That Ol 720 Posted May 16, 2023 Report Share Posted May 16, 2023 Old Z24 engine just went out and so im looking to get a remanufactured engine with 0 miles to buy for an engine swap over the summer. I've been looking for about a week, but a lot of them have bad reviews. Just curious if you guys have any insight to any quality engine rebuilders for the z24. I tried Jegs and ATK but they weren't able to rebuild my engine for 5 months due to a parts shortage. Don't really know if thats a nation wide shortage or whatever it is, but i did try them. Thanks bros Quote Link to comment
Stoffregen Motorsports Posted May 16, 2023 Report Share Posted May 16, 2023 (edited) Try your local machine shop. In my opinion, there's no such thing as a quality remanufactured engine. Edited May 16, 2023 by Stoffregen Motorsports Quote Link to comment
datzenmike Posted May 16, 2023 Report Share Posted May 16, 2023 Guy on here Thomas Perkins has a Jasper remanufactured engine. He seems to like them. 1 Quote Link to comment
720_Jeff Posted May 16, 2023 Report Share Posted May 16, 2023 As said, at least one of us enjoys Jaspers. Looks like, one has to do it through a shop/installer. There is a pricing tool, they may no longer do z24's or z20's, or at least keep a rebuildable core around. https://www.jasperengines.com/find-an-installer I'd say, probably have to call them to see what they will do for you on a z24 800-827-7455 Quote Link to comment
bottomwatcher Posted May 16, 2023 Report Share Posted May 16, 2023 So what "went out"? Quote Link to comment
Thomas Perkins Posted May 16, 2023 Report Share Posted May 16, 2023 (edited) 8 hours ago, datzenmike said: Guy on here Thomas Perkins has a Jasper remanufactured engine. He seems to like them. Jasper no longer sells 720 engines.I called a few weeks back and they said they no.longer remanufacture them.They are good though. I have 102,000 miles on mine and my wife has a 2004 Lincoln LS with a remanufacture transmission from them.I would stay away from Auto Zone ,Advance and Orielly's.The Jasper installer that put mine in wife's has cancer and he no longer is mechanicing, he is taking care of his wife.He also put my new heating and air in.I would ask him about where to get a engine.I could drive by there.His phone is not taking calls.He worked on my 720 for over 20 years.He is renting his building out to someone that is painting vehicles. Edited May 16, 2023 by Thomas Perkins Quote Link to comment
Thomas Perkins Posted May 18, 2023 Report Share Posted May 18, 2023 Back in 2009 is when I had my Jasper 2.4 engine installed.The engine was 1900 and labor and parts were 1200.It is a 4x4.The clutch needed replacing and he put one from Napa in it with no labor charge.He put new castoil motor oil with new Wik filter , new thermostat, new coolant,new ngk spark plugs.new exhaust and intake studs, new intake and exhaust gaskets.New oil pan gaskets,new oil pump gaskets.New head gaskets ,send head to machine shop.pressure test and valves adjusted.new water hoses ,new belts.New down pipe gasket.New distributor cap and rotor, new coils. 1 Quote Link to comment
That Ol 720 Posted May 21, 2023 Author Report Share Posted May 21, 2023 On 5/16/2023 at 4:13 AM, bottomwatcher said: So what "went out"? cracked block 💀 Quote Link to comment
datzenmike Posted May 21, 2023 Report Share Posted May 21, 2023 Ahhh forgot to check the antifreeze. Quote Link to comment
Stoffregen Motorsports Posted May 21, 2023 Report Share Posted May 21, 2023 Bummer. It is possible to repair the crack, depending on where it is. I've repaired the crack around the middle head bolt hole a few different times. Quote Link to comment
datzenmike Posted May 21, 2023 Report Share Posted May 21, 2023 If you look hard enough a lot of engines have small cracks between bead bolts and water jacket. A lot more are out there and they work just fine till taken apart and the owner freaks. It can't get out, the hole is blind, there's a head gasket seal to the head and the tops of the bolts have a washer and torqued to 60 ft lbs. Here's a solution that is too simple. Weld it up... ... and have it decked... 1 Quote Link to comment
Stoffregen Motorsports Posted May 22, 2023 Report Share Posted May 22, 2023 Those welds would certainly crack again. Cast iron needs to be preheated, stick welded, peened, post heated, peened again, then possibly even welded again and post heated, then peened. Yes, I've done wire feed on cast iron but only been lucky with the few successes. Quote Link to comment
datzenmike Posted May 22, 2023 Report Share Posted May 22, 2023 Some day maybe but the way I look at it this wasn't broken off it was stressed and cracked from thousands of heat cycles. The crack is a stress reliever so no reason to crack again. ... and not mine so very confident it fine. 1 Quote Link to comment
720_Jeff Posted May 25, 2023 Report Share Posted May 25, 2023 Just saw this one https://shop.advanceautoparts.com/p/spartan-engine-long-block-nissan-z24-carb-engine-324a/20705808-P Quote Link to comment
Stoffregen Motorsports Posted May 25, 2023 Report Share Posted May 25, 2023 BBB info shows Spartan Engines in Texas, and when you google the address, ATK comes up. Made in TX? Or shipped over the border and rebuilt in Mexico? Not necessarily a bad thing, but does raise some questions. Quote Link to comment
bottomwatcher Posted May 26, 2023 Report Share Posted May 26, 2023 Yeah i guess a cracked block would not count as a rebuild able core. I bought one of those "used Japanese engines" in the late 90s. It was a z 24 for like $500. Ran it for 20 years, good motor and was running strong when I pulled it for the KA swap. No hits on craigslist so I took it to the scrapyard. I bought another used Japanese engine 3 years ago for the wife's 2007 rav 4. Her engine siezed because it sat for 6 months without being started. It was the only car we have had this happen to and the only car with synthetic oil. I don't think synthetic prevents rust like conventional oil. Quote Link to comment
datzenmike Posted May 26, 2023 Report Share Posted May 26, 2023 It wouldn't have seized just from sitting 6 months or even years. It may have had a leaking HG and water got into a cylinder(s). Why did you park it in the first place? Was it running weird? Quote Link to comment
bottomwatcher Posted May 26, 2023 Report Share Posted May 26, 2023 The car lives under a stilt home for the summer on a saltwater canal in Florida. The humidity is off the charts and high winds will carry salt in the air from wave action. Cylinders were rusted. Car hadn't been started in 6 months. The other vehicles were fine but that is the only one I run synthetic in. That's my theory and I am sticking to it. I have a buddy starting the cars every 3 weeks now. Quote Link to comment
datzenmike Posted May 26, 2023 Report Share Posted May 26, 2023 By that reasoning every car in Florida under similar conditions would have this problem. 1 Quote Link to comment
Thomas Perkins Posted May 27, 2023 Report Share Posted May 27, 2023 (edited) I have a Jasper engine.Got it back in 2009.I called a few weeks ago for someone here and they said they don't do them Nissan 2.4's any more.But you would have to have a Jasper installer do it back then.But it came with a Nation wide 3 year or 100,000 mile warranty,what ever came first.I now have 103,000 on it.Still like new.My wife had Jack install a Jasper transmission in her 2004 Lincoln LS about 3 years ago and it is still like new.It was well worth going Jasper cause it was done right.That is why my 720 is top notch cause Jack has done the major work on it.He even upgraded my heating and air.I just work more hours to pay for it.A good thing about Jasper is,if anything goes wrong with it under warranty,They replace the engine or transmission with no charge.Jack told me Jasper pays the best in case he has to replace it if something is wrong.All the auto part stores don't pay shit so he won't install them.Plus you only get a 90 day warranty from Auto Part stores.Stay away from Auto Zone,O'Reilly's and Advance.With the bad crack you have.Junk it and find a remanufactured engine.No shop will touch that.See the mileage on my Jasper paper work.I now have 386,000 on it.Here it is.See the black paint around the front by the radiator and by the front fenders..The paint shop did that when they painted the truck.Check out my plastic radiator.Lifetime warranty.Been using that type for 29 years.Bought the first one many moons ago and never have to buy another.The last one lasted 12 years.When they go out,I take the water pump off too and go get a free one. Edited May 27, 2023 by Thomas Perkins 1 Quote Link to comment
bottomwatcher Posted May 28, 2023 Report Share Posted May 28, 2023 On 5/26/2023 at 9:26 AM, datzenmike said: By that reasoning every car in Florida under similar conditions would have this problem. Some do. Lots of screaming deals in Florida on cars with siezed brakes, dead electronics and other issues for sale on Craigslist in the fall when people return from up north. 1 Quote Link to comment
Thomas Perkins Posted May 31, 2023 Report Share Posted May 31, 2023 You can get the hurricane cars but probably no title.In Alabama when they have floods,them vehicles are for sell everywhere.A friend got one but no title,the bottom was red clay everywhere.The car lots that sell to people with bad credit have them cars,knowing you will never get it paid for and they have no title. 1 Quote Link to comment
Stoffregen Motorsports Posted May 31, 2023 Report Share Posted May 31, 2023 1 hour ago, Thomas Perkins said: You can get the hurricane cars but probably no title.In Alabama when they have floods,them vehicles are for sell everywhere.A friend got one but no title,the bottom was red clay everywhere.The car lots that sell to people with bad credit have them cars,knowing you will never get it paid for and they have no title. Shady. 1 Quote Link to comment
Thomas Perkins Posted May 31, 2023 Report Share Posted May 31, 2023 Most calls on my house phone is scammers,most wanting to sell insurance.I don't get none on my cell phone.My home phone announces who is calling.You have shady everywhere.Just like people wanting to hold signs up but don't want to work. 1 Quote Link to comment
