Rollingstoned916 Posted March 31, 2016 Report Share Posted March 31, 2016 I bought a w58 head recently and was wondering if my u67 valve cover have the same bolt on pattern 1 Quote Link to comment
Rollingstoned916 Posted March 31, 2016 Author Report Share Posted March 31, 2016 Thanks guys I also found someone selling a Weber 32/36 DGEV with a conversion kit would this fit my L20B okay?? 2 Quote Link to comment
Charlie69 Posted March 31, 2016 Report Share Posted March 31, 2016 Why are you changing heads? The U67 is the preferred Street head for a L20B. 1 Quote Link to comment
flatcat19 Posted March 31, 2016 Report Share Posted March 31, 2016 That. ^ Switching to the W58 from the U67 is lateral, if not backwards. Unless the W58 is a peanut. Quote Link to comment
Rollingstoned916 Posted March 31, 2016 Author Report Share Posted March 31, 2016 My u67 is blown Quote Link to comment
flatcat19 Posted March 31, 2016 Report Share Posted March 31, 2016 How does a cylinder head get "blown?" Quote Link to comment
datsunaholic Posted March 31, 2016 Report Share Posted March 31, 2016 You'll have some other interesting problems. Exhaust port design is different. It'll WORK, it just won't be optimal. And you'll want to make sure the water ports in the head are well sealed, since your manifolds, if original to the U67, don't have the matching water ports the W58 head has. Quote Link to comment
Rjawm Posted March 31, 2016 Report Share Posted March 31, 2016 How does a cylinder head get "blown?" Drive on a blown headgasket long enough...granted the example in pic isn't a Datsun head, but still Quote Link to comment
distributorguy Posted March 31, 2016 Report Share Posted March 31, 2016 Easily repaired. Quote Link to comment
datzenmike Posted March 31, 2016 Report Share Posted March 31, 2016 The W58 will have two coolant openings that your U67 does not have but the manifold gasket will seal them closed, no worries. The W58 is basically the same as the U67 but has round exhaust ports with metal liners. Your U67 exhaust manifold has squarish ports. The round head ports will fit the square manifold... ok. I doubt you will notice any difference between them My u67 is blown Do not confuse this with a blown gasket. The gasket is cheap and easy to replace. One other thing. DO NOT remove the cam sprocket to remove the timing chain until you have found out how to secure the chain tensioner down inside. Failure to do this will almost double the amount of work needed to remove the head. Quote Link to comment
Rjawm Posted March 31, 2016 Report Share Posted March 31, 2016 Easily repaired. Usually for much more than the head is worth, unless you have personal access to all the tools needed to make the repair. So not such a great option for most people. Quote Link to comment
