thisismatt Posted February 12, 2023 Report Share Posted February 12, 2023 I spy with my little eye...H233 lsd for cheap https://www.facebook.com/marketplace/item/1214491892490812 Quote Link to comment
datzenmike Posted February 12, 2023 Report Share Posted February 12, 2023 There were no WD21 Pathfinders till '87. Drum brake through '88 so that narrows this down. Quote Link to comment
thisismatt Posted February 12, 2023 Report Share Posted February 12, 2023 1 hour ago, datzenmike said: There were no WD21 Pathfinders till '87. Drum brake through '88 so that narrows this down. Yeah, year liated is incorrect, but... Quote Link to comment
Stoffregen Motorsports Posted February 12, 2023 Report Share Posted February 12, 2023 The sway bar on that axle might be worth retro-fitting onto any truck. I wonder if it would fit between the leaf springs of a 620/720. Quote Link to comment
Wildcat Walker Posted February 18, 2023 Report Share Posted February 18, 2023 2 Quote Link to comment
datzenmike Posted February 18, 2023 Report Share Posted February 18, 2023 Look like S30 calipers, almost like Girling? 1 Quote Link to comment
Wildcat Walker Posted February 24, 2023 Report Share Posted February 24, 2023 2 Quote Link to comment
datzenmike Posted February 24, 2023 Report Share Posted February 24, 2023 Top ? Bottom Z32 calipers? Quote Link to comment
Wildcat Walker Posted July 23, 2023 Report Share Posted July 23, 2023 (edited) I finally met a major milestone in the H233 narrowing project. As far as I know, this is the worlds first narrowed H233B LSD differential. The amount of work and money required to execute this project has been ridiculous. After Moser ruined my 29 spline pathfinder axles, I pulled a 31 spline Xterra axle from the yard as a replacement. Dutchman did the axle splines and I did the housing. The Xterra unit was narrowed by almost 10 inches to suit my 620. I combined the best parts (frictions) from pathfinder and Xterra units for the LSD clutch pack. The 29 and 31 spline side gears interchange, and everything else in the 3rd member is identical. Edited July 24, 2023 by Wildcat Walker 3 Quote Link to comment
thisismatt Posted July 23, 2023 Report Share Posted July 23, 2023 Nice work. I didn't see - is there a rotor hat parking brake or ? Quote Link to comment
Wildcat Walker Posted July 23, 2023 Report Share Posted July 23, 2023 No parking brake on the axle. I may use hydraulic parking brake later on. Will be running z32 calipers on this. Quote Link to comment
datzenmike Posted July 24, 2023 Report Share Posted July 24, 2023 Z32? That's stopping power you'll never need. The fronts do all the work, specially with weight shift off the rears onto the front tires. Quote Link to comment
thisismatt Posted July 24, 2023 Report Share Posted July 24, 2023 7 minutes ago, datzenmike said: Z32? That's stopping power you'll never need. The fronts do all the work, specially with weight shift off the rears onto the front tires. Look like rears, so... Quote Link to comment
datzenmike Posted July 24, 2023 Report Share Posted July 24, 2023 Rears would be better. They just look huge. Quote Link to comment
thisismatt Posted July 24, 2023 Report Share Posted July 24, 2023 On 2/17/2023 at 8:35 PM, Wildcat Walker said: On 2/18/2023 at 9:05 AM, Wildcat Walker said: These are the rears, Mike Quote Link to comment
datzenmike Posted July 24, 2023 Report Share Posted July 24, 2023 That looks better. Quote Link to comment
Wildcat Walker Posted July 24, 2023 Report Share Posted July 24, 2023 (edited) Mike, I will be running Z32 rear calipers on this axle and Z32 front calipers in the front. I will proportion the rear to prevent lock up and provide the proper bias. This isn't a stock 620, "extra" braking is definitely needed. The images of the rear setup Matt shared will be slightly different. When I changed from the pathfinder to the Xterra axle, the axle bearings also changed from a single tapered roller to a double, making the housing deeper. So I will have an offset of the brake bracket instead of a flat bracket. Caliper and rotor remains the same. Note: I retained the factory sway bar mounts on the H233B housing, should come in handy for a rear sway bar for the 620. Edited July 24, 2023 by Wildcat Walker Quote Link to comment
Wildcat Walker Posted July 24, 2023 Report Share Posted July 24, 2023 (edited) Packing clutch with optimum order of plates and utilizing thickest plates. And some images of the damage done by Moser Engineering. I explained to them the scope of work in great detail, and I left a copy of the FSM for both the axle and differential at the shop. Lesson learned. Dutchman is the way to go for splining existing axles. Moser on top, Dutchman on bottom. Edited July 24, 2023 by Wildcat Walker 1 1 Quote Link to comment
Wildcat Walker Posted July 24, 2023 Report Share Posted July 24, 2023 Alignment pucks I designed for the Pathfinder and Xterra versions of the H233B. The bar is 1.375" TGP, very rigid. It was the largest diameter bar I could fit through the axle ends. 1 Quote Link to comment
Wildcat Walker Posted July 24, 2023 Report Share Posted July 24, 2023 29 spline axle in a 31 spline side gear for comparison. 1 Quote Link to comment
Wildcat Walker Posted March 10 Report Share Posted March 10 (edited) Narrowing another H233B for a KA24DE swapped 720. Pulled a 3.7 gearset from the yard. I definitely prefer the Xterra units due to the dual tapered roller bearing design ( no shimming) and larger axles, but the D21 and WD21 units are more common in our yards. Only $150 invested up to this point. We may run a caliper with internal parking brake on this one. Edited March 10 by Wildcat Walker 3 1 Quote Link to comment
Wildcat Walker Posted March 10 Report Share Posted March 10 Its amazing how it's cheaper to order OEM Pinion bearings from Japan through Amayama than it is to buy the same thing here in the USA. Nothing but greed to blame. 327% more expensive to line an Americans pocket. I love Japan. 1 Quote Link to comment
