DARIN 510 Posted March 15 Author Report Share Posted March 15 4 hours ago, Rustbin said: This hinge thing had been nagging in the back of my mind so I unburied the four door, pulled back the tarp and found the hinges still attached. Half a day and plenty of WD 40 later I was able to extend them up and they did not bind like Darin's 69. Much searching in the bins where I stored the parts off the '72 reveled the hinges from the 71 and 1 1/2 from the 72. I found that 4 of them had the same arch and 2 were different, even from each other. I'm sure the ones from the 69 are original, they have smaller holes for the hood bolts and an elongated hole where it mounts to the body, but the arch is a little different between them. I was wondering if there was a change where the hood hinges mount during the 69 model year? My car was made in 5 / 69 and if Darin's was made earlier maybe his has the mounting points the same as 68 on the body. It looks to me like Datsun had some variation in production of the hinges. Hainz, I had seen hinges listed on Futofabs website but they are on backorder. My search brought up two results but I have no idea if they are any good to you. I will be refurbishing mine, maybe I should post here on how it goes. https://www.zeddsaver.com/products/datsun-510-hood-hinges https://zcardepot.com/products/hood-bonnet-hinge-510-69-73# Unfortunately, I do not have the Vin sticker like you do. Mine is missing because someone had repainted the car at one point. however, my white 510 is made an 11/69, which makes it a 1970. and those hinges are different. they have the smaller arches like all the others. So my assumption is those hinges that are aftermarket are 1970 to 1973 only. From what DatsunMike said, based off of my VIN number from my 69 he assumes that it should be made between April to May based on the number. Quote Link to comment
banzai510(hainz) Posted March 15 Report Share Posted March 15 I think I have spare hinges from a 71/72 but I dont know where they at. But thanks for the links. I thought it was Futofab. Zcarparts is a nice 1 stop shop. Quote Link to comment
iceman510 Posted March 15 Report Share Posted March 15 11 hours ago, Rustbin said: Hainz, I had seen hinges listed on Futofabs website but they are on backorder. My search brought up two results but I have no idea if they are any good to you. I will be refurbishing mine, maybe I should post here on how it goes. https://www.zeddsaver.com/products/datsun-510-hood-hinges https://zcardepot.com/products/hood-bonnet-hinge-510-69-73# It's interesting that the Zedsaver look to be original parts refurbished and replated. I wonder if they pay any attention to the differences. There is no suggestion of different years being available. ZCarDepot parts are most likely the same as Futofab or anyone else sells. I can't imagine there are multiple vendors out there making these. Quote Link to comment
DARIN 510 Posted March 16 Author Report Share Posted March 16 On 3/11/2024 at 7:55 AM, iceman510 said: So how does the aftermarket compare to that one? Seems from looking at the photos it would be the worst of the 3 for small arch. Look at the first pics I posted. The white ones. Quote Link to comment
