Arifaeth Posted September 16, 2021 Report Share Posted September 16, 2021 Hey, so to add to the multiple topics I've made 😂, in my truck the shifter is extremely sloppy, like difficult to find the gears type sloppy, so I was wondering if anyone knew where I can find either a bushing set, or a short throw shifter replacement for it? Quote Link to comment
datzenmike Posted September 16, 2021 Report Share Posted September 16, 2021 Your F4W63 has an A type shift mechanism. AKA 'Monkey Motion' and is a well earned moniker. My '71, while driving along was so sloppy that on right hand turns it would flop over and hit my knee. You could move it in a circle the size of a basketball. Shortening isn't the answer. The bottom of the shift lever is threaded and the tightened nut and washers squeeze the rubber cone bushings #8. I have no idea where you can get any but maybe you can jam something in there or wrap them to make a tighter fit? Perhaps stacking one or more washers in the middle where #9 is??? The striking pin #19 and the clips #18 can be replaced with a nut and bolt and washers to squeeze the fingers closer to the striking rod #20. Do NOT over tighten, this is just to remove the slack. It's like a hinge and must be free to move. Control arm pin #17 can also be replaced with a nut bolt and washers, but retain or improve the fit of the control arm bushing #15. Again the bolt and nut can snug up the 'fingers' on the control arm #37 but must not be tight or you won't be able to shift. 2 Quote Link to comment
Arifaeth Posted September 16, 2021 Author Report Share Posted September 16, 2021 38 minutes ago, datzenmike said: Your F4W63 has an A type shift mechanism. AKA 'Monkey Motion' and is a well earned moniker. My '71, while driving along was so sloppy that on right hand turns it would flop over and hit my knee. You could move it in a circle the size of a basketball. Shortening isn't the answer. The bottom of the shift lever is threaded and the tightened nut and washers squeeze the rubber cone bushings #8. I have no idea where you can get any but maybe you can jam something in there or wrap them to make a tighter fit? Perhaps stacking one or more washers in the middle where #9 is??? The striking pin #19 and the clips #18 can be replaced with a nut and bolt and washers to squeeze the fingers closer to the striking rod #20. Do NOT over tighten, this is just to remove the slack. It's like a hinge and must be free to move. Control arm pin #17 can also be replaced with a nut bolt and washers, but retain or improve the fit of the control arm bushing #15. Again the bolt and nut can snug up the 'fingers' on the control arm #37 but must not be tight or you won't be able to shift. Do they not make "aftermarket" or different mechanisms for the transmissions? To change how it shifts? Quote Link to comment
Stoffregen Motorsports Posted September 16, 2021 Report Share Posted September 16, 2021 The only aftermarket item ever for that transmission shifter was a pair of solid tapered aluminum bushing that replaced the soft rubber bushings. That mod firmed it up a bit, but the throws remained the same. There are a handful of small bushings in the strike rod and shift rod pivot mechanism that can wear out, leaving you with a ton of play. The plastic cross pin bushings can be replaced with bronze for a slightly firmer feel too. 1 Quote Link to comment
Arifaeth Posted September 16, 2021 Author Report Share Posted September 16, 2021 15 minutes ago, Stoffregen Motorsports said: The only aftermarket item ever for that transmission shifter was a pair of solid tapered aluminum bushing that replaced the soft rubber bushings. That mod firmed it up a bit, but the throws remained the same. There are a handful of small bushings in the strike rod and shift rod pivot mechanism that can wear out, leaving you with a ton of play. The plastic cross pin bushings can be replaced with bronze for a slightly firmer feel too. Got it, alright, looks like I'll probably just wrap it in some kind of like ,rubber tape or something to add material and hope that helps Quote Link to comment
datzenmike Posted September 16, 2021 Report Share Posted September 16, 2021 Thin washers or shim material for down lower. Quote Link to comment
Stoffregen Motorsports Posted September 16, 2021 Report Share Posted September 16, 2021 Ive even seen washers welded to the top and the bottom of the iron shift lever, acting like solid bushings, but without the crush safety factor. Quote Link to comment
mklotz70 Posted September 17, 2021 Report Share Posted September 17, 2021 The rubber bushings(#8) have shown up on ebay several times. You should be able to look at the mechanism and it's pieces and see where the slop is. There's no easy way to make any kind of short shifter for it......at least not one that would be affordable. lol Quote Link to comment
thisismatt Posted September 17, 2021 Report Share Posted September 17, 2021 16 hours ago, Arifaeth said: Do they not make "aftermarket" or different mechanisms for the transmissions? To change how it shifts? 🤣 No, there is no market for them. The J series was not used in many vehicles, especially in the US. 1 Quote Link to comment
datzenmike Posted September 17, 2021 Report Share Posted September 17, 2021 However this style shifter was used on all later PL521s, 510s, 610s, 710s, A10s Roadster and the first year 240z. Cutting the shift lever reduces the mechanical leverage making shifting a little stiffer. It also makes it hard to reach comfortably. You should be able to shift into every gear with your back against the seat. Nothing looks worse than someone leaning forward and fumbling for the shifter. The best way would be to design it so the fulcrum pin #17, was higher. 1/2 to 3/4" would be plenty. Mechanical advantage would be sacrificed but the shifter length would remain the same. This will shorten the throw forward and back but won't affect the sideways shift through the neutral gate. 3 Quote Link to comment
robrizzo Posted July 24, 2023 Report Share Posted July 24, 2023 On 9/16/2021 at 3:03 PM, datzenmike said: Your F4W63 has an A type shift mechanism. AKA 'Monkey Motion' and is a well earned moniker. My '71, while driving along was so sloppy that on right hand turns it would flop over and hit my knee. You could move it in a circle the size of a basketball. Shortening isn't the answer. The bottom of the shift lever is threaded and the tightened nut and washers squeeze the rubber cone bushings #8. I have no idea where you can get any but maybe you can jam something in there or wrap them to make a tighter fit? Perhaps stacking one or more washers in the middle where #9 is??? The striking pin #19 and the clips #18 can be replaced with a nut and bolt and washers to squeeze the fingers closer to the striking rod #20. Do NOT over tighten, this is just to remove the slack. It's like a hinge and must be free to move. Control arm pin #17 can also be replaced with a nut bolt and washers, but retain or improve the fit of the control arm bushing #15. Again the bolt and nut can snug up the 'fingers' on the control arm #37 but must not be tight or you won't be able to shift. How do you remove pin #17. holding me up from installing transmission. please help. Quote Link to comment
datzenmike Posted July 24, 2023 Report Share Posted July 24, 2023 Asked and answered... ... use a suitable size drift or blunted nail and tap it out. Hold something heavy against the shifter to absorb the shock of hammering. The roll pin does show in this picture as #12. The one I have for the 510 does show it as 32873-14600 retaining pin. Being a roll pin it's used in a variety of parts. Maybe trying to reduce slack? Most of the shifter has to turn and rotate so it can't be over tight. That bushing is replaceable as are the washers. The F4W63 is well named the 'Monkey Motion' shifter. In any gear my 5 year old '71 521 shifter could be moved in a circle about the size of a basketball when I got it. Quote Link to comment
