frank88 Posted December 28, 2018 Report Share Posted December 28, 2018 Hi Guys. I want to know if this is a stock booster or if for some reason it has been moved forward of the firewall? The piece behind the servo doesn't look oem to me. Car is a 76 620, L20B. Thanks 1 Quote Link to comment
Crashtd420 Posted December 28, 2018 Report Share Posted December 28, 2018 You mean that adaptor/ spacer.... Its factory.... 1 Quote Link to comment
frank88 Posted December 28, 2018 Author Report Share Posted December 28, 2018 Thanks for the speedy reply. Shame its oem, It's pretty much the biggest master setup I've ever seen! 1 Quote Link to comment
2wheel-lee Posted February 14, 2019 Report Share Posted February 14, 2019 I've always wondered about this spacer. What's its purpose? Anyone remove it or make a shorter spacer and use a shorter rod? Yes, I know some people remove the booster entirely when doing engine swaps, but I want to keep mine--I just want more clearance. 1 Quote Link to comment
wayno Posted February 15, 2019 Report Share Posted February 15, 2019 You could try the 1973/74 booster, it is smaller round, but you would need the proper spacer for between the booster than master brake cylinder and that spacer doesn't come with rebuilt boosters. 1 Quote Link to comment
datzenmike Posted February 15, 2019 Report Share Posted February 15, 2019 I think the spacer moves the booster out to give more room for the clutch master. It might also provide more clearance for the steering column just below it. 1 Quote Link to comment
wayno Posted February 17, 2019 Report Share Posted February 17, 2019 That is called a pedestal Mike, the spacer is between the booster and the brake master. On 2/14/2019 at 8:59 PM, datzenmike said: I think the spacer moves the booster out to give more room for the clutch master. It might also provide more clearance for the steering column just below it. 1 Quote Link to comment
datzenmike Posted February 17, 2019 Report Share Posted February 17, 2019 Thanks wayno I usually call it a pedestal. 1 Quote Link to comment
