Cuts metal like mad Posted November 28, 2008 Report Share Posted November 28, 2008 there is adjustment... Make sure you get it centered up before dropping it back in after putting the "new" parts in. Didn't look at those links, don't know they covered the adjustment "procedure" but it's in the haynes Quote Link to comment
moparvwfreak Posted November 28, 2008 Author Report Share Posted November 28, 2008 i'll look and see what i can find ont the adjustment procedure. Quote Link to comment
Pacific coast Datsun Posted May 4, 2009 Report Share Posted May 4, 2009 On the T shaped plug on the matchbox the vertical connector (I) should have 12 volts from the ignition and also be connected to the +side of the coil, the cross (-) should go to the neg side of the coil. Stick an old spark plug in the coil wire and lay on the grounded fender. Remove dizzy, take the cap off and spin the rotor by hand. There should be sparks at the plug. D-mike...can you please tell me what color the wire is that needs to be connected to the vertical connector on the matchbox ? Im having issues on my 72 wagon & the wiring is all stock & uncut. Quote Link to comment
ggzilla Posted May 4, 2009 Report Share Posted May 4, 2009 Air gap was too tight and the little tips of the starwheel hit the outer ring breaking them...Not caused by loose shaft bushing. This is caused by a broken bearing plate (advance plate), they have three ball bearings that fall out. A new plate assembly is about $75 from Nissan. Quote Link to comment
banzai510(hainz) Posted May 4, 2009 Report Share Posted May 4, 2009 B is +coil C is -coil anytime a car dies automatically ck for spark. Pulle the center wire to the cap and place it near ground. and turn car over. if you get spart look else where. This saves on cranking the battery so you can look else where. My next obvious is gas by pumping ghe gas and see if gas is squirting in the carb. Thsi shows that gas is making it up to and in the carb. Shows ful pump and needle valve working. Quote Link to comment
