]2eDeYe Posted February 19, 2019 Report Share Posted February 19, 2019 That key location is pretty trick. Can't wait to see what get's done to the 720. ? 1 Quote Link to comment
petercscherer Posted March 21, 2019 Author Report Share Posted March 21, 2019 This project got postponed while I do a suspension swap on the White 1995 Hardbody. Thread can be found here: https://ratsun.net/topic/69795-1995-nissan-hardbody-2wd-build/page/2/ I should be back on the Rebel in Mid May. Planning for a July completion. 😉 ~Peter Quote Link to comment
E.419 Posted October 20, 2019 Report Share Posted October 20, 2019 Doing the same hardtail conversion on my 1985 rebel 250. Was wondering if you ever got the project finished? If so what did you do for spacers on the back wheel? What about axle adjusters? Would love to see pics and pic your brain sometime on this stuff. Quote Link to comment
petercscherer Posted November 17, 2019 Author Report Share Posted November 17, 2019 On 10/20/2019 at 12:37 AM, E.419 said: Doing the same hardtail conversion on my 1985 rebel 250. Was wondering if you ever got the project finished? If so what did you do for spacers on the back wheel? What about axle adjusters? Would love to see pics and pic your brain sometime on this stuff. Project had to be postponed, got sidelined first with my Hardbody Nissan build, and then life got wacky for me and I've been so busy with work and other commitments that both projects are stalled. I will finish them both this winter hopefully. My plan for spacers, is I've been using washers for mockup, and then I'll measure up what I need and have a buddy machine me a spacer out of round stock the same diameter as the OEM spacer. As for adjusters, I ordered up a set I believe that came on modern Honda 250cc dirt bikes, and I'm going to adapt them for tensioning. I tried to figure out a chain idler wheel to take up the slack, but it look to unwieldy and ugly that I decided the rear mount axle adjusters was better. The bike is really close to completion, I bet I could finish it in a month of solid work once I get time. Feel free to email me directly and I'll help you as much as I can, I have lots of schematics and research on this conversion. caprockfabshop@gmail.com ~Peter Quote Link to comment
datsunfreak Posted October 5, 2020 Report Share Posted October 5, 2020 On 3/20/2019 at 7:15 PM, petercscherer said: I should be back on the Rebel in Mid May. Planning for a July completion. And? 😁 Quote Link to comment
petercscherer Posted October 24, 2020 Author Report Share Posted October 24, 2020 On 10/4/2020 at 7:31 PM, datsunfreak said: And? 😁 And the shutdown hit. Had to prioritize as much paying work as possible and I'm just now getting to a point where I can get back to personal projects. I did just finish building a 4x8 welding table that this bike will fit on so I'm off the ground and able to do some more fixture welding of brackets and the rear assembly. Should have updates soon. ~Peter 3 Quote Link to comment
datsunfreak Posted October 26, 2020 Report Share Posted October 26, 2020 On 10/24/2020 at 7:08 AM, petercscherer said: And the shutdown hit. Had to prioritize as much paying work as possible I figured as much. Your instagram has been kinda dead. 😁 Quote Link to comment
petercscherer Posted October 27, 2020 Author Report Share Posted October 27, 2020 On 10/26/2020 at 7:03 AM, datsunfreak said: I figured as much. Your instagram has been kinda dead. 😁 Yeah, too many distractions on there. My plan of attack is to get the rebel finished over the next few months and then drag the 95 Hardbody back in and get back on that. Here's pics of the table. 4'x8' 5/16" mild steel (just the top weighs 408lbs!) All the tubing is 1/8" wall so its capable of supporting up to 3800lbs. Overall the table weighs 720lbs!!! Sits at 33" tall which is perfect for rolling a chair under it for tig welding. It'll be the workspace for the rebel so I can make a fixture to bolt the frame of the bike to the table at ride height and do better fabrication without working on the ground and having it roll around on me. ~Peter 1 Quote Link to comment
datsunfreak Posted October 27, 2020 Report Share Posted October 27, 2020 For a second, due to the weight, I wonder if those were tow straps... 😁 Quote Link to comment
petercscherer Posted October 27, 2020 Author Report Share Posted October 27, 2020 Close, they do actually come in handy for grabbing it and pulling it around. But they're primarily there to help me with lifting the table. I built it upside down taking advantage of the relatively level concrete, and then needed to flip it to get it right side up. That was a bit of an ordeal... Quote Link to comment
Mattndew76 Posted October 27, 2020 Report Share Posted October 27, 2020 I cant see the pictures Quote Link to comment
datsunfreak Posted October 27, 2020 Report Share Posted October 27, 2020 5 hours ago, petercscherer said: Close, they do actually come in handy for grabbing it and pulling it around. But they're primarily there to help me with lifting the table. I built it upside down taking advantage of the relatively level concrete, and then needed to flip it to get it right side up. That was a bit of an ordeal... I actually thought they were a place to run straps to so you can strap down a bike. 😁 Quote Link to comment
petercscherer Posted October 27, 2020 Author Report Share Posted October 27, 2020 1 hour ago, Mattndew76 said: I cant see the pictures I couldn't either on my phone, but just looked here on my computer and they show up just fine. They're hosted off my google photos account, that may have something to do with it. ~Peter Quote Link to comment
Dima85 Posted June 3, 2022 Report Share Posted June 3, 2022 Hello. Have you completed the honda rebel project? Would love to see a photo of what happened. Quote Link to comment
Dima85 Posted June 3, 2022 Report Share Posted June 3, 2022 Привет. Ты закончил проект с honda rebel ? Очень хочется увидеть фото того что получилось Quote Link to comment
petercscherer Posted June 13, 2022 Author Report Share Posted June 13, 2022 On 6/3/2022 at 2:57 AM, Dima85 said: Hello. Have you completed the honda rebel project? Would love to see a photo of what happened. Hi Dima, I've made zero progress on the Rebel in the past 2 years. Had a couple acquaintances die in motorcycle accidents here in W Texas and I have come to realize that the odds of survival diminish on 2 wheels, especially around here. Too many big trucks and people driving distracted. So work continues on my Nissan Hardbody Race Truck as I ponder the future of this build. Thanks for checking in! ~Peter 1 1 Quote Link to comment
