Hybrid510 Posted August 26, 2022 Report Share Posted August 26, 2022 Hello friends ..new to the group and tried to search ,but could not find the answer ..I see a good way to lower the rear of a 521 is with 720 4x4 leaf springs..I see they have new 3 inch lowering 720 4x4 springs ..can you just add these springs with no lowering blocks ? sorry if this has been asked before ..thanks for any input Quote Link to comment
datzenmike Posted August 26, 2022 Report Share Posted August 26, 2022 720, 620 and 521/510 rear leaf springs are all the same overall length. 720 leaves are almost flat when installed. Off the vehicle, if you string between the two eyelets and measure down the 2wd is 6.3 inches, the 4x4 is only 3.7 inches. So right away close to 3" different. The spring rate for the 720 is also much higher with the 4x4. Makes no sense to want to lower a 720 4x4 with lowering springs. wtf? The whole reason for 4x4s to ride high is for ground clearance and larger tires. Quote Link to comment
bilzbobaggins Posted August 26, 2022 Report Share Posted August 26, 2022 Is my memory correct or are the 84 4x4 springs the ones with the most drop? Quote Link to comment
banzai510(hainz) Posted August 26, 2022 Report Share Posted August 26, 2022 I used Belltech 6202 with 2 deg angle. cheap and EZ Quote Link to comment
d.p Posted August 26, 2022 Report Share Posted August 26, 2022 1 hour ago, banzai510(hainz) said: I used Belltech 6202 with 2 deg angle. cheap and EZ Do those require refilling the eye holes or they truly plug and play? Quote Link to comment
d.p Posted August 26, 2022 Report Share Posted August 26, 2022 FUCK re-drilling. Quote Link to comment
datzenmike Posted August 26, 2022 Report Share Posted August 26, 2022 2 hours ago, bilzbobaggins said: Is my memory correct or are the 84 4x4 springs the ones with the most drop? 2 hours ago, datzenmike said: 720 leaves are almost flat when installed. Off the vehicle, if you string between the two eyelets and measure down the 2wd is 6.3 inches, the 4x4 is only 3.7 inches. So right away close to 3" different. The spring rate for the 720 is also much higher with the 4x4. This is for the '84. I don't see why other years would be different. A spring shop can 'de-arch' your springs. Quote Link to comment
Hybrid510 Posted August 26, 2022 Author Report Share Posted August 26, 2022 Hey thanks for the info.So if you use stock 720 4x4 springs it lowers 3 inch and no need to add blocks ? Quote Link to comment
datzenmike Posted August 26, 2022 Report Share Posted August 26, 2022 If on a 720 the difference is 3". I don't know what the 'free camber' or arch of an unladen 521 leaf spring is nor the weight on them. Quote Link to comment
banzai510(hainz) Posted August 27, 2022 Report Share Posted August 27, 2022 On 8/26/2022 at 11:55 AM, d.p said: Do those require refilling the eye holes or they truly plug and play? NO they fit perfect on my 521 1 Quote Link to comment
greenthumb Posted August 28, 2022 Report Share Posted August 28, 2022 I thought I recalled someone saying the stack bolt is not in the same location and your axle ends up moving one direction or the other. It’s been a while, so ymmv Quote Link to comment
d.p Posted August 28, 2022 Report Share Posted August 28, 2022 16 hours ago, banzai510(hainz) said: NO they fit perfect on my 521 ima hold you to it and go buy them. Do they come with bushings? Quote Link to comment
