matrophy Posted July 29, 2021 Report Share Posted July 29, 2021 I bought an 85 720 King Cab that a neighbor had in his field for 10+ years. It runs pretty well considering and it is running a 6-wire Cal smog Hitachi carb. The vacuum lines are in pretty sorry shape and rather than replacing them, I'm wonder if I can delete them. Since the car is running the ECCS system I'm not sure if removing all the vaccum lines would affect the engine since it still has the Hitachi carb 1 Quote Link to comment
A guy named Rick Posted July 29, 2021 Report Share Posted July 29, 2021 (edited) Pretty sure it will interfere, since the carburetor operates based on signal from the oxygen sensor, and adjusts accordingly via the mixture control solenoid. most the vacuum stuff will alter the emission reading if removed. best to install a Weber and then go about deleting anything else that isn't required if you don't need to worry about emissions. Edited July 29, 2021 by A guy named Rick 2 Quote Link to comment
datzenmike Posted July 29, 2021 Report Share Posted July 29, 2021 It's rubber hose, how much can 8 feet cost? You said it runs pretty good. 1 Quote Link to comment
matrophy Posted July 30, 2021 Author Report Share Posted July 30, 2021 On 7/29/2021 at 3:49 PM, A guy named Rick said: Pretty sure it will interfere, since the carburetor operates based on signal from the oxygen sensor, and adjusts accordingly via the mixture control solenoid. most the vacuum stuff will alter the emission reading if removed. best to install a Weber and then go about deleting anything else that isn't required if you don't need to worry about emissions. Kinda what I figured. The PO took a silly straw (no joke) and bent over one end with electrical tape to cap off one of the lines so I figured I'd probably have to embark on the laborious process of tracing and replacing the lines. Hoping I could take the easy way out On 7/29/2021 at 4:45 PM, datzenmike said: It's rubber hose, how much can 8 feet cost? You said it runs pretty good. lmao Mike you know it's more than 8 feet if everything is replaced. .Yeah yeah. I know. It's just a PITA i mean honestly it's not too bad, but then again i've gone through the process, then put a weber on, put hitachi back, put weber on again, so i've had a little practice. Do you have the link to the Vac line replacement tutorial? it really helps, though it can get a little confusing. i kind of want to draw something else to make it a little more understanding, but i suck at drawing. Maybe i'll make some sort of photoshop thing. https://www.nicoclub.com/archives/nissan-720-pickup-truck-vacuum-hose-routing-and-repair-guide.html 1 Quote Link to comment
matrophy Posted July 30, 2021 Author Report Share Posted July 30, 2021 On 7/29/2021 at 5:41 PM, A guy named Rick said: i mean honestly it's not too bad, but then again i've gone through the process, then put a weber on, put hitachi back, put weber on again, so i've had a little practice. Do you have the link to the Vac line replacement tutorial? it really helps, though it can get a little confusing. i kind of want to draw something else to make it a little more understanding, but i suck at drawing. Maybe i'll make some sort of photoshop thing. https://www.nicoclub.com/archives/nissan-720-pickup-truck-vacuum-hose-routing-and-repair-guide.html Those fastboatman tutorials are lifesavers No joke! though a little confusing at times like i said, but it helped me out for sure. 1 Quote Link to comment
Charlie69 Posted July 30, 2021 Report Share Posted July 30, 2021 Can you say "Weber"? 1 Quote Link to comment
Veraciousreasoning Posted September 20, 2021 Report Share Posted September 20, 2021 On 7/29/2021 at 6:37 PM, Charlie69 said: Can you say "Weber"? I plan on getting a Weber carb. From what I understand it def gives your truck more power and that is something I need for sure. 0-60 in 45 minutes is just not great lol 1 Quote Link to comment
