craigba
Battery power drawn when 620 ignition is off
Maybe this has already been discussed, but I am experiencing a dying brand new battery. I've unplugged the Saturn alternator and voltage regulator from their respective locations, and I still see the battery draining. What else could be drawing power after keyed off?
Note:
I did solder in a 12V relay for the automatic choke, which I haven't unplugged, could this be an area to test also?
Thank you for any assistance provided.
Share this post
Link to post
Look up the parasitic draw test on youtube. That should help you figure this out.
Share this post
Link to post
Yup the reason for an internally regulated alternator (besides more power) is to get rid of the problematic external regulator.
You did join the White and Yellow wires  and the White/Red and White/Black pairs of wires?
Unplug and remove the automatic choke relay and find the Red and Blue wires going to the carb. The connectors unplug jst under the front left of the air filter. The Red wire is the idle cut solenoid. Unplug the Blue choke wire and connect the carb blue wire end into the Red idle cut wire. Your choke and idle cut are now powered by the idle cut supply and good to go.
Share this post
Link to post
Yeah get rid of the choke relay. You can heat the choke by wiring it to the ignition side of the ballast resister.
Share this post
Link to post
Thanks datzenmike! banzai510 there is no power at the choke wire when the car is off. I'll take a look at it tomorrow and test for the draw.
Share this post
Link to post
It might be disconnected but the relay still on. Unplug the relay to be sure.
With the relay gone you need a new power source for the choke that is turned off and on with the ignition. Connect to the Red idle cut solenoid or the the ignition side of the ballast resistor. done.
Share this post
Link to post
Do you have a stereo with memory?  That has a draw.
Did you wire the alternator properly?  Switching the power and signal wire can result in a draw.
Share this post
Link to post
The draw is coming from the power wire on the alternator, by based on the wiring diagram from the Saturn alternator write up, it looks like the power wire is jumped with the signal wire.
Share this post
Link to post
Could a blown fuse on the battery alternator circuit on the fuse box cause a constant power draw from the alternator and battery?
Share this post
Link to post
No
Maybe connect the signal wire to the ignition switch so that it is off with the key.
Share this post
Link to post
