flat land rider Posted November 26, 2008 Report Share Posted November 26, 2008 Hey, Since I only have the weak 35A alternator, I was wondering if it had enough juice to power a set of 6X9's or would it drain my system? Quote Link to comment
datzenmike Posted November 26, 2008 Report Share Posted November 26, 2008 (edited) Sure it should handle that, long as you aren't using a 100 X 100 watt per side amp to drive them. Edited November 27, 2008 by datzenmike Quote Link to comment
cg78 Posted November 26, 2008 Report Share Posted November 26, 2008 Or you could go to the yard and pull a bracket form a 720 and use its alternator. I am and noticed better overall power stability. Then again I am running an electric fan. There is also a way to run a gm 1 wire and they can put out 109amp if you would like to run some big sound. Quote Link to comment
datzenmike Posted November 26, 2008 Report Share Posted November 26, 2008 I did that but it was too close to the idler arm grease nipple. Used a 280z lower rad hose block inlet. No too much adjustment range. Quote Link to comment
izzo Posted November 26, 2008 Report Share Posted November 26, 2008 Suggestion. If you do run the stock alt, buy a cap... I dont know about the one in the link but its just for reference. You could run a cap before the stereo so it would pull the load from that rather than your alternator. Or if you do run an amp, put that before the amp. It would go, Battery/wire/farad capacitor/wire/amp. I can do up a diagram if you need. Stereo stuff is rather easy for me. http://www.opentip.com/Electronics-Computers/Farad-Digital-Capacitor-p-790535.html Quote Link to comment
bagged_datsun Posted November 26, 2008 Report Share Posted November 26, 2008 Suggestion. If you do run the stock alt, buy a cap... I dont know about the one in the link but its just for reference. You could run a cap before the stereo so it would pull the load from that rather than your alternator. Or if you do run an amp, put that before the amp. It would go, Battery/wire/farad capacitor/wire/amp. I can do up a diagram if you need. Stereo stuff is rather easy for me. http://www.opentip.com/Electronics-Computers/Farad-Digital-Capacitor-p-790535.html caps dont do nything, there just for looks. you could add another battery or be a high amp battery but if your amp cant keep up with the stereo draw it will still go dead Quote Link to comment
izzo Posted November 26, 2008 Report Share Posted November 26, 2008 (edited) caps dont do nything, there just for looks. you could add another battery or be a high amp battery but if your amp cant keep up with the stereo draw it will still go dead Normally i wouldnt argue, but they do in fact help (i wont argue the fact that most ppl use them for looks....). A second battery will make your problems worse. This is because a second battery will put more strain on your alternator. Now your alternator would have to charge two batteries instead of just one, wich is hooked up to your stereo. so that defeats the purpose since its charging 2 batteries instead of 1 now just for a stereo your best bet is to upgrade that alternator. Edited November 26, 2008 by h2theizzo Quote Link to comment
bagged_datsun Posted November 26, 2008 Report Share Posted November 26, 2008 Normally i wouldnt argue, but they do in fact help (i wont argue the fact that most ppl use them for looks....). A second battery will make your problems worse. This is because a second battery will put more strain on your alternator. Now your alternator would have to charge two batteries instead of just one, wich is hooked up to your stereo. so that defeats the purpose since its charging 2 batteries instead of 1 now just for a stereo your best bet is to upgrade that alternator. well adding 2 batteries wouldn't hurt anything as long as the draw from then was lower the 35 amps because they would stay charged and and there would be no need for the alt to charge them hence no strain, but if the draw is greater then the 35 amp output then you will have a problem but yes the alt upgrade would be the best bet and teh only thing that is gonna really help Quote Link to comment
ezcruiser Posted November 26, 2008 Report Share Posted November 26, 2008 (edited) I could see a cap helping if you had a starving sub. I don't know much about car audio setups, but this made for a good read: Car Audio Capacitors - Why You Can't Do Without Them I wanted to ad this as well: 90 amp bolt in alternator on an L-series motor Edited November 26, 2008 by ezcruiser Quote Link to comment
datzenmike Posted November 27, 2008 Report Share Posted November 27, 2008 (edited) Quote from: Car Audio Capacitors - Why You Can't Do Without Them "A capacitor is a bit similar to your car battery; it stores electrical energy. But unlike a battery it doesn't produce its own power, it simply stores it." News flash .... a capacitor is VERY like a battery. A battery doesn't produce it's own power, it only stores it. The alternator produces the power. There is no extra strain on an alternator if you have two or ten batteries connected to it. If it is rated at 35 amp output then that's what it puts out, it can't work any harder. If you have a draw of over 35 amps on a 35 amp alternator it will eventually drain the battery. An extra battery will extend this time by double. A 1 farad cap will hardly store any extra power, a second battery would be much better. A 90 amp alternator... even better. Edited November 27, 2008 by datzenmike Quote Link to comment
bagged_datsun Posted November 27, 2008 Report Share Posted November 27, 2008 Quote from:News flash .... a capacitor is VERY like a battery. A battery doesn't produce it's own power, it only stores it. The alternator produces the power. There is no extra strain on an alternator if you have two or ten batteries connected to it. If it is rated at 35 amp output then that's what it puts out, it can't work any harder. If you have a draw of over 35 amps on a 35 amp alternator it will eventually drain the battery. An extra battery will extend this time by double. A 1 farad cap will hardly store any extra power, a second battery would be much better. A 90 amp alternator... even better. kinda sounds like what i said Quote Link to comment
]2eDeYe Posted November 27, 2008 Report Share Posted November 27, 2008 I'm sorry.... What was the question? :D Capacitor=Battery=energy storage device. Battery is for extended loads and a capacitor is for momentary loads. flat land rider, what stereo? Quote Link to comment
1lo620 Posted November 27, 2008 Report Share Posted November 27, 2008 I have a decent set up in my truck....head unit, 2 amps, 2 10" subs. and a set of mid, tweeds...never had a problem...I remember years ago, i use to have a system that you could hear 3 blocks away, 4-12s, 4-5 1/4s, 4-tweeds. 4 amps, 2 electronic crossovers,All custom done on amp racks and the 12s in a wedge. it was ran off of 2 deep cycle batteries, and a higher output altenator, cant remember the amp output...But man that system bumped..Sold the truck to a kid and 2 weeks after I sold it to him all the stuff got stolen out of the truck, they took the whole box set up, it had the amps 12s etc on it they just lifted it out of the truck. The dad had the nerve of coming to my house an in directly accusing me of the theft....I was like ya your little punk ass son bumps the system all over town and you wonder why it got stolen....sorry got a bit offf topic...best of luck with your new system set up.. Quote Link to comment
flat land rider Posted November 28, 2008 Author Report Share Posted November 28, 2008 Thanks for the help! I'm not looking for anything crazy just something that is gonna play music louder then my exhaust. Can anyone tell me what wires are what out of the stock radio of a 80 720?:o Quote Link to comment
datzenmike Posted November 28, 2008 Report Share Posted November 28, 2008 LightGreen and Light Green/Red stripe wires go to dash speaker. Red/Yellow and Red/Blue stripe wires are for illumination, on with dash lights. Black/Blue stripe goes to ground. Black/Brown stripe comes from the fuse box. On with Ign.and Accy.. Quote Link to comment
cgovia Posted November 29, 2008 Report Share Posted November 29, 2008 how do you put a cd player in where the stock radio was any ideas any one? and I put my seat all the way back and dont have much room for a sub any ideas? Quote Link to comment
scooter Posted November 29, 2008 Report Share Posted November 29, 2008 for the stereo, trace the wire from the back of the fusebox. you need 2.. one from a constant power source and the other is switched with the key. as for the charging system i'm royally pissed off at datsun alternators and reglators.. after goin through 4 remans (2 were bearing failures.. damn high revving highway driving) and 2 regulators i stuck a big fucking chrome 100amp GM alternator on there :) all u have to do is grind the one tab down and it bolts in ;) have had NO troubles with the one wire set up, my dash lights are brighter and and my lights dont dim when the turn signals turn on.. and no more boiled out batterys!! the stock setup killed 2 batteries!! fuck! the only thing crappy i've noticed with the giant alternator is it seems to not rev up as fast as it did before.. A power pulley should change that though :fu: Quote Link to comment
