Wolfman Posted September 27, 2022 Report Share Posted September 27, 2022 Issue: battery voltage way to high 16v+ car: ‘70 510, l16. what I’ve tried: new alternator, two brand new voltage regulators, cleaned grounds, cleaned fuse box, new fuses. the alternator is for an ac model, from what I’ve read that should be ok. Both voltage regulators start to smoke and the relay clicks non stop. My old man fixed this once before but he passed away a long time ago and I don’t know what he did to remedy the issue. Any help would be greatly appreciated. Quote Link to comment
datzenmike Posted September 27, 2022 Report Share Posted September 27, 2022 From an AC model .... what? Do you perhaps have a later internally regulated alternator say from an A10 also called a 510. Quote Link to comment
Wolfman Posted September 27, 2022 Author Report Share Posted September 27, 2022 Autozone kept asking if my car had air conditioning, I guess they have 2 different alternators that produced different amps (lower/higher). The one I have is duralast #14118. All the bolts/plugs lined right up. Im not sure if it’s for the model your asking. I had them put it the correct info when looking up parts Quote Link to comment
datzenmike Posted September 27, 2022 Report Share Posted September 27, 2022 I don't think there was an air conditioning option on the PL510 and there were 3 alternators, 33, 35 and 50 amp. The 50 amp being only on '72 and '73 cars. Did you give the year? as there is a later Datsun also 'called' a 510 (in name only) but made in '78 through '81. This is the A10 or HL510 to show it has the L20B engine. Have them check what year the Duralast #14118 is for. BTY the A10 does have air conditioning option, and there are two alternators 50 and optional 60 amp. Quote Link to comment
banzai510(hainz) Posted September 27, 2022 Report Share Posted September 27, 2022 (edited) 14105 is like the standard number 35amper alt. for a 70-71 510 Buy a Japan made volt reg. this is a simple 20 min fix!!!!!!!!!!!!! 14118 is a good number shows a 60amper in Rockauto. have them ck the alternator before you leave. However if you have a over charge the alternator shows its working. Its the Regulator that is not. The alternator will give a overvolt non regulated reading. then the reg cut the voltage down to say 14 volts DC. I have noticed that the Neihoff brand made in USA voltreg are not great and happens with in a year or purchase Edited September 27, 2022 by banzai510(hainz) Quote Link to comment
thisismatt Posted September 27, 2022 Report Share Posted September 27, 2022 Charge your battery before you replace anything again. The alt & regulator are not designed to bring a battery back from dead, dead. Make sure you have solid grounds from battery to chassis and chassis to engine block. Quote Link to comment
banzai510(hainz) Posted September 27, 2022 Report Share Posted September 27, 2022 you had the ground wire on the alternator ? Quote Link to comment
Thomas Perkins Posted September 27, 2022 Report Share Posted September 27, 2022 (edited) It happened to me.My alternator over charged my battery,relays by the glove box were clicking,battery was less than a year old.The alternator kilt the battery,they gave me a new free battery and alternator finally went down to 12 volts and Auto parts store gave me another alternator.So get another battery. Edited September 27, 2022 by Thomas Perkins Quote Link to comment
datzenmike Posted September 28, 2022 Report Share Posted September 28, 2022 That's the last piece. If alternator and regulators have been changed, what's left? the battery. Borrow one see if it settles down. Quote Link to comment
Ooph! Posted September 28, 2022 Report Share Posted September 28, 2022 (edited) He said the regulator was smoking "Both voltage regulators start to smoke and the relay clicks non stop" I'd be checking the harness and at least revisit if its an internally or externally regulated Alt. Edited September 28, 2022 by Ooph! Quote Link to comment
datzenmike Posted September 28, 2022 Report Share Posted September 28, 2022 I forgot that if you put an internally regulated alternator on a Datsun with an external regulator the engine will not shut off with the key. 11 hours ago, banzai510(hainz) said: 14105 is like the standard number 35amper alt. for a 70-71 510 It would appear the correct alternator is on it. Battery ground for the body is on one of the mounting bolts for the external regulator. Factory battery ground cables have a separate ground for the body molded into the battery post connection. If replaced some time in the last 50 years, that ground for the body may be missing on the generic replacement. Quote Link to comment
Wolfman Posted November 19, 2022 Author Report Share Posted November 19, 2022 Took me forever to remember my log in password!!! So here is the update… took back the alternator and got a 35 amp instead. All good now. Thanks again for the input brothas. Always appreciate it!! Quote Link to comment
banzai510(hainz) Posted November 21, 2022 Report Share Posted November 21, 2022 (edited) I would have though it was the volt reg if there was a over charge buy this and plug in cig lighter socket works great and dont frain the battery on daily driver. trust it and it works see when battery loads down ect.... https://www.harborfreight.com/automotive/diagnostic-testing-scanning/12v-batteryalternator-tester-57331.html Edited November 23, 2022 by banzai510(hainz) Quote Link to comment
