igotatruck Posted December 4, 2017 Report Share Posted December 4, 2017 I see alot of offerings in the 12v electric fuel pump market. Any that are especially worthy of being on an 83 720? Quote Link to comment
Lockleaf Posted December 4, 2017 Report Share Posted December 4, 2017 Facet brand. There is a thread somewhere on here with a part number for it putt maybe someone will chime in 1 Quote Link to comment
.sunlover Posted December 4, 2017 Report Share Posted December 4, 2017 I use any off the shelf low psi pump. They are available at all parts stores, so no downtime. I doubt they make a pump that can't feed a z24. Mine is Mr. gasket, I never get less than 3psi pressure wot, up hill 5k rpm is no problem. Quote Link to comment
metalmonkey47 Posted December 5, 2017 Report Share Posted December 5, 2017 Anything but Airtex. Garbage pumps. Quote Link to comment
Crashtd420 Posted December 5, 2017 Report Share Posted December 5, 2017 I'm using a carter p4070... Low pressure high volumne... 4 to 8 psi and 72gph Actually output for me was around 6.5 I did have to add a regulator, was a little high for my weber. Needed about 3.5.. Quote Link to comment
mrbigtanker Posted December 6, 2017 Report Share Posted December 6, 2017 Facet brand. There is a thread somewhere on here with a part number for it putt maybe someone will chime in What he said. Been using them for years. They work great. 1 Quote Link to comment
nl320what Posted December 6, 2017 Report Share Posted December 6, 2017 Yea, the Facet cube style universal fuel pump is sold at nearly every autoparts store for about $60, and then get the universal adjustable regulator $15 or so. There is another type that is rounded and works just as good also, they both work just as well. But they should be mounted nearest to fuel tank as possible as they are made to push fluid, but have worked fine if mounted in engine compartment to suck. Quote Link to comment
