89Sunny Posted February 2, 2020 Report Share Posted February 2, 2020 This might be a dumb question BUT do I need to take off the intake to take off and replace the header? Quote Link to comment
datzenmike Posted February 2, 2020 Report Share Posted February 2, 2020 I would, easier to work on and you need a new gasket anyway. Get a foam rubber filter on there before you suck that sound deadner into the engine. Quote Link to comment
89Sunny Posted February 2, 2020 Author Report Share Posted February 2, 2020 Thanks. I didn't even think to pick up a new gasket. That's an older picture I've put on a newer air filter since then. 1 Quote Link to comment
banzai510(hainz) Posted February 3, 2020 Report Share Posted February 3, 2020 if your stock exhaust manifold is bad I would take off both. If your putting on a cheap header thinking your going to go FASTER your waisting your time and reliability of the car for such a minute gain and I mean minute gain by putting on a header on a 35hp motor if that.. Unless its Ceramic Coated also. I say don't do it!!!!!!!!!!!!!!!!!!!!!!!!!! if your set up is fine as it is and works. Quote Link to comment
datzenmike Posted February 3, 2020 Report Share Posted February 3, 2020 He said replace the header. He might mean the exhaust manifold which is pretty close to being a cast iron header anyway. Quote Link to comment
89Sunny Posted February 3, 2020 Author Report Share Posted February 3, 2020 There is a header on there now. The issue with the one that is that the way it's built is hangs way too low. My truck is lowered already and I'd like to go lower. So the new header (which was cheaper than a exhaust manifold) will allow me to adjust/move the pipe up and over some. I have no aspirations of going fast with the current engine. 1 Quote Link to comment
wayno Posted February 4, 2020 Report Share Posted February 4, 2020 Would not a stock exhaust manifold be better, then you can put the exhaust where you want it. Quote Link to comment
89Sunny Posted February 4, 2020 Author Report Share Posted February 4, 2020 9 hours ago, wayno said: Would not a stock exhaust manifold be better, then you can put the exhaust where you want it. Probably but I did no/do not have one and the ones I found were at least $100 more than the header. Quote Link to comment
datzenmike Posted February 4, 2020 Report Share Posted February 4, 2020 It's just an A series exhaust manifold isn't it???? They throw them away. Try a want ad here... https://ratsun.net/classifieds/category/9-datsun-parts/ Quote Link to comment
Stoffregen Motorsports Posted February 4, 2020 Report Share Posted February 4, 2020 On 2/1/2020 at 4:07 PM, 89Sunny said: This might be a dumb question BUT do I need to take off the intake to take off and replace the header? I see tubes in this pic. Looks like a header to me. Quote Link to comment
banzai510(hainz) Posted February 4, 2020 Report Share Posted February 4, 2020 order a A SERIES GASKET AND YOULL BE ABLE TO FIGURE THIS OUT IF YOU NEED TO REVOVE BOTH BUT 99% best to get a new gasket and a good one at that while running a header Quote Link to comment
Stoffregen Motorsports Posted February 4, 2020 Report Share Posted February 4, 2020 15 hours ago, wayno said: Would not a stock exhaust manifold be better, then you can put the exhaust where you want it. That manifold is a pile of crap. Notice the siamesed center runners and the 4-into-1 collector? The early ones were much better. Quote Link to comment
wayno Posted February 4, 2020 Report Share Posted February 4, 2020 He mentioned he was not looking to go fast, so I posted a photo of a stock type manifold with the single head pipe that would make it much easier for exhaust routing on a lowered vehicle, there is more needed to make that exhaust manifold work as it is an emissions manifold with at least 3 holes in it that need to be plugged. 1 Quote Link to comment
Stoffregen Motorsports Posted February 4, 2020 Report Share Posted February 4, 2020 Right. It will do that for sure. I just feel like if I'm going to take the time to swap it out, I may as well spend the extra hundred bucks to get a good manifold. Quote Link to comment
