wayno Posted September 11, 2019 Report Share Posted September 11, 2019 That brake master barely clears the Weber. Looking good, keep up the good work! Quote Link to comment
zachreini Posted September 11, 2019 Author Report Share Posted September 11, 2019 2 minutes ago, wayno said: That brake master barely clears the Weber. Looking good, keep up the good work! It’s definitely a tight fit. I’m glad I test fitted the engine so I knew where the problem areas are. Thanks! 1 Quote Link to comment
Easygoingjc Posted September 21, 2019 Report Share Posted September 21, 2019 Nice work, slow isn't bad. It means you are not rushing. My grandpa always said if you take the time to do it right the first time you don't have to take time to do it again. 2 Quote Link to comment
zachreini Posted September 13, 2020 Author Report Share Posted September 13, 2020 (edited) https://imgur.com/a/G6HxsCS After my second rebuild (new bearings, rings, seals, valves lapped) I got the truck started with the big Weber I also made this coolant pipe because I thought having a big tube crossing over the engine didn't look great. Now to get some new tires and get it back on the ground! Edited September 13, 2020 by zachreini 3 Quote Link to comment
zed1 Posted September 13, 2020 Report Share Posted September 13, 2020 Impressive. your work is outstanding. Keith Quote Link to comment
pidge Posted September 14, 2020 Report Share Posted September 14, 2020 That engine bay looks sweet man. Clean job. Quote Link to comment
