Efi conversion kit?
Dean720Ada
So I googled Weber efi conversion kit and a whole bunch of websites popped up. Redline makes a Weber 45 efi conversion kit. They have efi throttle bodies in direct replacement of the Weber 45 DCOE. So if you are running the Weber 45 you can swap it out with the throttle bodies. They should bolt right up. www.foxinjectjon.com also has Weber 45 conversion kits as well. It's highly exspensive but would this be the simplest way to convert to efi with out any modifications. Some of these kits come with an ecu and everything to do the conversion. This would probably the most efficient way if you want to run a turbo set up. You would have to build a plenum of course. I would like to hear your opinions.
  • Replies 9
Corrected it for you.
At the bottom of every post is an EDIT button, click, make corrections and don't forget to hit the SAVE CHANGES button after. Your corrected post is now displayed.
To correct or amend a title, go to your first post, hit the EDIT but select instead the USE FULL EDITOR to access the title line, make changes and hit the SAVE CHANGES button. Done... easy.
I think it just depends on how big of a boner you have for an L or Z motor. If it were me.. I would just go with a full engine swap for likely cheaper than the kit above. They are seriously cool though.
