for energy suspension universal or generic bushing guide pdf. I know it's out there, I just don't have a link. If you find this page, you can search poly bushings by dimension. They also have sleeves listed by dimension. Quote Link to comment
Stoffregen Motorsports Posted March 8 Report Share Posted March 8 Try this. It's not as complete as it could be, but it does havea universal section - https://prothane.com/wp-content/uploads/2020/09/PROTHANE_Catalog-15_9-11-19.pdf Also, page 11 and 12 - https://teamenergysuspension.com/wp-content/uploads/2021/02/2017_August-ES_Catalog.pdf Quote Link to comment
Stoffregen Motorsports Posted March 8 Report Share Posted March 8 (edited) Even this isn't the one I was thinking of, but it has a lot of info - https://www.suspension.com/universal-bushings.asp We should pin this link somewhere on the site. Pretty comprehensive listing. Edited March 8 by Stoffregen Motorsports Quote Link to comment
iceman510 Posted March 8 Report Share Posted March 8 https://parts.nissanusa.com/p/89754852/55476-u7600.html NLA according to Nissan. Quote Link to comment
jxb003 Posted March 8 Author Report Share Posted March 8 21 minutes ago, Stoffregen Motorsports said: Even this isn't the one I was thinking of, but it has a lot of info - https://www.suspension.com/universal-bushings.asp We should pin this link somewhere on the site. Pretty comprehensive listing. This is a good start. I’ll post up dimensions and how close I can get with a universal. 1 Quote Link to comment
datzenmike Posted March 8 Report Share Posted March 8 Another option is to pull them off another 4x4. BTW the 720 transfer case also had bushings. 1 Quote Link to comment
jxb003 Posted March 8 Author Report Share Posted March 8 3 hours ago, datzenmike said: Another option is to pull them off another 4x4. BTW the 720 transfer case also had bushings. Datzenmike. Don’t talk about more bushings. Giving me anxiety. I’m still on the front. A-arms. Differential etc. 1 Quote Link to comment
datzenmike Posted March 9 Report Share Posted March 9 Ahh the tyranny of choice. I was wondering if they would be a close match or substitute. Quote Link to comment
bottomwatcher Posted March 9 Report Share Posted March 9 12 hours ago, jxb003 said: Datzenmike. Don’t talk about more bushings. Giving me anxiety. I’m still on the front. A-arms. Differential etc. Yeah warm up on those before you hit the LCA arm bushings. You will wonder if the truck is worth it after the first one. 1 Quote Link to comment
