serum114 Posted July 11, 2023 Report Posted July 11, 2023 Does anyone know what was bolted to this dipstick tube from the factory? It came off of an L20b. Thank you! Quote
banzai510(hainz) Posted July 11, 2023 Report Posted July 11, 2023 the water line clamp I believe 1 Quote
Stoffregen Motorsports Posted July 11, 2023 Report Posted July 11, 2023 12 minutes ago, banzai510(hainz) said: the water line clamp I believe For the win! Quote
serum114 Posted July 11, 2023 Author Report Posted July 11, 2023 Do you guys know if 510s had the same clamp? Or just l20b? Quote
Stoffregen Motorsports Posted July 11, 2023 Report Posted July 11, 2023 I believe the early 510s did not have that tab. Quote
banzai510(hainz) Posted July 11, 2023 Report Posted July 11, 2023 (edited) 15 minutes ago, serum114 said: Or just l20b? Does it matter?????????? if anything you would want it if you have the hose clamp part I think my 521 has it also Edited July 11, 2023 by banzai510(hainz) Quote
serum114 Posted July 11, 2023 Author Report Posted July 11, 2023 I do want it !!! 🤗 I was trying to figure out which vehicles had that clamp so I can find one. Thanks again Hainz! Quote
datzenmike Posted July 11, 2023 Report Posted July 11, 2023 Return line heater hose. The clamp to the dip stick for the 510 is 27041-73000. Any L series with a heater will have this. Quote
Crashtd420 Posted July 11, 2023 Report Posted July 11, 2023 I was expecting more.... Looks like a generic clamp.... Quote
datzenmike Posted July 11, 2023 Report Posted July 11, 2023 The proper dip stick has a welded on threaded 'thing' on it. The 'clamp' is just an open metal loop with two holes and a small Philips head bolt. Quote
banzai510(hainz) Posted July 12, 2023 Report Posted July 12, 2023 as mnike said its just a clamp with a hole in it. a good hardware store will have them cheap and maybe even plastic ones. I beleive you can still get brand new dipstick tubes some were if you wanted a new one Quote
Stoffregen Motorsports Posted July 12, 2023 Report Posted July 12, 2023 The proper bracket will have a radiused edge so it doesn't chafe or cut into the hose. They are all over the interweb for dual hose applications, but find one for a single hose... Quote
