kcobb454 Posted January 23, 2024 Report Share Posted January 23, 2024 Hi Im looking for a supplier of vinyl flooring for my PL521. Anyone know if there is a place to get one? Quote Link to comment
MikeRL411 Posted January 24, 2024 Report Share Posted January 24, 2024 Have you considered spray on bed liner? Quote Link to comment
kcobb454 Posted January 24, 2024 Author Report Share Posted January 24, 2024 Yeah not a big fan for inside cab. I want to put dynamat type product down first, then vinyl. will do carpet if I have to but really want it to be more of a truck, not a car lol. we live rural and we actually use our truck around our place and it rains a lot in Washington lol, so carpet will be a last resort. Quote Link to comment
yenpit Posted March 25, 2024 Report Share Posted March 25, 2024 Late reply, but most of the Datsun rubber floor coverings (not individual mats) are moulded, to contour up & over the trans tunnel. All of them are long discontinued & I'm not aware of any reproductions. I have a 77k low mile 1980 720 rubber floor covering, that I am going to fit to my 1972 521. I did lay it in & it is a tad bigger, so a little trimming & it should fit fine. That tells me that the 620 might fight as well in the 521. If you are on Facebook, look up Issaranawat TreeAusawa. He is in Thailand & makes many of the Datsun door panels, using a similar (if not the same) "heat seam" process as Datsun did. That said, he is a HUGE 620 guy & I THINK I might have seen a post last year, that he can make the 620 rubber floor covering, with the DATSUN logo & ribs.................?? Maybe he can make one a tad larger outer circumference, so you have a little extra material to work with & trim to better fit the 521.......?? As long as you "anchor" the covering, it should stay in place, not move around on you........... If you do this, please post your results, so we know! Quote Link to comment
datzenmike Posted March 25, 2024 Report Share Posted March 25, 2024 TJ, trace out the 720 cover and save it. I fit a 720 mat in my 620 and it was a few inches wide at the doors, so it would work on 620s also. Could be used for carpet as well. 1 Quote Link to comment
Stoffregen Motorsports Posted March 28, 2024 Report Share Posted March 28, 2024 I have used restaurant floor mats which I cut to shape. You can buy them in different thickness and style in rolls. Amazon sells them. 1 Quote Link to comment
yenpit Posted April 9, 2024 Report Share Posted April 9, 2024 On 3/25/2024 at 12:41 PM, datzenmike said: TJ, trace out the 720 cover and save it. I fit a 720 mat in my 620 and it was a few inches wide at the doors, so it would work on 620s also. Could be used for carpet as well. Yes, same for the 521...........few inches wider at the sides/doors! Problem with tracing, is the trans tunnel is moulded, so it does not sit flat when laid out............. I got a NEW carpet kit in the box, for the 521, but I think I want the rubber mat, cuz it will be more of a work truck/hauler, being a flat bed! 1 Quote Link to comment
kcobb454 Posted June 3, 2024 Author Report Share Posted June 3, 2024 Ok I have givin up on the Vinyl quest, I am looking for the best fitting carpet now. any input on the preferred kit out there? Thank you for the input! Quote Link to comment
pidge Posted June 3, 2024 Report Share Posted June 3, 2024 Guy on eBay sells kits. I think it’s a seven piece not including the mats. I’m in the process of doing mine now. I think the fella is from Utah if memory serves me right. Quote Link to comment
EDM620 Posted November 14, 2024 Report Share Posted November 14, 2024 any update on the carpet kit? FWIW, I read somewhere that roofing sheet rolls work for sound deadener (cheaper than dynamat) and can easily be moulded to fit contours by applying a bit of heat. Could solve your need for vinyl flooring. I'm currently fitting some of the thinner roof roll (leading edge/drip guard) to my firewall and inside the doors due to it being easier to work with, plus I got some of the thicker stuff to lay on my floors for under the carpet. The thinner stuff I got has a fibrous paper backing Price is right = free. Roofers typically throw away any excess material. Quote Link to comment
Crashtd420 Posted November 14, 2024 Report Share Posted November 14, 2024 1 hour ago, EDM620 said: any update on the carpet kit? FWIW, I read somewhere that roofing sheet rolls work for sound deadener (cheaper than dynamat) and can easily be moulded to fit contours by applying a bit of heat. Could solve your need for vinyl flooring. I'm currently fitting some of the thinner roof roll (leading edge/drip guard) to my firewall and inside the doors due to it being easier to work with, plus I got some of the thicker stuff to lay on my floors for under the carpet. The thinner stuff I got has a fibrous paper backing Price is right = free. Roofers typically throw away any excess material. It does work, I used in my 521 for the same reason, leftover and free.. only thing is it stinks for a little while, atleast mine did... Quote Link to comment
datzenmike Posted November 14, 2024 Report Share Posted November 14, 2024 Probably me for my goon, covered ever sq. in. of the floor, under the back seat and cargo and more, this is what I did. Cuts with tin snips, dry not sticky, you can 'weld' together with heat gun or torch. Do inside in the winter or in summer when warm and it's limp enough to take any shape. I've pulled roll ends out of dumpsters because roofers don't like joints or seams. A skid of the stuff was left on a work site for months after the roof was done. When the kid came to take it away I asked for the part roll left. He said take all I want... less for him to lift. The stuff is great but no one seemed interested. They would rather pay $200-300 for DynoMat. 1 Quote Link to comment
