Stinky Posted July 7, 2023 Report Share Posted July 7, 2023 Has anybody had any luck finding a plug for the Alternator on an '86 720? My Charge light was flashing. I figured that it was the Alternator, or at least it needed to be tested. I started digging and I learned that the plug was messed up. I looked it up on Rockauto, and it showed it being a Dorman 85125 (Which I got at Oreilly). Checking on the Napa website, it crossed over to a Eclin EC69 (a good PN). I went to Napa....it is larger. The PN showes that it is for a Ford Alternator. I bought it, and it would not fit. The Oreilly part (Dorman) was cheaper. So, I cut it in half and started in on it w/my grinder. I tirmmed it down to the size of the original plug. Once I got it thin enough to fit the slot, the 2 pieces plugged in....nice and tight BTW. I consider this to be a temporary fix. Anybody got any leads on an Alternator Lead (pun intended)? Quote Link to comment
datzenmike Posted July 7, 2023 Report Share Posted July 7, 2023 The very last 720s I think changed the two wire plug on the alternator to the same as used in the later D21 Hardbody. Quote Link to comment
Stinky Posted July 8, 2023 Author Report Share Posted July 8, 2023 I wonder if they did that when they went to FI on the 720s? I have a plug like in the link, w/about 6" of wire, and then in to a plug sorta like that, https://www.autozone.com/power-tools/electrical-socket?filterByKeyWord=85125&fromString=search&isIgnoreVehicle=false&isSearchByPartNumber=true I just looked up my alternator....it looks like it is supposed to have a plug like you are talking about, but I seem to have an alternator for an older PU https://www.rockauto.com/en/moreinfo.php?pk=3373620&cc=1210295&pt=2412&jsn=912 Quote Link to comment
thisismatt Posted July 8, 2023 Report Share Posted July 8, 2023 The T plug on the older alts doesn't utilize any kind of clip or weather proofing, so two spade terminals is just as good, other than the ability to mix them up. Quote Link to comment
Stoffregen Motorsports Posted July 8, 2023 Report Share Posted July 8, 2023 Plug for the alternator? Is it leaking? They are called connectors. Best results will come from Rockauto, so if you're not finding it there, you may have to hit up a few wrecking yards. Quote Link to comment
datzenmike Posted July 8, 2023 Report Share Posted July 8, 2023 I converted my 710's 50 amp to a much late 2002 Altima 100 amp alternator. Rather than cut the original harness I made this... I drove it for several years with the wires reversed and only noticed it when I installed a volt gauge. Switched them and no harm done. 1 Quote Link to comment
Stoffregen Motorsports Posted July 9, 2023 Report Share Posted July 9, 2023 I just searched for "1986 nissan 720 alternator pigtail" and found a bunch of results. Quote Link to comment
datzenmike Posted July 9, 2023 Report Share Posted July 9, 2023 On 7/8/2023 at 8:57 AM, datzenmike said: I drove it for several years with the wires reversed and only noticed it when I installed a volt gauge. Switched them and no harm done. When the battery voltage dropped far enough the alternator would just start charging. Never noticed this for years, never failed or struggled to start though. I was driving at night through western Wash. and the lights grew dimmer and dimmer and I was getting worried so I honked the horn to give me some indication of battery strength and the lights dimmed and then shot up to full brilliance and it was charging. The 720 volt gauge was definitely below 12v but jumped up into the charge range. When I got home I solved the problem, the two wires were reversed. Quote Link to comment
Thomas Perkins Posted July 11, 2023 Report Share Posted July 11, 2023 Usually the Auto part 50 amp Alternators come with the pig tail and the 60 amp does not.I replaced mine last year and I am using a 60 amp alternator and it does not have a pig tail.My original pig tail fits in it.So the 50 and 60 amp has different fittings on some,depends where you go,I guess..Here is my 60 amp Alternator.I have a extra fitting.I have one right here that is like new.I had my 720 for over 29 years and when I first bought it back then.The first alternator I put on it was from Auto Zone,and it came with a life time warranty.So I never ever had to buy another.I was using the 50 amp one's and had electrical problems and finally realized it was because I need a 60 amp one.And the problem went away.I remember one time,My alternator went bad,it was the 50 amp type.I took the pig tail off and kept it.So the 50 and 60 amp alternators fittings are different and the 60 amp one is bigger.People say the Auto Zone alternators are junk,but that is the first one I put on my 720 and stayed with it because of the warranty. 1 Quote Link to comment
Thomas Perkins Posted July 13, 2023 Report Share Posted July 13, 2023 Does anyone need this plug.I dont. Quote Link to comment
Stinky Posted July 25, 2023 Author Report Share Posted July 25, 2023 Thomas and Datzen. I finally got it going. I was thinking about that plug, and now I can't use it. Datzen, just before you posted, I figured out that I did not have a Charge-Light when the motor was not running, like when you first turn the key to on. It charged, I think. The battery did not go dead and the lights did not get dim when driven w/the lights on. So, after being out of town for a week, I finally got around to it. I cut the plug and re-attached the plug, w/the wires crossed. Originally, the red-orange went together, black and white together. That was wrong. It is now set up up Red-White, B;lack-Orange, I think. I coulda trimmed the plugs some more and get them to plug in. The way the plugs fit the alternator, it was easier to do that. The plugs plugged in securely, w/no wobble, so I went dat way. Quote Link to comment
