Z-train Posted May 21, 2016 Report Share Posted May 21, 2016 last night and step on the brakes. Every light except headlights comes on.I'm under the gun,any thoughts? Quote Link to comment
datzenmike Posted May 21, 2016 Report Share Posted May 21, 2016 I'll assume the engine and ignition was off. Just got in and applied the brakes? Power is always available for the brakes, assuming the fuse is good. It's on the 'always hot side' of the fuse box. Same as horn and interior light. The 620 has dual filament bulbs... brake and running (parking) lamps. If a brake filament broke and a bump caused it to touch a running lamp filament it could easily weld them together and power all the parking, clearance and dash lamps. Quote Link to comment
Z-train Posted May 21, 2016 Author Report Share Posted May 21, 2016 Up-date:Left turn signal stays on(doesn't blink) and when it's on-all the lights in the truck come on. Quote Link to comment
datsunaholic Posted May 21, 2016 Report Share Posted May 21, 2016 As Mike said- you have a bulb shorting the running light to the turn signal. Since the brake does it and the left turn signals do it, it's probably in the left rear taillight. Couple be corrosion in the socket, a loose bulb, or a broken filament in the bulb, so if you pull the left-center bulb in the housing that should solve it. Quote Link to comment
kmc63 Posted May 21, 2016 Report Share Posted May 21, 2016 They tell the truth it happened to me also. Quote Link to comment
banzai510(hainz) Posted May 21, 2016 Report Share Posted May 21, 2016 one time my flasher can turn signal seem to drain my system like under load. I took it out and wacked it then everything was fine. Quote Link to comment
Z-train Posted May 21, 2016 Author Report Share Posted May 21, 2016 one time my flasher can turn signal seem to drain my system like under load. I took it out and wacked it then everything was fine.Machines & people-sometimes all they understand is a good beating. Quote Link to comment
