Roman Tasel Posted December 6, 2008 Report Share Posted December 6, 2008 I took off the timing inspection plate to see if the gasket was bad and it wasn't. So i put back together. Then, a bolt breaks and half of it is stuck in heads. How do I get it out?!!! Quote Link to comment
banzai510(hainz) Posted December 6, 2008 Report Share Posted December 6, 2008 Beo honesnt body pulls that plate to ck the chain. Most ck the cahin when the Valave cover is pulled. What I do is drill the bolt where its busted on one side then I get a small indentation get a punch then wack it so it goes counterclockwise Quote Link to comment
72240z Posted December 6, 2008 Report Share Posted December 6, 2008 When the bolt breaks flush or better I weld a nut to it. When it's deep I drill and tap like mentioned. Idk easy-outs make me nervous I won't use it unless it is a very well made set and consequently expensive as hell. Sometimes a reverse drill bit will do it. Quote Link to comment
mklotz70 Posted December 7, 2008 Report Share Posted December 7, 2008 if there's at least a small amount sticking out, I use a dremel and a cut off wheel to cut a slot in the end. I stop cutting when the wheel gets to the hole surface. Then, if it's not stuck(sounds like it broke going in, but had been out before) I can use a flat blade screw driver to back it out. Quote Link to comment
Jester Posted December 7, 2008 Report Share Posted December 7, 2008 If you have some sticking out, grab it with a pair of vise-grips. Quote Link to comment
Guest DatsuNoob Posted December 7, 2008 Report Share Posted December 7, 2008 I like the vise grips method too (for some reason, I like the needle nose version best for stuff like this) but use a little PB blaster to lube 'er up first, let it set, wipe off the excess and set the vice grips tight. It should come right out. Quote Link to comment
72240z Posted December 7, 2008 Report Share Posted December 7, 2008 Idk I believe if there is enough to grab with vice grips it is far from a problem lol. Quote Link to comment
datzenmike Posted December 7, 2008 Report Share Posted December 7, 2008 Trouble is that it would be turned in pretty tight to snap off so you would need a good amount to grip onto, to begin turning. Thank goodness it's where it is as it can be drilled out to oversize and re-tapped as a last resort. Quote Link to comment
72240z Posted December 7, 2008 Report Share Posted December 7, 2008 Ya sometimes with the grips you just round out or mangle the end real good. With that much meat though you at least have a host of easier options. Quote Link to comment
Nicholas7620 Posted December 7, 2008 Report Share Posted December 7, 2008 Same thing happened to me except, I was screwing out the bolt. The vice grip method didn't work. I don't have a welder. I drilled out the bolt by using the smallest drill bit I had and drilled the hole as close to the center as possible. I switched drill bits to the next larger size and drilled again and repeated until almost all of old bolt is gone. Be careful not to drill into old threads. I then used a rat tail file to file out almost all of the remaining old bolt. I then got the correct size tap thread maker, and rethreaded the hole into the same threads. It took me three hours or more :eek: In your situation you can try drilling a perpendicular hole through the protruding bolt and push a cotter pin through the hole and twist the cotter pin clockwise. You could also try a nail if you don't have a cotter pin. My situation was worse than yours because the bolt had rusted/corroded into the threads. Valve covers, timing belt covers and most parts on cars don't need to be tightened more than half a turn past tight. :mellow: Quote Link to comment
