datO))) Posted June 26, 2016 Report Share Posted June 26, 2016 I'm finally pulling my motor/ trans to see what all is wrong with wagon. Haven't had a spot to do a large project sence I picked up the 411 almost 3 years ago. I've been dealing with the little and big issues as they come and more or less putting band aids on shit. Ok the question, I would like to hear what experiences you all have had using rubber mounts, bushings for everything Applicable VS Polyurethane . Pros , cons? More vibes? Less vibes etc. thanx Quote Link to comment
tr8er Posted June 26, 2016 Report Share Posted June 26, 2016 Stay safe, use a rubber 3 Quote Link to comment
hobospyder Posted June 26, 2016 Report Share Posted June 26, 2016 I had a buddy get poly engine and transfer mounts. If you trust your car to not rattle apart go with it but yeah, the vibrations were intense when he first put them in. I didn't like it Poly bushings I don't have enough experience with but I've heard they squeek when they rub add on twist as well as the rubber ones do. So I still say go with rubber 2 Quote Link to comment
datzenmike Posted June 26, 2016 Report Share Posted June 26, 2016 Rubber is compliant. (it gives) It grips both moving parts and twists internally and has superior vibration isolation. Polly is a 'racing' thing where compliance is not wanted on suspension and steering parts for a firmer more direct input. Vibration isn't an issue when racing. Polly cannot grip two moving parts or grips to a much lesser degree because of it's inherent firmness and lack of flexibility, thus it will wear and or squeak. Again, this is not an issue with a race car that gets regular replacements and maintainance. Tension rods are the worst place for a polly bushings. The tension rod must swing up and down and a polly bushing resists this and can cause unwanted flexing and metal fatigue failure. Only place I would use them, are the sway bar bushings. No one needs polly on non racing applications driven on the street any more than they need a spoiler or hood pins. 2 Quote Link to comment
thisismatt Posted June 26, 2016 Report Share Posted June 26, 2016 I'd only use poly where rotation/articulation isn't necessary, like rear crossmember or mustache mounts on a 510. 2 Quote Link to comment
jesusno2 Posted June 26, 2016 Report Share Posted June 26, 2016 Poly engine mounts are terrible! Worst idea i ever had 2 Quote Link to comment
datzenmike Posted June 26, 2016 Report Share Posted June 26, 2016 Blocks of wood cheaper. 3 Quote Link to comment
datO))) Posted June 26, 2016 Author Report Share Posted June 26, 2016 Dang . I'm sure glad I asked. I was going to do the ES. I guess back to the drawing board. Got a custom ish project. I.e. Fixing PO /crack heads craftsmanship. Almost think i should find the original 1600 for the wagon . I'll post pictures of the project and do a build thread for any custom Steeze that might help. Thanks. We're would one find rubber bushings? Quote Link to comment
datO))) Posted June 27, 2016 Author Report Share Posted June 27, 2016 The answer to everything lol. There's a place in Portland that does custom Rubber. I'm gonna go there a poke around a bit, see if I can't score some throw away chunks. This heat kicked my ass today. Didn't get shit done. Next weekend though, it's goin down . Quote Link to comment
datO))) Posted June 27, 2016 Author Report Share Posted June 27, 2016 Sence the PO did a hack job, I'm going to do a ford Flat head style motor mount set up . Just a straight up and down Kinda doohickey. Quote Link to comment
hobospyder Posted June 27, 2016 Report Share Posted June 27, 2016 Oh and nissan still stocks some of the bushings depending on vehicle 1 Quote Link to comment
datO))) Posted June 27, 2016 Author Report Share Posted June 27, 2016 hummmmmmm. I'll give them a call. It's a '67 but still just a call won't hurt. Unless They laugh at me. That will hurt. Quote Link to comment
paradime Posted June 27, 2016 Report Share Posted June 27, 2016 It would help to provide the part number if possible. Many parts like that are interchangeable for many years, and other models. Where you'd find the part # for a 411 is beyond me. not my barrio. 1 Quote Link to comment
datO))) Posted June 28, 2016 Author Report Share Posted June 28, 2016 It would help to provide the part number if possible. Many parts like that are interchangeable for many years, and other models. Where you'd find the part # for a 411 is beyond me. not my barrio. it's a custom job. The PO hacked the mount so I'm stuck with fanning my own. But it's kinda nice cause I can do it clean and know it's just one more thing to check off th list. 1 Quote Link to comment
paradime Posted June 29, 2016 Report Share Posted June 29, 2016 word ^ I was referring to the bushings, not the Motor mounts though. Sounds like a very cool build. Best of luck. 1 Quote Link to comment
datO))) Posted June 29, 2016 Author Report Share Posted June 29, 2016 got ya. I'm gonna also check the reckon g yard too. I figure if the bushings are round, I could probably use for both motor mounts and body Mounts. Once I get some worthy pictures, I'll post them just share my project with you guys. It's definitely a project lol . Quote Link to comment
datO))) Posted July 1, 2016 Author Report Share Posted July 1, 2016 Man I tell ya auto part store clerks don't know as much as they think they do. I'm gonna have to get my rubber from a junkyard. Quote Link to comment
paradime Posted July 6, 2016 Report Share Posted July 6, 2016 Man I tell ya auto part store clerks don't know as much as they think they do. I'm gonna have to get my rubber from a junkyard. You have to know more than the clerk to get what you want. The only thing they know is how to type in the part #, or go the long way around aka, year, make, model, part. Not likely their data base include a mid 60s Datsun 411. Poke around for a while and you may find the part #s for those bushings. Quote Link to comment
datzenmike Posted July 7, 2016 Report Share Posted July 7, 2016 The older guys are idiots too. Went to GM dealership and ask for "AC Delso Synchromesh Transmission fluid part number #8902...' What's it for!!! "Doesn't matter it's #8902180..." Does matter. You can't use that in any transmission, ya know. I know. #89021...." Have to know what it's going into. ....... " '76 710 Datsun................................................... Went across the street to Lordco was $4 cheaper. 2 Quote Link to comment
datO))) Posted July 14, 2016 Author Report Share Posted July 14, 2016 I finally found some from . The dude was like , feel free to start opening boxes. Can't recall what they are for but$20 and bam! You really do have to get creative with these things but that's what makes it special. Still getting pictures . Then I'll post. Probably going to drive it for awhile once the it's done before I start the next faze . It's caused some disruption. So gotta chew it of bits at a time. Next faze will be channeling the ass end to ad bags and drop that thing but with optional ride Heights. And smooth ride. Then on to tie rods, ends and bushing. Maybe the poly would be a good pick for those items ? Quote Link to comment
datzenmike Posted July 14, 2016 Report Share Posted July 14, 2016 Tie rods just have ball joints on the ends, don't they? If you mean the tension rods that run from the fronts back to each front wheel.. ABSOLUTELY NOT. These must be rubber so they can articulate without the rod flexing. 1 Quote Link to comment
datO))) Posted July 14, 2016 Author Report Share Posted July 14, 2016 Yes . I spoke in general regarding the front end of the wagon I.e. Body mounts swaybar . But I'm getting the consensus that poly is just out all around. Lol I can seem a little jumbled at times. Work long hours as a welder and steel fitter . Mike that also reminds me to Check my upper drive side ball joint. I think it's wallowed out. Quote Link to comment
