CharlieBucket Posted December 18, 2008 Report Share Posted December 18, 2008 my shifter pin fell out of the b210 at some point, i guess the clip broke down. anybody know of something i could rig it up with? i will get a new one but i need to drive it in the morning. i tried a few things but everything is to long and i cant shift into 4th and 5th. Quote Link to comment
Edz280zx Posted December 18, 2008 Report Share Posted December 18, 2008 Bailing wire wrapped a few dozen times thru the hole...sucks dude, I've got like 3 or 4 of them if you were local. Quote Link to comment
ggzilla Posted December 18, 2008 Report Share Posted December 18, 2008 (edited) Just use an 8mm bolt., the pin is just a round item. Some used a threaded end with a nut instead of a circlip. Most likely your plastic bushings are shot, that will make it sloppy even if you have the right size pin. With the wrong size pin it would be a nightmare!! Transmission Gear Control Edited December 18, 2008 by ggzilla Quote Link to comment
Nicholas7620 Posted December 18, 2008 Report Share Posted December 18, 2008 I got a replacement on ebay. Quote Link to comment
CharlieBucket Posted December 18, 2008 Author Report Share Posted December 18, 2008 i have bew brass bushings acually, i think i screw up the clip when i installed them. the tranny has been in and out twice right before i got it so the clip was sretched i think. so 8mm bolt, sounds good, they are like 20 bucks on ebay with shipping. Quote Link to comment
slodat Posted December 18, 2008 Report Share Posted December 18, 2008 Go to your Nissan dealer and order it with the clip. Probably cost you $5. Quote Link to comment
Llittle_Llama Posted December 18, 2008 Report Share Posted December 18, 2008 i didnt know nissan had that part! i am missing mine too, i used a bolt and nut. Quote Link to comment
Edz280zx Posted December 18, 2008 Report Share Posted December 18, 2008 For the record...the wire was just a suggestion for a "temporary" fix....the bolt is much better..lol Quote Link to comment
CharlieBucket Posted December 18, 2008 Author Report Share Posted December 18, 2008 i figured it wouldn't be to hard to get, i just needed it this morning. i got to work! found a bolt that was about right. the shifting to acually to tight now. thanks for the obvious tip, my brain doesn't work to well after working 10 hours and then coming home to kaos.wife, 2 kids, female roomate with a 1 kid. all 3 and under! Quote Link to comment
datzenmike Posted December 18, 2008 Report Share Posted December 18, 2008 This is another 'item' we all should slip into our pocket when at the yards. The pin from any car or truck up to about '86 should work. Quote Link to comment
hang_510 Posted December 18, 2008 Report Share Posted December 18, 2008 This is another 'item' we all should slip into our pocket when at the yards. The pin from any car or truck up to about '86 should work. yup! def a good item for the tool box. paper clips(bailing wire) have served their purpose too ;) Quote Link to comment
