RedStar620 Posted June 29, 2022 Report Share Posted June 29, 2022 I read in an old shop manual and noticed that the L20B was listed as a car and truck version. Is there any difference between the two, or are they one and the same? Quote Link to comment
Stoffregen Motorsports Posted June 29, 2022 Report Share Posted June 29, 2022 Why do you ask? Do you have an L20B and you're trying to figure out what it came from? I believe the difference had more to do with the year and the area of the world that the vehicle was sold. Cylinder heads are different, and probably compression ratio, and possibly cams too, depending on the two variables I just mentioned. Quote Link to comment
Crashtd420 Posted June 29, 2022 Report Share Posted June 29, 2022 The only other thing I can thing of that stroffgren missed are the oil pan and oil pickup tube.. 1 Quote Link to comment
datzenmike Posted June 29, 2022 Report Share Posted June 29, 2022 Oil pans were specific to every vehicle the L20B was used in. While there were 3? different heads used, U67, W58 and I think the A87 '74 610. (the first year the L20B was ever used) The same head was on cars or trucks for that year. Biggest difference was trucks had a 225mm flywheel and clutch and cars were all 200mm. Trucks and the S10 and A10 were throttle cable while the 610/710 were linkage similar to the 510. Other than that, all truck/cars used the same parts. 1 Quote Link to comment
d.p Posted July 24, 2022 Report Share Posted July 24, 2022 I have an l20b that I got out of a 510 and put it my 521 truck. Used a 521 pan, pickup tube and engine mounts. 1 Quote Link to comment
