zed1 Posted September 3, 2020 Report Share Posted September 3, 2020 (edited) Are these original door panel clips for a 1966 520? Thanks, Keith Edited September 3, 2020 by zed1 1 Quote Link to comment
thisismatt Posted September 3, 2020 Report Share Posted September 3, 2020 Look correct to me 1 Quote Link to comment
datzenmike Posted September 3, 2020 Report Share Posted September 3, 2020 They should be on the panel. 1 Quote Link to comment
Draker Posted September 3, 2020 Report Share Posted September 3, 2020 The slot into the holes in the door car, then just pop in like you see there. 1 Quote Link to comment
datzenmike Posted September 3, 2020 Report Share Posted September 3, 2020 I'm thinking that the door panels may have been ripped off and damaged if the clips are still in the door. 1 Quote Link to comment
MikeRL411 Posted September 3, 2020 Report Share Posted September 3, 2020 Toyota's version of these clips have a foam pad to reduce rattle. They fit Datsun door panels. 2 Quote Link to comment
zed1 Posted September 3, 2020 Author Report Share Posted September 3, 2020 Is the photo below the same clip as the one mounted in the door above? Thanks, Keith 1 Quote Link to comment
Draker Posted September 3, 2020 Report Share Posted September 3, 2020 1 hour ago, zed1 said: Is the photo below the same clip as the one mounted in the door above? Thanks, Keith Can't tell dimensionally, but yes they are the same clip otherwise. 1 Quote Link to comment
