Sign in to follow this
mx71
Tach Mystery
Ok, I can't figure out the tach. I did order a new resistor in case that's it, but I don't know how else to get it to work. Is something supposed to be actually hooked up to the coil? The resistor is just plugged into the connection. The white/blue wire has 12 volts and the black/blue wire has no power. Why is it by the coil if it isn't connected to anything? What should I be looking for? I've been scouring this forum, the internet, and the service manual and it isn't super clear.
Share this post
Link to post
Are you just adding a tach? or the tach stopped working?
Share this post
Link to post
I bought the truck with the tach not working. It's an 85 Deluxe King Cab. What goes to the negative on the coil, and which coil?
Share this post
Link to post
I have an 82 my wire was blue. Follow your wiring diagram there should be a eye on the wire and it just went on the negative post of the coil. I believe intake, the one that doesn't cut off under load.
Share this post
Link to post
There may be other wires attached to the coil negative (-) terminal, but the White/Blue stripe one goes through the 2.2K ohm resister and then becomes a Black/Blue stripe to the tach in the dash. The tach also has a Black ground wire and a Yellow/Red wire, connected to the illumination system (dash lights.)
The intake coil is usually the source for the tach signal but it will work just as well on the exhaust.
If you bought it not working maybe it's broken.
Share this post
Link to post
Clearly it's broken. I'm just trying to troubleshoot to get it working. The diagram isn't clear that what color the wire is. So the wires with the resistor don't connect to the coil at all, or are they connected somewhere else? I couldn't find a new resistor, so I just ordered a general electronics resistor to test it. (2.2k ohm, 1w)
Share this post
Link to post
Hey I just went through this in my truck.
How are you measuring things?
Look for the mentioned 2.2k resistor by the coils. It will be in a thumb-sized black rubber connector on the wire. If you pull it you can check the continuity between the resistor, coil and the tach connector without worrying about wire colors.
Since you have 12V, it seems like your fuse is fine. Make sure you have ground on one of the other pins (not both) and the third will be the signal to the gauge. If you have access to an oscilloscope you can check to see if the connector in the dash is getting any kind of signal.
A cheap DMM might also be able to register some kind of AC response.
Also, you can measure the tach meter. If you remove the gauge from the cluster, you should see some tiny, silver wires connecting the control circuit to the little springs that move the needle.
If you measure these VERY CAREFULLY you should get a resistance of some kind, probably around ~100Ω, mine was 70Ω.
The bad one died as 'open circuit' if I remember correctly, and the small voltage from my cheap DMM was enough to nudge the working needle.
Check this:
http://community.ratsun.net/topic/71865-84-datsun-720-gauge-hackery/
Share this post
Link to post
Well I thought I was clear where the tach wires are connected.... From intake coil negative terminal, to resistor, to tach. If the resistor is bad or the wires not connected these are the things, other than the gauge itself, that could cause it to not work.
By broken I mean the gauge is at fault. The tach is quite complex, and so, is the most likely thing to fail. Two wires and a resistor are less likely.
Share this post
Link to post
I haven't yet gotten to the point of opening the cluster, but when I do, I'll try this. Thank you!
Check this:
Share this post
Link to post
Got it, thank you!
Share this post
Link to post
Well, it wasn't the resistor. Not sure how else how to check.
Share this post
Link to post
I think you're ignoring the probably cause, which is the tach gauge itself.
Share this post
Link to post
I guess I was wishful thinking. Is there a way to test it? Maybe check for a signal at the connector? I don't have an oscilloscope.
Share this post
Link to post
A signal at the connector merely says the wiring is good.
You could remove the tach and wire it directly to your truck's coil. You would still need the 2.2K resistor in line, but if it did work then you have a wiring problem.
The 'signal' is an on and off ground. If you connect a test lamp to the coil negative and the other end to the battery it might flicker with the engine running. On the other side of the 2.2K ohm resistor I doubt there would be enough current flow to light it.
Share this post
Link to post
Hmm. Bummer. It's the last thing left that doesn't work on the truck, but I'm not sure it's worth spending any more money on,
Share this post
Link to post
Keep eyes open in the wrecking yards. The ST model will have them standard, optional on the others. They are at least, plug 'n play
Share this post
Link to post
They are relatively easy to come by. Post an ad in the classifieds. I've sold them here before.
Share this post
Link to post
Possibly. The only irritating thing is it's now the ONLY thing not working. I wouldn't care so much if other stuff was broken.
Share this post
Link to post
Ok, so far I've tried a new resistor and new tach, neither worked. I know it could be the coil. How do I test that?
Share this post
Link to post
If the engine runs the coil is good.
Maybe the dash wiring that the tach plugs into? Check for continuity between the coil and one side of the resister. Then from the other side of the resister to the tach.
Share this post
Link to post
The white/blue wire has continuity to the intake coil. When running, the white/blue gets 12 volts. and the black gets 9 volts. All ok so far?
Share this post
Link to post
What about from the other side of the resistor to the tach?
Share this post
Link to post
I was hoping not to have to get that one out, but I'll check it next time I mess with the truck. Thanks.
Share this post
Link to post
Mystery solved. Tach was bad. It's a bummer because upon removal it's in visually perfect condition. Think it's worth anything on eBay not working?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
