Datsun SU Carburetors
RLJ
  • Replies 8
Thanks Matt,
Don’t think Marvel Mystery Oil was the factory recommended fluid. Have read where it is commonly used by people though.
Just read in an L24 factory engine service manual that 20 weight motor oil was used. Noted that never use 30 weight. Wonder if it was the same recommendation for SSS engines.
The dampening oil viscosity is one of the tuning tools for the SU carburetors. It can range from no oil to most any viscosity oil.
The dashpot dampers in the SUs on our race car are cut out completely. No springs either.
Street engines and mild stock class racing engines respond well to the thinner Marvel Mystery Oil. Though some filing of the needles may also need to be done to get the optimal tune.
Power steering fluid is pretty much ATF.  I used ATF with some 20 weight fork oil mixed.
Started with nothing, way to lean. Went to Marvel Mystery Oil, better but still to lean. Went to ATF, better still but still a little hesitation of idle. Mixed some 20 weight fork oil and throttle response and drivability is good.
Observations. The more modified the engine is with longer duration cam and less manifold vacuum at idle, the thinner the fluid all the way to no fluid.
The more stock the engine with higher manifold vacuum at idle,  the thicker the fluid.
