Arkrider410 Posted August 11, 2016 Report Share Posted August 11, 2016 To turn it over had to hot wire the starter 1 Quote Link to comment
datzenmike Posted August 11, 2016 Report Share Posted August 11, 2016 If no power to anything including hear lights / brake lights / horn check the fusible link. EVERYTHING has to go through it to get from the battery to the rest of the truck. If you have headlights, check the Black/White wire on the ignition switch for power. If there is power at the ignition switch but no start the switch is bad or the wrong switch? or wiring bad. The start signal comes directly from the ignition switch. 1 Quote Link to comment
Arkrider410 Posted August 11, 2016 Author Report Share Posted August 11, 2016 Thanks I'll check it when I get a chance to 1 Quote Link to comment
G-Duax Posted August 11, 2016 Report Share Posted August 11, 2016 Also check the condition of the fuse black contacts. I had to clean mine with a small round wire brush, and then had to stretch small silicone o-rings around the terminals to keep them tight on the fuses. The terminals get weak, and corroded, and even though you have good fuses, there is little, if any currant passing through. No problems after 2 years of doing this. I probably should just buy one of the repos out of Taiwan, but until it acts up again, no reason to. 4 Quote Link to comment
Draker Posted August 11, 2016 Report Share Posted August 11, 2016 Good idea with the orings! 1 Quote Link to comment
bigboy620 Posted August 11, 2016 Report Share Posted August 11, 2016 I had the same problem. It was my fusible link 1 Quote Link to comment
Charlie69 Posted August 12, 2016 Report Share Posted August 12, 2016 Clean the fusible link connection to the battery. This happens on my 720 from time to time Quote Link to comment
datzenmike Posted August 12, 2016 Report Share Posted August 12, 2016 Also check the condition of the fuse black contacts. I had to clean mine with a small round wire brush, and then had to stretch small silicone o-rings around the terminals to keep them tight on the fuses. The terminals get weak, and corroded, and even though you have good fuses, there is little, if any currant passing through. No problems after 2 years of doing this. I probably should just buy one of the repos out of Taiwan, but until it acts up again, no reason to. My original fuse clips were tarnished and there was resistance. This leads to heat. Headlights would dim and flicker so I would just rub the fuses while driving to get them back. The last time I burned my fucking finger, so it was time to do something about it. The clips had no spring in them, probably from the heat taking the temper out of them, a vicious circle. I replaced the box, and all was well.. I'll admit... probably had halogen lamps that draw more current. To keep from blowing the fuses I likely had larger amp fuses too. Quote Link to comment
G-Duax Posted August 12, 2016 Report Share Posted August 12, 2016 Burned fingers......Yeah, that jogs the old memory banks. Seems like I remember re-staking the rivets that hold the connections together in that thing also. Quote Link to comment
