zeke5551 Posted October 7, 2022 Report Share Posted October 7, 2022 Has anyone successfully installed a Rack and pinion steering on a 320? Quote Link to comment
thisismatt Posted October 7, 2022 Report Share Posted October 7, 2022 @Stoffregen Motorsportsperhaps? 1 Quote Link to comment
Stoffregen Motorsports Posted October 7, 2022 Report Share Posted October 7, 2022 Nope, but I'd love to. Bring it by and I'll do it! Quote Link to comment
difrangia Posted October 7, 2022 Report Share Posted October 7, 2022 5 hours ago, Stoffregen Motorsports said: Nope, but I'd love to. Bring it by and I'll do it! You know the old saying; "Watch what you wish for" ; Bring the brown paper bag with $$ and a contact #. Matt will make it happen. 1 Quote Link to comment
zeke5551 Posted October 7, 2022 Author Report Share Posted October 7, 2022 I do a lot of fabricating myself, so I would most likely do the work in my shop. I was concerned about finding a narrow enough rack to keep the geometry proper. Maybe in the aftermarket community I can find something 1 Quote Link to comment
zeke5551 Posted October 7, 2022 Author Report Share Posted October 7, 2022 The stock steering box is right where the alternator mounts on the TDI Jetta engine that's going in Quote Link to comment
thisismatt Posted October 7, 2022 Report Share Posted October 7, 2022 Look into center take-off racks. Instead of tie rods connecting to the ends of the rack like usual, they have a bar across where you can establish your own pivot points. 2 Quote Link to comment
Stoffregen Motorsports Posted October 9, 2022 Report Share Posted October 9, 2022 (edited) Installing a steering box from a 720 and modifying your column to use an exposed shaft will give you some extra room. You can also convert the idler arm to 720 style for added clearance on the passenger side of the frame. I have a build thread here - - showing a 720 balljoint conversion on a 320. There are pics of the column mods to better explain what I'm talking about. Here are some pics. Edited October 9, 2022 by Stoffregen Motorsports Quote Link to comment
Stoffregen Motorsports Posted October 9, 2022 Report Share Posted October 9, 2022 (edited) More pics. Edited October 9, 2022 by Stoffregen Motorsports Quote Link to comment
zeke5551 Posted October 13, 2022 Author Report Share Posted October 13, 2022 Great info, I got lots to figure out. I was just noticing the rack on my MGB is pretty narrow, might work Quote Link to comment
Stoffregen Motorsports Posted October 13, 2022 Report Share Posted October 13, 2022 A Sprite rack is probably even narrower. Quote Link to comment
Icehouse Posted October 13, 2022 Report Share Posted October 13, 2022 Rack width isn't that crucial, placement is. Rack placement chances bump and ackerman. Placement can also cancel out the bump. Being front steering gotta make sure you get a front steer rack. I would get power myself. 2 Quote Link to comment
zeke5551 Posted October 17, 2022 Author Report Share Posted October 17, 2022 thank you, going to get the motor set in there soon and see where at 1 Quote Link to comment
zeke5551 Posted October 19, 2022 Author Report Share Posted October 19, 2022 I'll chech into the sprite/midget rack, was a good idea. Transmission adapter should be here tomorrow and I'll start figuring out mounts....good fun 1 Quote Link to comment
kentodd1903 Posted April 22, 2023 Report Share Posted April 22, 2023 Just wondering if you were able to install the rack and pinion and what you did. Quote Link to comment
