A guy named Rick Posted May 20, 2021 Report Share Posted May 20, 2021 So i need a new power booster, and want to be cheap and maybe just get a booster from a junkyard pickup, but to widen my options could i maybe use one from a hardbody? they seem to have longer studs but look identical. first one is for a hardbody, then one for a 720. https://shop.advanceautoparts.com/p/wearever-unloaded-vacuum-power-brake-booster-import-53-2440/3824063-P?searchTerm=power brake booster https://shop.advanceautoparts.com/p/wearever-unloaded-vacuum-power-brake-booster-import-53-2400/3820785-P?searchTerm=power brake booster 1 Quote Link to comment
Lockleaf Posted May 20, 2021 Report Share Posted May 20, 2021 take measurements. If the bolts line up with the 720 booster spacer, and also with the master cylinder then it will be fine. If they don't, you need to decide how much modification you are willing to deal with. 1 Quote Link to comment
A guy named Rick Posted May 20, 2021 Author Report Share Posted May 20, 2021 those 2 look the same, just longer bolts in the rear. cold cut them if they get in the way Quote Link to comment
Charlie69 Posted May 29, 2021 Report Share Posted May 29, 2021 You can not depend on images on a parts site to be of the actual part the advertisement is for. Quote Link to comment
A guy named Rick Posted May 29, 2021 Author Report Share Posted May 29, 2021 7 hours ago, Charlie69 said: You can not depend on images on a parts site to be of the actual part the advertisement is for. True. Words of wisdom there Quote Link to comment
ShutterMeShort Posted May 2 Report Share Posted May 2 Any update on this? Will a D21 booster mount up to a 720? Quote Link to comment
