Isaiahhh26 Posted May 7, 2017 Report Share Posted May 7, 2017 Fuel pump is leaking gas every time I push down the gas pedal. Replaced gasket and it is not leaking from there. It seems to be coming out of a little hole on the pump itself? Do I just get a new fuel pump or is there a way to stop the leak? 1 Quote Link to comment
willz Posted May 7, 2017 Report Share Posted May 7, 2017 Pictures of this little hole? 1 Quote Link to comment
Roadster-ka Posted May 7, 2017 Report Share Posted May 7, 2017 Replace the pump. 1 Quote Link to comment
banzai510(hainz) Posted May 7, 2017 Report Share Posted May 7, 2017 if stock orginal pump there is a hole. if leaks the diaphrame has a hole. sometimes gas will go in to the crank case also. ck the oil ans smell it 2 Quote Link to comment
datzenmike Posted May 7, 2017 Report Share Posted May 7, 2017 Probably needs a new pump diaphragm. It's the only way gas can get down to the mounting gasket. http://www.new-datsun-parts.com/datsun-510-parts-exterior1.html Don't drive it like this. Gas will thin the oil and can generate a explosive mixture in the crankcase. 3 Quote Link to comment
willz Posted May 7, 2017 Report Share Posted May 7, 2017 From what I've read, almost all the mechanical fuel pumps are the same internally so diaphragms and such swap over, I think there's one that actually has a dual diaphragm, it's got one on top of each other. Maybe from an F10? 1 Quote Link to comment
Isaiahhh26 Posted May 7, 2017 Author Report Share Posted May 7, 2017 I believe it's coming from this little hole but I will check the oil when I get the chance 1 Quote Link to comment
inazuma Posted May 8, 2017 Report Share Posted May 8, 2017 have it here in greece the pickUp 620 and i think the fuel pump have it maybe problem.. this hole after press the axon bleeding oil..this it's problem? can opened and fix it;; 1 Quote Link to comment
Scgreen620 Posted May 9, 2017 Report Share Posted May 9, 2017 The mechanical pump leaks from two holes closer to the part where you bolt it... It leaks oil ... 1 Quote Link to comment
inazuma Posted May 9, 2017 Report Share Posted May 9, 2017 The mechanical pump leaks from two holes closer to the part where you bolt it... It leaks oil ... and this it's ok;; that's "working" fuel pump..inside pass oil? 1 Quote Link to comment
datzenmike Posted May 9, 2017 Report Share Posted May 9, 2017 Unfortunately that is not the Nissan pump so I don't know. If it's leaking gas or oil it can't be right. 1 Quote Link to comment
inazuma Posted May 9, 2017 Report Share Posted May 9, 2017 Unfortunately that is not the Nissan pump so I don't know. If it's leaking gas or oil it can't be right.620 j16 have it engine(change it few year the j15)kyosan denki 2-1 write the body,if can help this information 1 Quote Link to comment
Scgreen620 Posted May 10, 2017 Report Share Posted May 10, 2017 If you don't have a Nikki I say you replace it it looks like it's one piece 1 Quote Link to comment
inazuma Posted May 10, 2017 Report Share Posted May 10, 2017 If you don't have a Nikki I say you replace it it looks like it's one piece Can help the by it correct model ;; 1 Quote Link to comment
Scgreen620 Posted May 10, 2017 Report Share Posted May 10, 2017 You have the correct pump yours isn't rebuild able 1 Quote Link to comment
datzenmike Posted May 10, 2017 Report Share Posted May 10, 2017 That's not a Nissan pump.They are rebuildable if you can find the parts. That is some generic replacement pump. It's simple... if leaking oil or gas it needs to be replaced. It may still work fine but it isn't right. 1 Quote Link to comment
inazuma Posted May 12, 2017 Report Share Posted May 12, 2017 ok thanks both,for the information.. can help me,find the correct fuel pump (j16 engine) oem number;; 1 Quote Link to comment
datzenmike Posted May 13, 2017 Report Share Posted May 13, 2017 I don't have J16 info. 1 Quote Link to comment
inazuma Posted May 13, 2017 Report Share Posted May 13, 2017 I don't have J16 info. i think j15 engine it's same,have it info for this engine code;; Quote Link to comment
